staging: rtl8188eu: os_dep: Used min_t instead of min
Author: Gulsah Kose <gulsah.1004@gmail.com>
This patch fixes this checkpatch.pl warning:
WARNING: min() should probably be min_t(int, req->essid_len,
IW_ESSID_MAX_SIZE)
by using this coccinelle script:
@r@
identifier i;
expression e1, e2;
type t1, t2;
t1 i =
- min((t2)e1, e2);
+ min_t(t2, e1, e2);
Signed-off-by: Gulsah Kose
Reviewed-by: Daniel Baluta
 drivers/staging/rtl8188eu/os_dep/ioctl_linux.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c b/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
index 70b729f..08ba7d3 100644
--- a/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
+++ b/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
@@ -1134,7 +1134,8 @@ static int rtw_wx_set_scan(struct net_device *dev, struct iw_request_info *a,
 		struct iw_scan_req *req = (struct iw_scan_req *)extra;
 		if (wrqu->data.flags & IW_SCAN_THIS_ESSID) {
-			int len = min((int)req->essid_len, IW_ESSID_MAX_SIZE);
+			int len = min_t(int, req->essid_len,
+					IW_ESSID_MAX_SIZE);
 			memcpy(ssid[0].Ssid, req->essid, len);
 			ssid[0].SsidLength = len;
BtrLinux
Privacy Overview
