staging: rtl8192e: Use kzalloc rather than kmalloc v2
Author: Thomas Meyer <thomas@m3y3r.de>
Use kzalloc rather than kmalloc followed by memset with 0
This considers some simple cases that are common and easy to validate
Note in particular that there are no ...s in the rule, so all of the
matched code has to be contiguous
The semantic patch that makes this change is available
in scripts/coccinelle/api/alloc/kzalloc-simple.cocci.
Signed-off-by: Thomas Meyer
 drivers/staging/rtl8192e/rtllib_crypt.c      | 6 ++----
 drivers/staging/rtl8192e/rtllib_crypt_ccmp.c | 3 +--
 drivers/staging/rtl8192e/rtllib_crypt_tkip.c | 3 +--
 drivers/staging/rtl8192e/rtllib_crypt_wep.c  | 3 +--
 drivers/staging/rtl8192e/rtllib_softmac.c    | 3 +--
 drivers/staging/rtl8192e/rtllib_wx.c         | 3 +--
 6 files changed, 7 insertions(+), 14 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtllib_crypt.c b/drivers/staging/rtl8192e/rtllib_crypt.c
index acda37b..a33bf02 100644
--- a/drivers/staging/rtl8192e/rtllib_crypt.c
+++ b/drivers/staging/rtl8192e/rtllib_crypt.c
@@ -104,11 +104,10 @@ int rtllib_register_crypto_ops(struct rtllib_crypto_ops *ops)
 	if (hcrypt == NULL)
 		return -1;
-	alg = kmalloc(sizeof(*alg), GFP_KERNEL);
+	alg = kzalloc(sizeof(*alg), GFP_KERNEL);
 	if (alg == NULL)
 		return -ENOMEM;
-	memset(alg, 0, sizeof(*alg));
 	alg->ops = ops;
 	spin_lock_irqsave(&hcrypt->lock, flags);
@@ -202,11 +201,10 @@ int __init rtllib_crypto_init(void)
 	int ret = -ENOMEM;
-	hcrypt = kmalloc(sizeof(*hcrypt), GFP_KERNEL);
+	hcrypt = kzalloc(sizeof(*hcrypt), GFP_KERNEL);
 	if (!hcrypt)
 		goto out;
-	memset(hcrypt, 0, sizeof(*hcrypt));
 	INIT_LIST_HEAD(&hcrypt->algs);
 	spin_lock_init(&hcrypt->lock);
diff --git a/drivers/staging/rtl8192e/rtllib_crypt_ccmp.c b/drivers/staging/rtl8192e/rtllib_crypt_ccmp.c
index 6196b9a..63b7504 100644
--- a/drivers/staging/rtl8192e/rtllib_crypt_ccmp.c
+++ b/drivers/staging/rtl8192e/rtllib_crypt_ccmp.c
@@ -63,10 +63,9 @@ static void *rtllib_ccmp_init(int key_idx)
 	struct rtllib_ccmp_data *priv;
-	priv = kmalloc(sizeof(*priv), GFP_ATOMIC);
+	priv = kzalloc(sizeof(*priv), GFP_ATOMIC);
 	if (priv == NULL)
 		goto fail;
-	memset(priv, 0, sizeof(*priv));
 	priv->key_idx = key_idx;
 	priv->tfm = (void *)crypto_alloc_cipher("aes", 0, CRYPTO_ALG_ASYNC);
diff --git a/drivers/staging/rtl8192e/rtllib_crypt_tkip.c b/drivers/staging/rtl8192e/rtllib_crypt_tkip.c
index 6a0c878..70d5001 100644
--- a/drivers/staging/rtl8192e/rtllib_crypt_tkip.c
+++ b/drivers/staging/rtl8192e/rtllib_crypt_tkip.c
@@ -60,10 +60,9 @@ static void *rtllib_tkip_init(int key_idx)
 	struct rtllib_tkip_data *priv;
 	if (priv == NULL)
 		goto fail;
 	priv->tx_tfm_arc4 = crypto_alloc_blkcipher("ecb(arc4)", 0,
 			CRYPTO_ALG_ASYNC);
diff --git a/drivers/staging/rtl8192e/rtllib_crypt_wep.c b/drivers/staging/rtl8192e/rtllib_crypt_wep.c
index c59bf10..1f1ffb8 100644
--- a/drivers/staging/rtl8192e/rtllib_crypt_wep.c
+++ b/drivers/staging/rtl8192e/rtllib_crypt_wep.c
@@ -38,10 +38,9 @@ static void *prism2_wep_init(int keyidx)
 	struct prism2_wep_data *priv;
 	if (priv == NULL)
 		goto fail;
 	priv->key_idx = keyidx;
 	priv->tx_tfm = crypto_alloc_blkcipher("ecb(arc4)", 0, CRYPTO_ALG_ASYNC);
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index fa774cf..30c3bca 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -3048,10 +3048,9 @@ void rtllib_softmac_init(struct rtllib_device *ieee)
 	ieee->state = RTLLIB_NOLINK;
 	for (i = 0; i < 5; i++)
 		ieee->seq_ctrl[i] = 0;
-	ieee->pDot11dInfo = kmalloc(sizeof(struct rt_dot11d_info), GFP_ATOMIC);
+	ieee->pDot11dInfo = kzalloc(sizeof(struct rt_dot11d_info), GFP_ATOMIC);
 	if (!ieee->pDot11dInfo)
 		RTLLIB_DEBUG(RTLLIB_DL_ERR, "can't alloc memory for DOT11D\n");
-	memset(ieee->pDot11dInfo, 0, sizeof(struct rt_dot11d_info));
 	ieee->LinkDetectInfo.SlotIndex = 0;
 	ieee->LinkDetectInfo.SlotNum = 2;
 	ieee->LinkDetectInfo.NumRecvBcnInPeriod = 0;
diff --git a/drivers/staging/rtl8192e/rtllib_wx.c b/drivers/staging/rtl8192e/rtllib_wx.c
index 8cea4a6..a8fd2e1 100644
--- a/drivers/staging/rtl8192e/rtllib_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_wx.c
@@ -368,11 +368,10 @@ int rtllib_wx_set_encode(struct rtllib_device *ieee,
 		struct rtllib_crypt_data *new_crypt;
 		/* take WEP into use */
-		new_crypt = kmalloc(sizeof(struct rtllib_crypt_data),
+		new_crypt = kzalloc(sizeof(struct rtllib_crypt_data),
 				    GFP_KERNEL);
 		if (new_crypt == NULL)
 			return -ENOMEM;
-		memset(new_crypt, 0, sizeof(struct rtllib_crypt_data));
 		new_crypt->ops = rtllib_get_crypto_ops("WEP");
 		if (!new_crypt->ops) {
 			request_module("rtllib_crypt_wep");
BtrLinux
Privacy Overview
