Staging: rtl8192e: rtl_wx.c: Remove braces for single statement blocks
Author: Shraddha Barke <shraddha.6596@gmail.com>
The linux kernel coding style discourages use of braces for single
statement blocks. This patch removes the unnecessary braces.
The warning was detected using checkpatch.pl. Coccinelle was used to
make the change.
Signed-off-by: Shraddha Barke
 drivers/staging/rtl8192e/rtl8192e/rtl_wx.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c b/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c
index 7e3ca7e..7e56137 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c
@@ -334,10 +334,9 @@ static int rtl8192_wx_get_range(struct net_device *dev,
 	/* ~130 Mb/s real (802.11n) */
 	range->throughput = 130 * 1000 * 1000;
-	if (priv->rf_set_sens != NULL) {
+	if (priv->rf_set_sens != NULL)
 		/* signal level threshold range */
 		range->sensitivity = priv->max_sens;
 	range->max_qual.qual = 100;
 	range->max_qual.level = 0;
BtrLinux
Privacy Overview
