staging: rtl8188eu: os_dep: ioctl_linux: Clean up tests if NULL returned on failure
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Some functions like kmalloc/kzalloc return NULL on failure.
When NULL represents failure, !x is commonly used.
This was done using Coccinelle:
expression *e;
identifier l1;
e = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\)(...);
- e == NULL
+ !e
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8188eu/os_dep/ioctl_linux.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c b/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
index eeb1694..5672f01 100644
--- a/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
+++ b/drivers/staging/rtl8188eu/os_dep/ioctl_linux.c
@@ -2115,13 +2115,13 @@ static u8 set_pairwise_key(struct adapter *padapter, struct sta_info *psta)
 	u8 res = _SUCCESS;
 	ph2c = kzalloc(sizeof(struct cmd_obj), GFP_KERNEL);
-	if (ph2c == NULL) {
+	if (!ph2c) {
 		res = _FAIL;
 		goto exit;
 	psetstakey_para = kzalloc(sizeof(struct set_stakey_parm), GFP_KERNEL);
-	if (psetstakey_para == NULL) {
+	if (!psetstakey_para) {
 		kfree(ph2c);
 		res = _FAIL;
 		goto exit;
@@ -2153,12 +2153,12 @@ static int set_group_key(struct adapter *padapter, u8 *key, u8 alg, int keyid)
 	DBG_88E("%s\n", __func__);
 	pcmd = kzalloc(sizeof(struct	cmd_obj), GFP_KERNEL);
-	if (pcmd == NULL) {
+	if (!pcmd) {
 		res = _FAIL;
 		goto exit;
 	psetkeyparm = kzalloc(sizeof(struct setkey_parm), GFP_KERNEL);
-	if (psetkeyparm == NULL) {
+	if (!psetkeyparm) {
 		kfree(pcmd);
 		res = _FAIL;
 		goto exit;
BtrLinux
Privacy Overview
