staging: rtl8192e: replace memset(x,0,ETH_ALEN) by eth_zero_addr(x)
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
eth_zero_addr() is a wrapper function for memset if 0 is going to
be assigned to a mac address. The replacement was done by the
following coccinelle script:
@header@
#include
@eth_zero_addr@
expression e;
-memset(e,0,ETH_ALEN);
+eth_zero_addr(e);
@eth_broadcast_addr@
identifier e;
-memset(e,\(0xff\|0xFF\|255\),ETH_ALEN);
+eth_broadcast_addr(e);
@linux_header depends on !header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
@special_header depends on !header && !linux_header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
@custom_header depends on !header && !linux_header && !special_header && (eth_zero_addr || eth_broadcast_addr) @
+ #include
Signed-off-by: Aya Mahfouz
 drivers/staging/rtl8192e/rtllib_softmac.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index d992a75..16aef7c 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -3751,7 +3751,7 @@ void notify_wx_assoc_event(struct rtllib_device *ieee)
 		printk(KERN_INFO "%s(): Tell user space disconnected\n",
 		       __func__);
-		memset(wrqu.ap_addr.sa_data, 0, ETH_ALEN);
+		eth_zero_addr(wrqu.ap_addr.sa_data);
 	wireless_send_event(ieee->dev, SIOCGIWAP, &wrqu, NULL);
BtrLinux
Privacy Overview
