Staging: rtl8192e: rtl8192e: Merges two lines of code and removes unused variable
Author: Mahati Chamarthy <mahati.chamarthy@gmail.com>
This patch merges an assignment with an immediately following return of
the assigned variable. It also removes a variable that becomes unused due to this transformation.
The following Coccinelle semantic patch was used to make this transformation:
expression ret;
identifier f;
-ret =
+return
     f(...);
-return ret;
identifier ret;
type t;
identifier c;
-t ret = c;
 ... when != ret
     when strict
Signed-off-by: Mahati Chamarthy
Acked-by: Julia Lawall
 drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c b/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c
index f0b150f..a1ecdff 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c
@@ -85,12 +85,9 @@ void PHY_SetRF8256Bandwidth(struct net_device *dev,
 bool PHY_RF8256_Config(struct net_device *dev)
 	struct r8192_priv *priv = rtllib_priv(dev);
-	bool rtStatus = true;
 	priv->NumTotalRFPath = RTL819X_TOTAL_RF_PATH;
-	rtStatus = phy_RF8256_Config_ParaFile(dev);
-	return rtStatus;
+	return phy_RF8256_Config_ParaFile(dev);
 bool phy_RF8256_Config_ParaFile(struct net_device *dev)
BtrLinux
Privacy Overview
