staging: rtl8192e: do not use comparisons on bool tests
Author: Valentina Manea <valentina.manea.m@gmail.com>
This patch fixes coccinelle errors regarding comparisons
used in bool tests.
Signed-off-by: Valentina Manea
Reviewed-by: Lisa Nguyen
 drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c  |  6 +++---
 drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c      |  8 ++++----
 drivers/staging/rtl8192e/rtl8192e/r8192E_firmware.c |  2 +-
 drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c      |  9 ++++-----
 drivers/staging/rtl8192e/rtl8192e/rtl_core.c        | 14 ++++++--------
 drivers/staging/rtl8192e/rtl8192e/rtl_dm.c          | 11 +++++------
 drivers/staging/rtl8192e/rtl819x_TSProc.c           |  4 ++--
 drivers/staging/rtl8192e/rtllib_rx.c                |  2 +-
 drivers/staging/rtl8192e/rtllib_softmac.c           | 13 ++++++-------
 drivers/staging/rtl8192e/rtllib_tx.c                |  2 +-
 drivers/staging/rtl8192e/rtllib_wx.c                |  2 +-
 11 files changed, 34 insertions(+), 39 deletions(-)
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c b/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c
index 0da56c8..5af1c19 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8190P_rtl8256.c
@@ -140,7 +140,7 @@ bool phy_RF8256_Config_ParaFile(struct net_device *dev)
 		rtStatus = rtl8192_phy_checkBBAndRF(dev, HW90_BLOCK_RF,
 						(enum rf90_radio_path)eRFPath);
-		if (rtStatus != true) {
+		if (!rtStatus) {
 			RT_TRACE(COMP_ERR, "PHY_RF8256_Config():Check "
 				 "Radio[%d] Fail!!\n", eRFPath);
 			goto phy_RF8256_Config_ParaFile_Fail;
@@ -245,7 +245,7 @@ void PHY_SetRF8256CCKTxPower(struct net_device *dev, u8	powerlevel)
 	struct r8192_priv *priv = rtllib_priv(dev);
 	TxAGC = powerlevel;
-	if (priv->bDynamicTxLowPower == true) {
+	if (priv->bDynamicTxLowPower) {
 		if (priv->CustomerID == RT_CID_819x_Netcore)
 			TxAGC = 0x22;
 		else
@@ -294,7 +294,7 @@ void PHY_SetRF8256OFDMTxPower(struct net_device *dev, u8 powerlevel)
 			priv->Pwr_Track = writeVal_tmp;
-		if (priv->bDynamicTxHighPower == true)
+		if (priv->bDynamicTxHighPower)
 			writeVal = 0x03030303;
 		else
 			writeVal = (byte3 << 24) | (byte2 << 16) |
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c b/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c
index 6616b3a..a816a57 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8192E_dev.c
@@ -720,7 +720,7 @@ start:
 	priv->pFirmware->firmware_status = FW_STATUS_0_INIT;
-	if (priv->RegRfOff == true)
+	if (priv->RegRfOff)
 		priv->rtllib->eRFPowerState = eRfOff;
 	ulRegRead = read_nic_dword(dev, CPU_GEN);
@@ -745,7 +745,7 @@ start:
 	RT_TRACE(COMP_INIT, "BB Config Start!\n");
 	rtStatus = rtl8192_BBConfig(dev);
+	if (!rtStatus) {
 		RT_TRACE(COMP_ERR, "BB Config failed\n");
 		return rtStatus;
@@ -856,7 +856,7 @@ start:
 	if (priv->ResetProgress == RESET_TYPE_NORESET) {
 		RT_TRACE(COMP_INIT, "RF Config Started!\n");
 		rtStatus = rtl8192_phy_RFConfig(dev);
+		if (!rtStatus) {
 			RT_TRACE(COMP_ERR, "RF Config failed\n");
 			return rtStatus;
@@ -869,7 +869,7 @@ start:
 	write_nic_byte(dev, 0x87, 0x0);
-	if (priv->RegRfOff == true) {
+	if (priv->RegRfOff) {
 		RT_TRACE((COMP_INIT | COMP_RF | COMP_POWER),
 			  "%s(): Turn off RF for RegRfOff ----------\n",
 			  __func__);
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8192E_firmware.c b/drivers/staging/rtl8192e/rtl8192e/r8192E_firmware.c
index dd2a96b..abcd22f 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8192E_firmware.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8192E_firmware.c
@@ -329,7 +329,7 @@ bool init_firmware(struct net_device *dev)
 		rt_status = fw_download_code(dev, mapped_file, file_length);
-		if (rt_status != true) {
+		if (!rt_status) {
 			goto download_firmware_fail;
diff --git a/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c b/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c
index 9676c59..21e6ddd 100644
--- a/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c
+++ b/drivers/staging/rtl8192e/rtl8192e/r8192E_phy.c
@@ -567,7 +567,7 @@ static bool rtl8192_BB_Config_ParaFile(struct net_device *dev)
 					 (enum hw90_block)eCheckItem,
 					 (enum rf90_radio_path)0);
+		if (!rtStatus) {
 			RT_TRACE((COMP_ERR | COMP_PHY), "PHY_RF8256_Config():"
 				 "Check PHY%d Fail!!\n", eCheckItem-1);
 			return rtStatus;
@@ -1425,7 +1425,7 @@ static bool SetRFPowerState8190(struct net_device *dev,
 	u8	i = 0, QueueID = 0;
 	struct rtl8192_tx_ring  *ring = NULL;
-	if (priv->SetRFPowerStateInProgress == true)
+	if (priv->SetRFPowerStateInProgress)
 		return false;
 	RT_TRACE(COMP_PS, "===========> SetRFPowerState8190()!\n");
 	priv->SetRFPowerStateInProgress = true;
@@ -1443,10 +1443,9 @@ static bool SetRFPowerState8190(struct net_device *dev,
 					InitilizeCount--;
 					priv->RegRfOff = false;
 					rtstatus = NicIFEnableNIC(dev);
-				} while ((rtstatus != true) &&
-					 (InitilizeCount > 0));
+				} while (!rtstatus && (InitilizeCount > 0));
-				if (rtstatus != true) {
+				if (!rtstatus) {
 					RT_TRACE(COMP_ERR, "%s():Initialize Ada"
 						 "pter fail,return\n",
 						 __func__);
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
index b01f6f5..6ba02fc 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_core.c
@@ -370,8 +370,7 @@ bool MgntActSet_RF_State(struct net_device *dev,
 	case eRfOn:
 		priv->rtllib->RfOffReason &= (~ChangeSource);
-		if ((ChangeSource == RF_CHANGE_BY_HW) &&
-		    (priv->bHwRadioOff == true))
+		if ((ChangeSource == RF_CHANGE_BY_HW) && priv->bHwRadioOff)
 			priv->bHwRadioOff = false;
 		if (!priv->rtllib->RfOffReason) {
@@ -405,8 +404,7 @@ bool MgntActSet_RF_State(struct net_device *dev,
 						      disas_lv_ss);
-		     (priv->bHwRadioOff == false))
+		if ((ChangeSource == RF_CHANGE_BY_HW) && !priv->bHwRadioOff)
 			priv->bHwRadioOff = true;
 		priv->rtllib->RfOffReason |= ChangeSource;
 		bActionAllowed = true;
@@ -428,7 +426,7 @@ bool MgntActSet_RF_State(struct net_device *dev,
 		PHY_SetRFPowerState(dev, StateToSet);
 		if (StateToSet == eRfOn) {
-			if (bConnectBySSID && (priv->blinked_ingpio == true)) {
+			if (bConnectBySSID && priv->blinked_ingpio) {
 				queue_delayed_work_rsl(ieee->wq,
 					 &ieee->associate_procedure_wq, 0);
 				priv->blinked_ingpio = false;
@@ -955,7 +953,7 @@ static int _rtl8192_sta_up(struct net_device *dev, bool is_silent_reset)
 	RT_TRACE(COMP_INIT, "Bringing up iface");
 	priv->bfirst_init = true;
 	init_status = priv->ops->initialize_adapter(dev);
-	if (init_status != true) {
+	if (!init_status) {
 		RT_TRACE(COMP_ERR, "ERR!!! %s(): initialization is failed!\n",
 			 __func__);
 		priv->bfirst_init = false;
@@ -1647,7 +1645,7 @@ void	rtl819x_watchdog_wqcallback(void *data)
 	bool	bHigherBusyRxTraffic = false;
 	bool bEnterPS = false;
-	if (IS_NIC_DOWN(priv) || (priv->bHwRadioOff == true))
+	if (IS_NIC_DOWN(priv) || priv->bHwRadioOff)
 		return;
 	if (priv->rtllib->state >= RTLLIB_LINKED) {
@@ -3045,7 +3043,7 @@ bool NicIFEnableNIC(struct net_device *dev)
 	RT_TRACE(COMP_PS, "===========>%s()\n", __func__);
 			 __func__);
 		priv->bdisable_nic = false;
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c b/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c
index 1853665..bdab150 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_dm.c
@@ -535,7 +535,7 @@ static void dm_TXPowerTrackingCallback_TSSI(struct net_device *dev)
-			if (viviflag == true) {
+			if (viviflag) {
 				write_nic_byte(dev, Pw_Track_Flag, 0);
 				viviflag = false;
 				RT_TRACE(COMP_POWER_TRACKING, "we filted this data\n");
@@ -2273,12 +2273,12 @@ void dm_CheckRfCtrlGPIO(void *data)
 	eRfPowerStateToSet = (tmp1byte&BIT1) ?  eRfOn : eRfOff;
-	if ((priv->bHwRadioOff == true) && (eRfPowerStateToSet == eRfOn)) {
+	if (priv->bHwRadioOff && (eRfPowerStateToSet == eRfOn)) {
 		RT_TRACE(COMP_RF, "gpiochangeRF  - HW Radio ON\n");
 		printk(KERN_INFO "gpiochangeRF  - HW Radio ON\n");
 		bActuallySet = true;
-	} else if ((priv->bHwRadioOff == false) && (eRfPowerStateToSet == eRfOff)) {
+	} else if (!priv->bHwRadioOff && (eRfPowerStateToSet == eRfOff)) {
 		RT_TRACE(COMP_RF, "gpiochangeRF  - HW Radio OFF\n");
 		printk(KERN_INFO "gpiochangeRF  - HW Radio OFF\n");
@@ -2289,7 +2289,7 @@ void dm_CheckRfCtrlGPIO(void *data)
 		mdelay(1000);
 		priv->bHwRfOffAction = 1;
 		MgntActSet_RF_State(dev, eRfPowerStateToSet, RF_CHANGE_BY_HW, true);
-		if (priv->bHwRadioOff == true)
+		if (priv->bHwRadioOff)
 			argv[1] = "RFOFF";
 		else
 			argv[1] = "RFON";
@@ -2946,8 +2946,7 @@ static void dm_dynamic_txpower(struct net_device *dev)
 			priv->bDynamicTxLowPower = false;
 		} else {
 			if (priv->undecorated_smoothed_pwdb <
-			    txlowpower_threshold &&
-			    priv->bDynamicTxHighPower == true)
+			    txlowpower_threshold && priv->bDynamicTxHighPower)
 				priv->bDynamicTxHighPower = false;
 			if (priv->undecorated_smoothed_pwdb < 35)
 				priv->bDynamicTxLowPower = true;
diff --git a/drivers/staging/rtl8192e/rtl819x_TSProc.c b/drivers/staging/rtl8192e/rtl819x_TSProc.c
index 658e875..29608e5 100644
--- a/drivers/staging/rtl8192e/rtl819x_TSProc.c
+++ b/drivers/staging/rtl8192e/rtl819x_TSProc.c
@@ -264,7 +264,7 @@ static struct ts_common_info *SearchAdmitTRStream(struct rtllib_device *ieee,
 		psearch_list = &ieee->Rx_TS_Admit_List;
 	for (dir = 0; dir <= DIR_BI_DIR; dir++) {
-		if (search_dir[dir] == false)
+		if (!search_dir[dir])
 			continue;
 		list_for_each_entry(pRet, psearch_list, List) {
 			if (memcmp(pRet->Addr, Addr, 6) == 0)
@@ -348,7 +348,7 @@ bool GetTs(struct rtllib_device *ieee, struct ts_common_info **ppTS,
 	if (*ppTS != NULL) {
 		return true;
 	} else {
-		if (bAddNewTs == false) {
+		if (!bAddNewTs) {
 			RTLLIB_DEBUG(RTLLIB_DL_TS, "add new TS failed"
 				     "(tid:%d)\n", UP);
 			return false;
diff --git a/drivers/staging/rtl8192e/rtllib_rx.c b/drivers/staging/rtl8192e/rtllib_rx.c
index 8ee80c5..6862172 100644
--- a/drivers/staging/rtl8192e/rtllib_rx.c
+++ b/drivers/staging/rtl8192e/rtllib_rx.c
@@ -1729,7 +1729,7 @@ static inline void rtllib_extract_country_ie(
 			network->CountryIeLen = info_element->len;
 			if (!IS_COUNTRY_IE_VALID(ieee)) {
-				if ((rtllib_act_scanning(ieee, false) == true) && (ieee->FirstIe_InScan == 1))
+				if (rtllib_act_scanning(ieee, false) && ieee->FirstIe_InScan)
 					printk(KERN_INFO "Received beacon ContryIE, SSID: <%s>\n", network->ssid);
 				Dot11d_UpdateCountryIe(ieee, addr2, info_element->len, info_element->data);
diff --git a/drivers/staging/rtl8192e/rtllib_softmac.c b/drivers/staging/rtl8192e/rtllib_softmac.c
index 0cbf6f5..e74d242 100644
--- a/drivers/staging/rtl8192e/rtllib_softmac.c
+++ b/drivers/staging/rtl8192e/rtllib_softmac.c
@@ -604,7 +604,7 @@ static void rtllib_softmac_scan_wq(void *data)
 	if (!ieee->ieee_up)
 		return;
-	if (rtllib_act_scanning(ieee, true) == true)
+	if (rtllib_act_scanning(ieee, true))
 		return;
 	down(&ieee->scan_sem);
@@ -1202,7 +1202,7 @@ inline struct sk_buff *rtllib_association_req(struct rtllib_network *beacon,
 	if ((ieee->rtllib_ap_sec_type &&
 	    (ieee->rtllib_ap_sec_type(ieee) & SEC_ALG_TKIP)) ||
-	    (ieee->bForcedBgMode == true)) {
+	    ieee->bForcedBgMode) {
 		ieee->pHTInfo->bEnableHT = 0;
 		ieee->mode = WIRELESS_MODE_G;
@@ -1535,7 +1535,7 @@ static void rtllib_associate_complete_wq(void *data)
 	struct rt_pwr_save_ctrl *pPSC = (struct rt_pwr_save_ctrl *)
 					(&(ieee->PowerSaveControl));
 	printk(KERN_INFO "Associated successfully\n");
-	if (ieee->is_silent_reset == 0) {
+	if (!ieee->is_silent_reset) {
 		printk(KERN_INFO "normal associate\n");
 		notify_wx_assoc_event(ieee);
@@ -1572,7 +1572,7 @@ static void rtllib_associate_complete_wq(void *data)
 	pPSC->LpsIdleCount = 0;
 	ieee->link_change(ieee->dev);
-	if (ieee->is_silent_reset == 1) {
+	if (ieee->is_silent_reset) {
 		printk(KERN_INFO "silent reset associate\n");
 		ieee->is_silent_reset = 0;
@@ -2005,7 +2005,7 @@ static short rtllib_sta_ps_sleep(struct rtllib_device *ieee, u64 *time)
 		return 0;
 	if (time) {
-		if (ieee->bAwakePktSent == true) {
+		if (ieee->bAwakePktSent) {
 			pPSC->LPSAwakeIntvl = 1;
 		} else {
 			u8		MaxPeriod = 1;
@@ -2338,8 +2338,7 @@ inline int rtllib_rx_auth(struct rtllib_device *ieee, struct sk_buff *skb,
 					if (ieee->current_network.mode ==
-					    IEEE_N_24G &&
-					    bHalfSupportNmode == true) {
+					    IEEE_N_24G && bHalfSupportNmode) {
 						printk(KERN_INFO "======>enter "
 						       "half N mode\n");
 						ieee->bHalfWirelessN24GMode =
diff --git a/drivers/staging/rtl8192e/rtllib_tx.c b/drivers/staging/rtl8192e/rtllib_tx.c
index 1cc6a9d..3183627 100644
--- a/drivers/staging/rtl8192e/rtllib_tx.c
+++ b/drivers/staging/rtl8192e/rtllib_tx.c
@@ -908,7 +908,7 @@ int rtllib_xmit_inter(struct sk_buff *skb, struct net_device *dev)
 				tcb_desc->data_rate = CURRENT_RATE(ieee->mode,
 					ieee->rate, ieee->HTCurrentOperaRate);
-			if (bdhcp == true) {
+			if (bdhcp) {
 				if (ieee->pHTInfo->IOTAction &
 				    HT_IOT_ACT_WA_IOT_Broadcom) {
diff --git a/drivers/staging/rtl8192e/rtllib_wx.c b/drivers/staging/rtl8192e/rtllib_wx.c
index c7e8d4d8..13af43b 100644
--- a/drivers/staging/rtl8192e/rtllib_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_wx.c
@@ -753,7 +753,7 @@ int rtllib_wx_set_mlme(struct rtllib_device *ieee,
 		/* leave break out intentionly */
 	case IW_MLME_DISASSOC:
-		if (deauth == true)
+		if (deauth)
 			printk(KERN_INFO "disauth packet !\n");
 		else
 			printk(KERN_INFO "dis associate packet!\n");
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
