staging: rtl8192e: using random_ether_addr() to generate random MAC
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using random_ether_addr() to generate a random Ethernet
address (MAC) that is not multicast and has the local
assigned bit set. Not need to duplicating its implementation.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
 drivers/staging/rtl8192e/rtllib_softmac.c | 8 +-------
 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index 8027ceb..99e907d 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -2620,13 +2620,7 @@ void rtllib_wake_all_queues(struct rtllib_device *ieee)
 inline void rtllib_randomize_cell(struct rtllib_device *ieee)
-	get_random_bytes(ieee->current_network.bssid, ETH_ALEN);
-	/* an IBSS cell address must have the two less significant
-	 * bits of the first byte = 2
-	ieee->current_network.bssid[0] &= ~0x01;
-	ieee->current_network.bssid[0] |= 0x02;
+	random_ether_addr(ieee->current_network.bssid);
 /* called in user context only */
BtrLinux
Privacy Overview
