Staging: rtl8192e: rtl8192e: Remove unnecessory variable
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch removes unnecessory variable in file ret_core.c
using coccinelle script.Semantic patch for this is as follows:
identifier ret;
-int ret = 0;
 ... when != ret
     when strict
-return ret;
+return 0;
Signed-off-by: Vaishali Thakkar
Acked-by: Julia Lawall
 drivers/staging/rtl8192e/rtl8192e/rtl_core.c | 9 ++++-----
 1 file changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
index 129447c..1425829 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
@@ -669,19 +669,18 @@ static int rtl8192_handle_beacon(struct net_device *dev,
 static int rtl8192_qos_association_resp(struct r8192_priv *priv,
 	struct rtllib_network *network)
-	int ret = 0;
 	unsigned long flags;
 	u32 size = sizeof(struct rtllib_qos_parameters);
 	int set_qos_param = 0;
 	if ((priv == NULL) || (network == NULL))
-		return ret;
+		return 0;
 	if (priv->rtllib->state != RTLLIB_LINKED)
-		return ret;
+		return 0;
 	if ((priv->rtllib->iw_mode != IW_MODE_INFRA))
-		return ret;
+		return 0;
 	spin_lock_irqsave(&priv->rtllib->lock, flags);
 	if (network->flags & NETWORK_HAS_QOS_PARAMETERS) {
@@ -711,7 +710,7 @@ static int rtl8192_qos_association_resp(struct r8192_priv *priv,
 		dm_init_edca_turbo(priv->rtllib->dev);
 		queue_work_rsl(priv->priv_wq, &priv->qos_activate);
-	return ret;
+	return 0;
 static int rtl8192_handle_assoc_response(struct net_device *dev,
BtrLinux
Privacy Overview
