Staging: rtl8192e: Remove unneeded brackets.
Author: Vatika Harlalka <vatikaharlalka@gmail.com>
These were detected with this Coccinelle script:
identifier f1, f2, f3;
constant c;
f1 =
- (f2 << f3)
+ f2 << f3
- (f2 >> f3)
+ f2 >> f3
- (f2 << c)
+ f2 << c
- (f2 >> c)
+ f2 >> c
Signed-off-by: Vatika Harlalka
Acked-by: Julia Lawall
 drivers/staging/rtl8192e/rtl8192e/rtl_core.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
index 2fbb964..7dda904 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
@@ -131,7 +131,7 @@ static bool PlatformIOCheckPageLegalAndGetRegMask(u32 u4bPage, u8 *pu1bPageMask)
 void write_nic_io_byte(struct net_device *dev, int x, u8 y)
-	u32 u4bPage = (x >> 8);
+	u32 u4bPage = x >> 8;
 	u8 u1PageMask = 0;
 	bool	bIsLegalPage = false;
@@ -154,7 +154,7 @@ void write_nic_io_byte(struct net_device *dev, int x, u8 y)
 void write_nic_io_word(struct net_device *dev, int x, u16 y)
 	u8 u1PageMask = 0;
@@ -177,7 +177,7 @@ void write_nic_io_word(struct net_device *dev, int x, u16 y)
 void write_nic_io_dword(struct net_device *dev, int x, u32 y)
 	u8 u1PageMask = 0;
@@ -199,7 +199,7 @@ void write_nic_io_dword(struct net_device *dev, int x, u32 y)
 u8 read_nic_io_byte(struct net_device *dev, int x)
 	u8 u1PageMask = 0;
 	u8	Data = 0;
@@ -224,7 +224,7 @@ u8 read_nic_io_byte(struct net_device *dev, int x)
 u16 read_nic_io_word(struct net_device *dev, int x)
 	u8 u1PageMask = 0;
 	u16	Data = 0;
@@ -250,7 +250,7 @@ u16 read_nic_io_word(struct net_device *dev, int x)
 u32 read_nic_io_dword(struct net_device *dev, int x)
 	u8 u1PageMask = 0;
 	u32	Data = 0;
BtrLinux
Privacy Overview
