Staging: rtl8192u: Add space before open parenthesis
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
Space is required before the open parenthesis.
This patch adds space after if to address that issue.
This was done with the help of the following Coccinelle script:
@r@
position p1,p2;
if@p1 (@p2 ...) {
@script:python@
p1 << r.p1;
p2 << r.p2;
l1 = int (p1[0].line)
l2 = int (p2[0].line)
c1 = int (p1[0].column)
c2 = int (p2[0].column)
if (l2 == l1 and c1 + 2 != c2):
  cocci.include_match(False)
position r.p1,r.p2;
- if@p1 (
+ if (
Signed-off-by: Haneen Mohammed
 drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c  | 68 +++++++++++-----------
 .../staging/rtl8192u/ieee80211/ieee80211_softmac.c | 40 ++++++-------
 .../rtl8192u/ieee80211/ieee80211_softmac_wx.c      |  4 +-
 .../staging/rtl8192u/ieee80211/rtl819x_BAProc.c    | 20 +++----
 .../staging/rtl8192u/ieee80211/rtl819x_HTProc.c    | 18 +++---
 5 files changed, 75 insertions(+), 75 deletions(-)
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
index 0a90450..b4d09b2 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_rx.c
@@ -608,12 +608,12 @@ static void RxReorderIndicatePacket(struct ieee80211_device *ieee,
 	bool			bMatchWinStart = false, bPktInBuf = false;
 	IEEE80211_DEBUG(IEEE80211_DL_REORDER,"%s(): Seq is %d,pTS->RxIndicateSeq is %d, WinSize is %d\n",__func__,SeqNum,pTS->RxIndicateSeq,WinSize);
 	/* Rx Reorder initialize condition.*/
-	if(pTS->RxIndicateSeq == 0xffff) {
+	if (pTS->RxIndicateSeq == 0xffff) {
 		pTS->RxIndicateSeq = SeqNum;
 	/* Drop out the packet which SeqNum is smaller than WinStart */
-	if(SN_LESS(SeqNum, pTS->RxIndicateSeq)) {
+	if (SN_LESS(SeqNum, pTS->RxIndicateSeq)) {
 		IEEE80211_DEBUG(IEEE80211_DL_REORDER,"Packet Drop! IndicateSeq: %d, NewSeq: %d\n",
 				 pTS->RxIndicateSeq, SeqNum);
 		pHTInfo->RxReorderDropCounter++;
@@ -716,7 +716,7 @@ static void RxReorderIndicatePacket(struct ieee80211_device *ieee,
 		    SN_EQUAL(pReorderEntry->SeqNum, pTS->RxIndicateSeq))
 			/* This protect buffer from overflow. */
-			if(index >= REORDER_WIN_SIZE) {
+			if (index >= REORDER_WIN_SIZE) {
 				IEEE80211_DEBUG(IEEE80211_DL_ERR, "RxReorderIndicatePacket(): Buffer overflow!! \n");
 				bPktInBuf = true;
 				break;
@@ -740,7 +740,7 @@ static void RxReorderIndicatePacket(struct ieee80211_device *ieee,
 	/* Handling pending timer. Set this timer to prevent from long time Rx buffering.*/
-	if(index>0) {
+	if (index>0) {
 		// Cancel previous pending timer.
 	//	del_timer_sync(&pTS->RxPktPendingTimer);
 		pTS->RxTimeoutIndicateSeq = 0xffff;
@@ -753,7 +753,7 @@ static void RxReorderIndicatePacket(struct ieee80211_device *ieee,
 		ieee80211_indicate_packets(ieee, prxbIndicateArray, index);
-	if(bPktInBuf && pTS->RxTimeoutIndicateSeq==0xffff) {
+	if (bPktInBuf && pTS->RxTimeoutIndicateSeq==0xffff) {
 		// Set new pending timer.
 		IEEE80211_DEBUG(IEEE80211_DL_REORDER,"%s(): SET rx timeout timer\n", __func__);
 		pTS->RxTimeoutIndicateSeq = pTS->RxIndicateSeq;
@@ -783,16 +783,16 @@ static u8 parse_subframe(struct sk_buff *skb,
 	/* just for debug purpose */
 	SeqNum = WLAN_GET_SEQ_SEQ(le16_to_cpu(hdr->seq_ctl));
-	if((IEEE80211_QOS_HAS_SEQ(fc))&&\
+	if ((IEEE80211_QOS_HAS_SEQ(fc))&&\
 			(((frameqos *)(skb->data + IEEE80211_3ADDR_LEN))->field.reserved)) {
 		bIsAggregateFrame = true;
-	if(IEEE80211_QOS_HAS_SEQ(fc)) {
+	if (IEEE80211_QOS_HAS_SEQ(fc)) {
 		LLCOffset += 2;
-	if(rx_stats->bContainHTC) {
+	if (rx_stats->bContainHTC) {
 		LLCOffset += sHTCLng;
 	//printk("ChkLength = %d\n", LLCOffset);
@@ -826,7 +826,7 @@ static u8 parse_subframe(struct sk_buff *skb,
 			//==m==>change the length order
 			nSubframe_Length = (nSubframe_Length>>8) + (nSubframe_Length<<8);
-			if(skb->len<(ETHERNET_HEADER_SIZE + nSubframe_Length)) {
+			if (skb->len<(ETHERNET_HEADER_SIZE + nSubframe_Length)) {
 				printk("%s: A-MSDU parse error!! pRfd->nTotalSubframe : %d\n",\
 						__func__, rxb->nr_subframes);
 				printk("%s: A-MSDU parse error!! Subframe Length: %d\n",__func__, nSubframe_Length);
@@ -852,19 +852,19 @@ static u8 parse_subframe(struct sk_buff *skb,
 			memcpy(data_ptr, skb->data, nSubframe_Length);
 #endif
 			rxb->subframes[rxb->nr_subframes++] = sub_skb;
-			if(rxb->nr_subframes >= MAX_SUBFRAME_COUNT) {
+			if (rxb->nr_subframes >= MAX_SUBFRAME_COUNT) {
 				IEEE80211_DEBUG_RX("ParseSubframe(): Too many Subframes! Packets dropped!\n");
 				break;
 			skb_pull(skb, nSubframe_Length);
-			if(skb->len != 0) {
+			if (skb->len != 0) {
 				nPadding_Length = 4 - ((nSubframe_Length + ETHERNET_HEADER_SIZE) % 4);
-				if(nPadding_Length == 4) {
+				if (nPadding_Length == 4) {
 					nPadding_Length = 0;
-				if(skb->len < nPadding_Length) {
+				if (skb->len < nPadding_Length) {
 					return 0;
@@ -938,7 +938,7 @@ int ieee80211_rx(struct ieee80211_device *ieee, struct sk_buff *skb,
 	frag = WLAN_GET_SEQ_FRAG(sc);
 	hdrlen = ieee80211_get_hdrlen(fc);
-	if(HTCCheck(ieee, skb->data))
+	if (HTCCheck(ieee, skb->data))
 		if(net_ratelimit())
 		printk("find HTCControl\n");
@@ -1273,13 +1273,13 @@ int ieee80211_rx(struct ieee80211_device *ieee, struct sk_buff *skb,
 //added by amy for reorder
-	if(ieee->current_network.qos_data.active && IsQoSDataFrame(skb->data)
+	if (ieee->current_network.qos_data.active && IsQoSDataFrame(skb->data)
 		&& !is_multicast_ether_addr(hdr->addr1))
 		TID = Frame_QoSTID(skb->data);
 		SeqNum = WLAN_GET_SEQ_SEQ(sc);
 		GetTs(ieee,(PTS_COMMON_INFO *) &pTS,hdr->addr2,TID,RX_DIR,true);
-		if(TID !=0 && TID !=3)
+		if (TID !=0 && TID !=3)
 			ieee->bis_any_nonbepkts = true;
@@ -1289,7 +1289,7 @@ int ieee80211_rx(struct ieee80211_device *ieee, struct sk_buff *skb,
 	payload = skb->data + hdrlen;
 	//ethertype = (payload[6] << 8) | payload[7];
 	rxb = kmalloc(sizeof(struct ieee80211_rxb), GFP_ATOMIC);
-	if(rxb == NULL)
+	if (rxb == NULL)
 		IEEE80211_DEBUG(IEEE80211_DL_ERR,"%s(): kmalloc rxb error\n",__func__);
 		goto rx_dropped;
@@ -1335,7 +1335,7 @@ int ieee80211_rx(struct ieee80211_device *ieee, struct sk_buff *skb,
 				stats->rx_packets++;
 				stats->rx_bytes += sub_skb->len;
-				if(is_multicast_ether_addr(dst)) {
+				if (is_multicast_ether_addr(dst)) {
 					stats->multicast++;
@@ -1589,14 +1589,14 @@ static inline void ieee80211_extract_country_ie(
 	u8 *addr2
-	if(IS_DOT11D_ENABLE(ieee))
+	if (IS_DOT11D_ENABLE(ieee))
-		if(info_element->len!= 0)
+		if (info_element->len!= 0)
 			memcpy(network->CountryIeBuf, info_element->data, info_element->len);
 			network->CountryIeLen = info_element->len;
-			if(!IS_COUNTRY_IE_VALID(ieee))
+			if (!IS_COUNTRY_IE_VALID(ieee))
 				Dot11d_UpdateCountryIe(ieee, addr2, info_element->len, info_element->data);
@@ -1607,7 +1607,7 @@ static inline void ieee80211_extract_country_ie(
 		// some AP (e.g. Cisco 1242) don't include country IE in their
 		// probe response frame.
-		if(IS_EQUAL_CIE_SRC(ieee, addr2) )
+		if (IS_EQUAL_CIE_SRC(ieee, addr2) )
 			UPDATE_CIE_WATCHDOG(ieee);
@@ -1887,7 +1887,7 @@ int ieee80211_parse_info_param(struct ieee80211_device *ieee,
 			//if(tmp_htcap_len !=0  ||  tmp_htinfo_len != 0)
-				if((info_element->len >= 3 &&
+				if ((info_element->len >= 3 &&
 					 info_element->data[0] == 0x00 &&
 					 info_element->data[1] == 0x05 &&
 					 info_element->data[2] == 0xb5) ||
@@ -1939,7 +1939,7 @@ int ieee80211_parse_info_param(struct ieee80211_device *ieee,
 			else
 				network->cisco_cap_exist = false;
 			//added by amy for LEAP of cisco
-			if(info_element->len > 4 &&
+			if (info_element->len > 4 &&
 				info_element->data[1] == 0x40 &&
 				info_element->data[2] == 0x96 &&
@@ -1975,7 +1975,7 @@ int ieee80211_parse_info_param(struct ieee80211_device *ieee,
 					network->bCcxRmEnable = false;
@@ -2295,7 +2295,7 @@ static inline void update_network(struct ieee80211_network *dst,
 	dst->rates_len = src->rates_len;
 	memcpy(dst->rates_ex, src->rates_ex, src->rates_ex_len);
 	dst->rates_ex_len = src->rates_ex_len;
-	if(src->ssid_len > 0)
+	if (src->ssid_len > 0)
 		memset(dst->ssid, 0, dst->ssid_len);
 		dst->ssid_len = src->ssid_len;
@@ -2351,7 +2351,7 @@ static inline void update_network(struct ieee80211_network *dst,
 		dst->qos_data.param_count = src->qos_data.param_count;
-	if(dst->qos_data.supported == 1) {
+	if (dst->qos_data.supported == 1) {
 		dst->QoS_Enable = 1;
 		if(dst->ssid_len)
 			IEEE80211_DEBUG_QOS
@@ -2366,7 +2366,7 @@ static inline void update_network(struct ieee80211_network *dst,
 	/* dst->last_associate is not overwritten */
 	dst->wmm_info = src->wmm_info; //sure to exist in beacon or probe response frame.
-	if(src->wmm_param[0].ac_aci_acm_aifsn|| \
+	if (src->wmm_param[0].ac_aci_acm_aifsn|| \
 	   src->wmm_param[1].ac_aci_acm_aifsn|| \
 	   src->wmm_param[2].ac_aci_acm_aifsn|| \
 	   src->wmm_param[3].ac_aci_acm_aifsn) {
@@ -2455,7 +2455,7 @@ static inline void ieee80211_process_probe_response(
 	if (!IsLegalChannel(ieee, network.channel))
 		return;
-	if(ieee->bGlobalDomain)
+	if (ieee->bGlobalDomain)
 		if (WLAN_FC_GET_STYPE(beacon->header.frame_ctl) == IEEE80211_STYPE_PROBE_RESP)
@@ -2471,7 +2471,7 @@ static inline void ieee80211_process_probe_response(
 			else
 				// Filter over channel ch12~14
-				if(network.channel > 11)
+				if (network.channel > 11)
 					printk("GetScanInfo(): For Global Domain, filter probe response at channel(%d).\n", network.channel);
 					return;
@@ -2492,7 +2492,7 @@ static inline void ieee80211_process_probe_response(
 			else
-				if(network.channel > 14)
+				if (network.channel > 14)
 					printk("GetScanInfo(): For Global Domain, filter beacon at channel(%d).\n",network.channel);
 					return;
@@ -2513,9 +2513,9 @@ static inline void ieee80211_process_probe_response(
 	spin_lock_irqsave(&ieee->lock, flags);
-	if(is_same_network(&ieee->current_network, &network, ieee)) {
+	if (is_same_network(&ieee->current_network, &network, ieee)) {
 		update_network(&ieee->current_network, &network);
-		if((ieee->current_network.mode == IEEE_N_24G || ieee->current_network.mode == IEEE_G)
+		if ((ieee->current_network.mode == IEEE_N_24G || ieee->current_network.mode == IEEE_G)
 		&& ieee->current_network.berp_info_valid){
 		if(ieee->current_network.erp_value& ERP_UseProtection)
 			ieee->current_network.buseprotection = true;
@@ -2605,7 +2605,7 @@ static inline void ieee80211_process_probe_response(
 	spin_unlock_irqrestore(&ieee->lock, flags);
 	if (is_beacon(beacon->header.frame_ctl)&&is_same_network(&ieee->current_network, &network, ieee)&&\
 		(ieee->state == IEEE80211_LINKED)) {
-		if(ieee->handle_beacon != NULL) {
+		if (ieee->handle_beacon != NULL) {
 			ieee->handle_beacon(ieee->dev,beacon,&ieee->current_network);
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
index 66b1587..168ee32 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac.c
@@ -609,9 +609,9 @@ EXPORT_SYMBOL(ieee80211_stop_scan);
 /* called with ieee->lock held */
 static void ieee80211_start_scan(struct ieee80211_device *ieee)
-	if(IS_DOT11D_ENABLE(ieee) )
+	if (IS_DOT11D_ENABLE(ieee) )
-		if(IS_COUNTRY_IE_VALID(ieee))
+		if (IS_COUNTRY_IE_VALID(ieee))
 			RESET_CIE_WATCHDOG(ieee);
@@ -629,9 +629,9 @@ static void ieee80211_start_scan(struct ieee80211_device *ieee)
 /* called with wx_sem held */
 void ieee80211_start_scan_syncro(struct ieee80211_device *ieee)
@@ -739,7 +739,7 @@ static struct sk_buff *ieee80211_probe_resp(struct ieee80211_device *ieee, u8 *d
 	HTConstructInfoElement(ieee,tmp_ht_info_buf,&tmp_ht_info_len, encrypt);
-	if(pHTInfo->bRegRT2RTAggregation)
+	if (pHTInfo->bRegRT2RTAggregation)
 		tmp_generic_ie_buf = ieee->pHTInfo->szRT2RTAggBuffer;
 		tmp_generic_ie_len = sizeof(ieee->pHTInfo->szRT2RTAggBuffer);
@@ -1016,12 +1016,12 @@ inline struct sk_buff *ieee80211_association_req(struct ieee80211_network *beaco
 	encrypt = ieee->host_encrypt && crypt && crypt->ops && ((0 == strcmp(crypt->ops->name,"WEP") || wpa_ie_len));
 	//Include High Throuput capability && Realtek proprietary
-	if(ieee->pHTInfo->bCurrentHTSupport&&ieee->pHTInfo->bEnableHT)
+	if (ieee->pHTInfo->bCurrentHTSupport&&ieee->pHTInfo->bEnableHT)
 		ht_cap_buf = (u8 *)&(ieee->pHTInfo->SelfHTCap);
 		ht_cap_len = sizeof(ieee->pHTInfo->SelfHTCap);
 		HTConstructCapabilityElement(ieee, ht_cap_buf, &ht_cap_len, encrypt);
-		if(ieee->pHTInfo->bCurrentRT2RTAggregation)
+		if (ieee->pHTInfo->bCurrentRT2RTAggregation)
 			realtek_ie_buf = ieee->pHTInfo->szRT2RTAggBuffer;
 			realtek_ie_len = sizeof( ieee->pHTInfo->szRT2RTAggBuffer);
@@ -1034,11 +1034,11 @@ inline struct sk_buff *ieee80211_association_req(struct ieee80211_network *beaco
-	if(beacon->bCkipSupported)
+	if (beacon->bCkipSupported)
 		ckip_ie_len = 30+2;
-	if(beacon->bCcxRmEnable)
+	if (beacon->bCcxRmEnable)
 		ccxrm_ie_len = 6+2;
@@ -1141,7 +1141,7 @@ inline struct sk_buff *ieee80211_association_req(struct ieee80211_network *beaco
 		tag += osCcxAironetIE.Length;
 		static u8 CcxRmCapBuf[] = {0x00, 0x40, 0x96, 0x01, 0x01, 0x00};
 		OCTET_STRING osCcxRmCap;
@@ -1168,8 +1168,8 @@ inline struct sk_buff *ieee80211_association_req(struct ieee80211_network *beaco
 		tag += osCcxVerNum.Length;
 	//HT cap element
-	if(ieee->pHTInfo->bCurrentHTSupport&&ieee->pHTInfo->bEnableHT){
-		if(ieee->pHTInfo->ePeerHTSpecVer != HT_SPEC_VER_EWC)
+	if (ieee->pHTInfo->bCurrentHTSupport&&ieee->pHTInfo->bEnableHT){
+		if (ieee->pHTInfo->ePeerHTSpecVer != HT_SPEC_VER_EWC)
 			tag = skb_put(skb, ht_cap_len);
 			*tag++ = MFIE_TYPE_HT_CAP;
@@ -1187,12 +1187,12 @@ inline struct sk_buff *ieee80211_association_req(struct ieee80211_network *beaco
 	tag = skb_put(skb, wmm_info_len);
-	if(wmm_info_len) {
+	if (wmm_info_len) {
 	  ieee80211_WMM_Info(ieee, &tag);
 #ifdef THOMAS_TURBO
 	tag = skb_put(skb, turbo_info_len);
-	if(turbo_info_len) {
+	if (turbo_info_len) {
 		ieee80211_TURBO_Info(ieee, &tag);
 #endif
@@ -1358,7 +1358,7 @@ static void ieee80211_associate_complete_wq(struct work_struct *work)
 	ieee->LinkDetectInfo.SlotNum = 2 * (1 + ieee->current_network.beacon_interval/500);
 	// To prevent the immediately calling watch_dog after association.
-	if(ieee->LinkDetectInfo.NumRecvBcnInPeriod==0||ieee->LinkDetectInfo.NumRecvDataInPeriod==0 )
+	if (ieee->LinkDetectInfo.NumRecvBcnInPeriod==0||ieee->LinkDetectInfo.NumRecvDataInPeriod==0 )
 		ieee->LinkDetectInfo.NumRecvBcnInPeriod = 1;
 		ieee->LinkDetectInfo.NumRecvDataInPeriod= 1;
@@ -1782,7 +1782,7 @@ static inline void ieee80211_sta_ps(struct ieee80211_device *ieee)
-	if((ieee->ps == IEEE80211_PS_DISABLED ||
+	if ((ieee->ps == IEEE80211_PS_DISABLED ||
 		ieee->iw_mode != IW_MODE_INFRA ||
 		ieee->state != IEEE80211_LINKED)){
@@ -2024,7 +2024,7 @@ ieee80211_rx_frame_softmac(struct ieee80211_device *ieee, struct sk_buff *skb,
 				ieee->softmac_stats.rx_ass_ok++;
 				/* station support qos */
 				/* Let the register setting defaultly with Legacy station */
-				if(ieee->qos_support) {
+				if (ieee->qos_support) {
 					assoc_resp = (struct ieee80211_assoc_response_frame *)skb->data;
 					memset(network, 0, sizeof(*network));
 					if (ieee80211_parse_info_param(ieee,assoc_resp->info_element,\
@@ -2156,7 +2156,7 @@ void ieee80211_softmac_xmit(struct ieee80211_txb *txb, struct ieee80211_device *
 	ieee->stats.tx_bytes += txb->payload_size;
 	ieee->stats.tx_packets++;
 	tcb_desc = (cb_desc *)(txb->fragments[0]->cb + MAX_DEV_ADDR_SIZE);
-	if(tcb_desc->bMulticast) {
+	if (tcb_desc->bMulticast) {
 		ieee->stats.multicast++;
 	/* if xmit available, just xmit it immediately, else just insert it to the wait queue */
@@ -2460,9 +2460,9 @@ void ieee80211_start_bss(struct ieee80211_device *ieee)
 	// Ref: 802.11d 11.1.3.3
 	// STA shall not start a BSS unless properly formed Beacon frame including a Country IE.
-	if(IS_DOT11D_ENABLE(ieee) && !IS_COUNTRY_IE_VALID(ieee))
+	if (IS_DOT11D_ENABLE(ieee) && !IS_COUNTRY_IE_VALID(ieee))
-		if(! ieee->bGlobalDomain)
+		if (! ieee->bGlobalDomain)
 			return;
diff --git a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
index dcfa5ab..77d0a34 100644
--- a/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
+++ b/drivers/staging/rtl8192u/ieee80211/ieee80211_softmac_wx.c
@@ -345,7 +345,7 @@ void ieee80211_wx_sync_scan_wq(struct work_struct *work)
 	ieee->state = IEEE80211_LINKED;
 	ieee->link_change(ieee->dev);
 	// To prevent the immediately calling watch_dog after scan.
@@ -469,7 +469,7 @@ EXPORT_SYMBOL(ieee80211_wx_get_mode);
 	printk(KERN_INFO"raw TX is %s\n",
 	      ieee->raw_tx ? "enabled" : "disabled");
-	if(ieee->iw_mode == IW_MODE_MONITOR)
+	if (ieee->iw_mode == IW_MODE_MONITOR)
 		if(prev == 0 && ieee->raw_tx){
 			if (ieee->data_hard_resume)
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c
index 1b4623c..618d2cb 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_BAProc.c
@@ -46,14 +46,14 @@ static u8 TxTsDeleteBA(struct ieee80211_device *ieee, PTX_TS_RECORD pTxTs)
 	u8			bSendDELBA = false;
 	// Delete pending BA
-	if(pPendingBa->bValid)
+	if (pPendingBa->bValid)
 		DeActivateBAEntry(ieee, pPendingBa);
 		bSendDELBA = true;
 	// Delete admitted BA
-	if(pAdmittedBa->bValid)
+	if (pAdmittedBa->bValid)
 		DeActivateBAEntry(ieee, pAdmittedBa);
 		bSendDELBA = true;
@@ -74,7 +74,7 @@ static u8 RxTsDeleteBA(struct ieee80211_device *ieee, PRX_TS_RECORD pRxTs)
 	PBA_RECORD		pBa = &pRxTs->RxAdmittedBARecord;
-	if(pBa->bValid)
+	if (pBa->bValid)
 		DeActivateBAEntry(ieee, pBa);
 		bSendDELBA = true;
@@ -363,7 +363,7 @@ int ieee80211_rx_ADDBAReq(struct ieee80211_device *ieee, struct sk_buff *skb)
 	printk("====================>rx ADDBAREQ from :%pM\n", dst);
 //some other capability is not ready now.
-	if(	(ieee->current_network.qos_data.active == 0) ||
+	if ((ieee->current_network.qos_data.active == 0) ||
 		(ieee->pHTInfo->bCurrentHTSupport == false)) //||
 	//	(ieee->pStaQos->bEnableRxImmBA == false)	)
@@ -373,7 +373,7 @@ int ieee80211_rx_ADDBAReq(struct ieee80211_device *ieee, struct sk_buff *skb)
 	// Search for related traffic stream.
 	// If there is no matched TS, reject the ADDBA request.
-	if(	!GetTs(
+	if (!GetTs(
 			ieee,
 			(PTS_COMMON_INFO *)(&pTS),
 			dst,
@@ -390,7 +390,7 @@ int ieee80211_rx_ADDBAReq(struct ieee80211_device *ieee, struct sk_buff *skb)
 	// We can do much more check here, including BufferSize, AMSDU_Support, Policy, StartSeqCtrl...
 	// I want to check StartSeqCtrl to make sure when we start aggregation!!!
-	if(pBaParamSet->field.BAPolicy == BA_POLICY_DELAYED)
+	if (pBaParamSet->field.BAPolicy == BA_POLICY_DELAYED)
 		rc = ADDBA_STATUS_INVALID_PARAM;
 		IEEE80211_DEBUG(IEEE80211_DL_ERR, "BA Policy is not correct in %s()\n", __func__);
@@ -522,7 +522,7 @@ int ieee80211_rx_ADDBARsp(struct ieee80211_device *ieee, struct sk_buff *skb)
 		// We can compare the value of BA parameter set that Peer returned and Self sent.
 		// If it is OK, then admitted. Or we can send DELBA to cancel BA mechanism.
 			// Since this is a kind of ADDBA failed, we delay next ADDBA process.
 			pTS->bAddBaReqDelayed = true;
@@ -582,7 +582,7 @@ int ieee80211_rx_DELBA(struct ieee80211_device *ieee, struct sk_buff *skb)
 		return -1;
-	if(ieee->current_network.qos_data.active == 0 ||
+	if (ieee->current_network.qos_data.active == 0 ||
 		ieee->pHTInfo->bCurrentHTSupport == false )
 		IEEE80211_DEBUG(IEEE80211_DL_ERR, "received DELBA while QOS or HT is not supported(%d, %d)\n",ieee->current_network.qos_data.active, ieee->pHTInfo->bCurrentHTSupport);
@@ -600,7 +600,7 @@ int ieee80211_rx_DELBA(struct ieee80211_device *ieee, struct sk_buff *skb)
 		PRX_TS_RECORD	pRxTs;
-		if( !GetTs(
+		if (!GetTs(
 				ieee,
 				(PTS_COMMON_INFO *)&pRxTs,
 				dst,
@@ -618,7 +618,7 @@ int ieee80211_rx_DELBA(struct ieee80211_device *ieee, struct sk_buff *skb)
 		PTX_TS_RECORD	pTxTs;
-		if(!GetTs(
+		if (!GetTs(
 			ieee,
 			(PTS_COMMON_INFO *)&pTxTs,
 			dst,
diff --git a/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c b/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c
index 69b0e30..c2588f8 100644
--- a/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c
+++ b/drivers/staging/rtl8192u/ieee80211/rtl819x_HTProc.c
@@ -503,7 +503,7 @@ static u8 HTIOTActIsMgntUseCCK6M(struct ieee80211_network *network)
 	// 2008/01/25 MH Judeg if we need to use OFDM to sned MGNT frame for broadcom AP.
 	// 2008/01/28 MH We must prevent that we select null bssid to link.
-	if(network->broadcom_cap_exist)
+	if (network->broadcom_cap_exist)
 		retValue = 1;
@@ -620,7 +620,7 @@ void HTConstructCapabilityElement(struct ieee80211_device *ieee, u8 *posHTCap, u
 	// 2008.06.12
 	// For RTL819X, if pairwisekey = wep/tkip, ap is ralink, we support only MCS0~7.
-	if(ieee->GetHalfNmodeSupportByAPsHandler(ieee->dev))
+	if (ieee->GetHalfNmodeSupportByAPsHandler(ieee->dev))
 		int i;
 		for(i = 1; i< 16; i++)
@@ -747,7 +747,7 @@ void HTConstructRT2RTAggElement(struct ieee80211_device *ieee, u8 *posRT2RTAgg,
 	*posRT2RTAgg++ = 0x01;
 	*posRT2RTAgg = 0x10;//*posRT2RTAgg = 0x02;
-	if(ieee->bSupportRemoteWakeUp) {
+	if (ieee->bSupportRemoteWakeUp) {
 		*posRT2RTAgg |= 0x08;//RT_HT_CAP_USE_WOW;
@@ -874,12 +874,12 @@ u8 HTGetHighestMCSRate(struct ieee80211_device *ieee, u8 *pMCSRateSet, u8 *pMCSF
 	for(i = 0; i < 16; i++)
-		if(availableMcsRate[i] != 0)
+		if (availableMcsRate[i] != 0)
 			bitMap = availableMcsRate[i];
 			for(j = 0; j < 8; j++)
-				if((bitMap%2) != 0)
+				if ((bitMap%2) != 0)
 					if(HTMcsToDataRate(ieee, (8*i+j)) > HTMcsToDataRate(ieee, mcsRate))
 						mcsRate = (8*i+j);
@@ -1062,7 +1062,7 @@ void HTOnAssocRsp(struct ieee80211_device *ieee)
 	// Lanhsin: mark for tmp to avoid deauth by ap from  s3
 	//if(memcmp(pMgntInfo->Bssid, NETGEAR834Bv2_BROADCOM, 3)==0)
-	if(0)
+	if (0)
 			pHTInfo->bCurrentAMPDUEnable = false;
@@ -1298,7 +1298,7 @@ void HTUpdateSelfAndPeerSetting(struct ieee80211_device *ieee,	struct ieee80211_
 //	PHT_CAPABILITY_ELE		pPeerHTCap = (PHT_CAPABILITY_ELE)pNetwork->bssht.bdHTCapBuf;
 	PHT_INFORMATION_ELE		pPeerHTInfo = (PHT_INFORMATION_ELE)pNetwork->bssht.bdHTInfoBuf;
-	if(pHTInfo->bCurrentHTSupport)
+	if (pHTInfo->bCurrentHTSupport)
 		// Config current operation mode.
@@ -1323,7 +1323,7 @@ EXPORT_SYMBOL(HTUpdateSelfAndPeerSetting);
 u8 HTCCheck(struct ieee80211_device *ieee, u8 *pFrame)
-	if(ieee->pHTInfo->bCurrentHTSupport)
+	if (ieee->pHTInfo->bCurrentHTSupport)
 		if ((IsQoSDataFrame(pFrame) && Frame_Order(pFrame)) == 1) {
 			IEEE80211_DEBUG(IEEE80211_DL_HT, "HT CONTROL FILED EXIST!!\n");
@@ -1352,7 +1352,7 @@ void HTSetConnectBwMode(struct ieee80211_device *ieee, HT_CHANNEL_WIDTH	Bandwidt
 //		return;
 //	spin_lock_irqsave(&(ieee->bw_spinlock), flags);
-	if(pHTInfo->bSwBwInProgress) {
+	if (pHTInfo->bSwBwInProgress) {
 //		spin_unlock_irqrestore(&(ieee->bw_spinlock), flags);
 		return;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
