staging: rtl8192e: make return of 0 explicit
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete unnecessary use of a local variable to immediately return 0.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
local idexpression ret;
expression e;
position p;
-ret = 0;
... when != ret = e
return
- ret
+ 0
Signed-off-by: Julia Lawall
 drivers/staging/rtl8192e/rtl8192e/rtl_core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
index 356d521..2920e40 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
@@ -1915,8 +1915,7 @@ int rtl8192_hard_start_xmit(struct sk_buff *skb, struct net_device *dev)
 	memcpy((unsigned char *)(skb->cb), &dev, sizeof(dev));
 	if (queue_index == TXCMD_QUEUE) {
 		rtl8192_tx_cmd(dev, skb);
-		ret = 0;
-		return ret;
+		return 0;
 	} else {
 		tcb_desc->RATRIndex = 7;
 		tcb_desc->bTxDisableRateFallBack = 1;
BtrLinux
Privacy Overview
