Staging: rtl8188eu: os_dep: Compression of lines for immediate return
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
This patch compresses two lines in to a single line in file rtw_android.c
if immediate return statement is found. It also removes variable bytes_written as
it is no longer needed.
It is done using script Coccinelle. And coccinelle uses following semantic
patch for this compression function:
expression ret;
identifier f;
-ret =
+return
     f(...);
-return ret;
Signed-off-by: Vaishali Thakkar
Acked-by: Julia Lawall
 drivers/staging/rtl8188eu/os_dep/rtw_android.c | 9 ++-------
 1 file changed, 2 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/rtl8188eu/os_dep/rtw_android.c b/drivers/staging/rtl8188eu/os_dep/rtw_android.c
index ca2736d..1718229 100644
--- a/drivers/staging/rtl8188eu/os_dep/rtw_android.c
+++ b/drivers/staging/rtl8188eu/os_dep/rtw_android.c
@@ -106,23 +106,18 @@ static int rtw_android_get_link_speed(struct net_device *net, char *command,
 				      int total_len)
 	struct adapter *padapter = (struct adapter *)rtw_netdev_priv(net);
-	int bytes_written;
 	u16 link_speed;
 	link_speed = rtw_get_cur_max_rate(padapter) / 10;
-	bytes_written = snprintf(command, total_len, "LinkSpeed %d",
+	return snprintf(command, total_len, "LinkSpeed %d",
 				 link_speed);
-	return bytes_written;
 static int rtw_android_get_macaddr(struct net_device *net, char *command,
 				   int total_len)
-	bytes_written = snprintf(command, total_len, "Macaddr = %pM",
+	return snprintf(command, total_len, "Macaddr = %pM",
 				 net->dev_addr);
 static int android_set_cntry(struct net_device *net, char *command,
BtrLinux
Privacy Overview
