staging: rtl8192e: use is_zero_ether_addr() instead of memcmp()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using is_zero_ether_addr() instead of directly use
memcmp() to determine if the ethernet address is all
zeros.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
drivers/staging/rtl8192e/rtllib_softmac_wx.c | 7 ++++---
1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtllib_softmac_wx.c b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
index 1bb6b52e..740cf85 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac_wx.c
@@ -14,6 +14,8 @@
+#include <linux/etherdevice.h>
#include "rtllib.h"
#include "dot11d.h"
/* FIXME: add A freqs */
@@ -137,7 +139,6 @@ int rtllib_wx_set_wap(struct rtllib_device *ieee,
int ret = 0;
- u8 zero[] = {0, 0, 0, 0, 0, 0};
unsigned long flags;
short ifup = ieee->proto_started;
@@ -157,7 +158,7 @@ int rtllib_wx_set_wap(struct rtllib_device *ieee,
goto out;
- if (memcmp(temp->sa_data, zero, ETH_ALEN) == 0) {
+ if (is_zero_ether_addr(temp->sa_data)) {
spin_lock_irqsave(&ieee->lock, flags);
memcpy(ieee->current_network.bssid, temp->sa_data, ETH_ALEN);
ieee->wap_set = 0;
@@ -177,7 +178,7 @@ int rtllib_wx_set_wap(struct rtllib_device *ieee,
ieee->cannot_notify = false;
- ieee->wap_set = (memcmp(temp->sa_data, zero, ETH_ALEN) != 0);
+ ieee->wap_set = !is_zero_ether_addr(temp->sa_data);
spin_unlock_irqrestore(&ieee->lock, flags); |
@@ -14,6 +14,8 @@
#include "rtllib.h"
#include "dot11d.h"
int ret = 0;
goto out;
ieee->wap_set = 0;
