staging: rtl8192e: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
 The semantic patch that makes this change is available
 in scripts/coccinelle/api/memdup.cocci.
 More information about semantic patching is available at
 http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
 drivers/staging/rtl8192e/rtllib_softmac.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index 30c3bca..a326880 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -3206,11 +3206,11 @@ static int rtllib_wpa_set_wpa_ie(struct rtllib_device *ieee,
 		return -EINVAL;
 	if (param->u.wpa_ie.len) {
-		buf = kmalloc(param->u.wpa_ie.len, GFP_KERNEL);
+		buf = kmemdup(param->u.wpa_ie.data, param->u.wpa_ie.len,
+			      GFP_KERNEL);
 		if (buf == NULL)
 			return -ENOMEM;
-		memcpy(buf, param->u.wpa_ie.data, param->u.wpa_ie.len);
 		kfree(ieee->wpa_ie);
 		ieee->wpa_ie = buf;
 		ieee->wpa_ie_len = param->u.wpa_ie.len;
BtrLinux
Privacy Overview
