drivers/staging/rtl8188eu/core/rtw_cmd.c | 18 ++++---
drivers/staging/rtl8188eu/core/rtw_ioctl_set.c | 3 +-
drivers/staging/rtl8188eu/core/rtw_led.c | 59 +++++++++++++++--------
drivers/staging/rtl8188eu/core/rtw_mlme.c | 15 ++++--
drivers/staging/rtl8188eu/core/rtw_mlme_ext.c | 7 +--
drivers/staging/rtl8188eu/core/rtw_recv.c | 6 ++-
drivers/staging/rtl8188eu/include/osdep_service.h | 5 --
drivers/staging/rtl8188eu/include/rtw_mlme_ext.h | 10 ++--
drivers/staging/rtl8188eu/include/rtw_pwrctrl.h | 5 +-
drivers/staging/rtl8188eu/include/rtw_recv.h | 4 +-
drivers/staging/rtl8188eu/os_dep/os_intfs.c | 6 ++-
11 files changed, 82 insertions(+), 56 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_cmd.c b/drivers/staging/rtl8188eu/core/rtw_cmd.c
index 4b43462..89b5e48 100644
--- a/drivers/staging/rtl8188eu/core/rtw_cmd.c
+++ b/drivers/staging/rtl8188eu/core/rtw_cmd.c
@@ -325,7 +325,8 @@ u8 rtw_sitesurvey_cmd(struct adapter *padapter, struct ndis_802_11_ssid *ssid,
if (res == _SUCCESS) {
pmlmepriv->scan_start_time = jiffies;
- _set_timer(&pmlmepriv->scan_to_timer, SCANNING_TIMEOUT);
+ mod_timer(&pmlmepriv->scan_to_timer,
+ jiffies + msecs_to_jiffies(SCANNING_TIMEOUT));
rtw_led_control(padapter, LED_CTL_SITE_SURVEY);
@@ -1234,9 +1235,11 @@ void rtw_survey_cmd_callback(struct adapter *padapter, struct cmd_obj *pcmd)
if (pcmd->res == H2C_DROPPED) {
/* TODO: cancel timer and do timeout handler directly... */
/* need to make timeout handlerOS independent */
- _set_timer(&pmlmepriv->scan_to_timer, 1);
+ jiffies + msecs_to_jiffies(1));
} else if (pcmd->res != H2C_SUCCESS) {
RT_TRACE(_module_rtl871x_cmd_c_, _drv_err_, ("\n ********Error: MgntActrtw_set_802_11_bssid_LIST_SCAN Fail ************\n\n."));
@@ -1270,10 +1273,12 @@ void rtw_joinbss_cmd_callback(struct adapter *padapter, struct cmd_obj *pcmd)
- _set_timer(&pmlmepriv->assoc_timer, 1);
+ mod_timer(&pmlmepriv->assoc_timer,
RT_TRACE(_module_rtl871x_cmd_c_, _drv_err_, ("********Error:rtw_select_and_join_from_scanned_queue Wait Sema Fail ************\n"));
rtw_free_cmd_obj(pcmd);
@@ -1291,7 +1296,8 @@ void rtw_createbss_cmd_callback(struct adapter *padapter, struct cmd_obj *pcmd)
RT_TRACE(_module_rtl871x_cmd_c_, _drv_err_, ("\n ********Error: rtw_createbss_cmd_callback Fail ************\n\n."));
del_timer_sync(&pmlmepriv->assoc_timer);
diff --git a/drivers/staging/rtl8188eu/core/rtw_ioctl_set.c b/drivers/staging/rtl8188eu/core/rtw_ioctl_set.c
index 2faf6b2..969150a 100644
--- a/drivers/staging/rtl8188eu/core/rtw_ioctl_set.c
+++ b/drivers/staging/rtl8188eu/core/rtw_ioctl_set.c
@@ -86,7 +86,8 @@ u8 rtw_do_join(struct adapter *padapter)
select_ret = rtw_select_and_join_from_scanned_queue(pmlmepriv);
if (select_ret == _SUCCESS) {
pmlmepriv->to_join = false;
- _set_timer(&pmlmepriv->assoc_timer, MAX_JOIN_TIMEOUT);
+ jiffies + msecs_to_jiffies(MAX_JOIN_TIMEOUT));
} else {
if (check_fwstate(pmlmepriv, WIFI_ADHOC_STATE) == true) {
/* submit createbss_cmd to change to a ADHOC_MASTER */
diff --git a/drivers/staging/rtl8188eu/core/rtw_led.c b/drivers/staging/rtl8188eu/core/rtw_led.c
index 1b8264b..e8b82b2f 100644
--- a/drivers/staging/rtl8188eu/core/rtw_led.c
+++ b/drivers/staging/rtl8188eu/core/rtw_led.c
@@ -122,14 +122,16 @@ static void SwLedBlink1(struct LED_871x *pLed)
pLed->BlinkingLedState = RTW_LED_OFF;
else
pLed->BlinkingLedState = RTW_LED_ON;
- _set_timer(&(pLed->BlinkTimer), LED_BLINK_NO_LINK_INTERVAL_ALPHA);
+ mod_timer(&pLed->BlinkTimer, jiffies +
+ msecs_to_jiffies(LED_BLINK_NO_LINK_INTERVAL_ALPHA));
break;
case LED_BLINK_NORMAL:
if (pLed->bLedOn)
else
- _set_timer(&(pLed->BlinkTimer), LED_BLINK_LINK_INTERVAL_ALPHA);
+ msecs_to_jiffies(LED_BLINK_LINK_INTERVAL_ALPHA));
break;
case LED_BLINK_SCAN:
pLed->BlinkTimes--;
@@ -143,7 +145,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
RT_TRACE(_module_rtl8712_led_c_, _drv_info_, ("CurrLedState %d\n", pLed->CurrLedState));
} else if (!check_fwstate(pmlmepriv, _FW_LINKED)) {
pLed->bLedNoLinkBlinkInProgress = true;
@@ -152,7 +155,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
pLed->bLedScanBlinkInProgress = false;
@@ -161,7 +165,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
- _set_timer(&(pLed->BlinkTimer), LED_BLINK_SCAN_INTERVAL_ALPHA);
+ msecs_to_jiffies(LED_BLINK_SCAN_INTERVAL_ALPHA));
break;
case LED_BLINK_TXRX:
@@ -176,7 +181,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
@@ -185,7 +191,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
pLed->BlinkTimes = 0;
@@ -195,7 +202,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
- _set_timer(&(pLed->BlinkTimer), LED_BLINK_FASTER_INTERVAL_ALPHA);
+ msecs_to_jiffies(LED_BLINK_FASTER_INTERVAL_ALPHA));
break;
case LED_BLINK_WPS:
@@ -203,7 +211,8 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
break;
case LED_BLINK_WPS_STOP: /* WPS success */
if (pLed->BlinkingLedState == RTW_LED_ON)
@@ -218,14 +227,15 @@ static void SwLedBlink1(struct LED_871x *pLed)
else
pLed->bLedWPSBlinkInProgress = false;
} else {
- LED_BLINK_WPS_SUCCESS_INTERVAL_ALPHA);
+ msecs_to_jiffies(LED_BLINK_WPS_SUCCESS_INTERVAL_ALPHA));
break;
default:
@@ -262,7 +272,8 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
else
break;
case LED_CTL_LINK:
@@ -283,7 +294,8 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
else
break;
case LED_CTL_SITE_SURVEY:
@@ -311,7 +323,8 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
else
break;
case LED_CTL_TX:
@@ -334,7 +347,8 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
else
break;
case LED_CTL_START_WPS: /* wait until xinpin finish */
@@ -362,7 +376,8 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
else
break;
case LED_CTL_STOP_WPS:
@@ -389,11 +404,12 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
pLed->CurrLedState = LED_BLINK_WPS_STOP;
if (pLed->bLedOn) {
} else {
- _set_timer(&(pLed->BlinkTimer), 0);
+ jiffies + msecs_to_jiffies(0));
break;
case LED_CTL_STOP_WPS_FAIL:
@@ -407,7 +423,8 @@ static void SwLedControlMode1(struct adapter *padapter, enum LED_CTL_MODE LedAct
else
break;
case LED_CTL_POWER_OFF:
pLed->CurrLedState = RTW_LED_OFF;
diff --git a/drivers/staging/rtl8188eu/core/rtw_mlme.c b/drivers/staging/rtl8188eu/core/rtw_mlme.c
index d4632da..f006679 100644
--- a/drivers/staging/rtl8188eu/core/rtw_mlme.c
+++ b/drivers/staging/rtl8188eu/core/rtw_mlme.c
@@ -665,7 +665,8 @@ void rtw_surveydone_event_callback(struct adapter *adapter, u8 *pbuf)
set_fwstate(pmlmepriv, _FW_UNDER_LINKING);
if (rtw_select_and_join_from_scanned_queue(pmlmepriv) == _SUCCESS) {
} else {
struct wlan_bssid_ex *pdev_network = &(adapter->registrypriv.dev_network);
u8 *pibss = adapter->registrypriv.dev_network.MacAddress;
@@ -692,7 +693,8 @@ void rtw_surveydone_event_callback(struct adapter *adapter, u8 *pbuf)
s_ret = rtw_select_and_join_from_scanned_queue(pmlmepriv);
if (_SUCCESS == s_ret) {
} else if (s_ret == 2) { /* there is no need to wait for join */
_clr_fwstate_(pmlmepriv, _FW_UNDER_LINKING);
rtw_indicate_connect(adapter);
@@ -1127,14 +1129,16 @@ void rtw_joinbss_event_prehandle(struct adapter *adapter, u8 *pbuf)
} else if (pnetwork->join_res == -4) {
rtw_reset_securitypriv(adapter);
if ((check_fwstate(pmlmepriv, _FW_UNDER_LINKING)) == true) {
RT_TRACE(_module_rtl871x_mlme_c_, _drv_err_, ("fail! clear _FW_UNDER_LINKING ^^^fw_state=%x\n", get_fwstate(pmlmepriv)));
} else { /* if join_res < 0 (join fails), then try again */
@@ -1449,7 +1453,8 @@ void rtw_dynamic_check_timer_handlder(void *function_context)
rtw_auto_scan_handler(adapter);
exit:
- _set_timer(&adapter->mlmepriv.dynamic_chk_timer, 2000);
+ mod_timer(&adapter->mlmepriv.dynamic_chk_timer,
+ jiffies + msecs_to_jiffies(2000));
#define RTW_SCAN_RESULT_EXPIRE 2000
diff --git a/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c b/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
index cd12dd7..e496276 100644
--- a/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
+++ b/drivers/staging/rtl8188eu/core/rtw_mlme_ext.c
@@ -3972,8 +3972,8 @@ void start_clnt_join(struct adapter *padapter)
/* and enable a timer */
beacon_timeout = decide_wait_for_beacon_timeout(pmlmeinfo->bcn_interval);
set_link_timer(pmlmeext, beacon_timeout);
- _set_timer(&padapter->mlmepriv.assoc_timer,
- (REAUTH_TO * REAUTH_LIMIT) + (REASSOC_TO*REASSOC_LIMIT) + beacon_timeout);
+ mod_timer(&padapter->mlmepriv.assoc_timer, jiffies +
+ msecs_to_jiffies((REAUTH_TO * REAUTH_LIMIT) + (REASSOC_TO * REASSOC_LIMIT) + beacon_timeout));
pmlmeinfo->state = WIFI_FW_AUTH_NULL | WIFI_FW_STATION_STATE;
} else if (caps&cap_IBSS) { /* adhoc client */
@@ -5406,7 +5406,8 @@ u8 add_ba_hdl(struct adapter *padapter, unsigned char *pbuf)
if (((pmlmeinfo->state & WIFI_FW_ASSOC_SUCCESS) && (pmlmeinfo->HT_enable)) ||
((pmlmeinfo->state&0x03) == WIFI_FW_AP_STATE)) {
issue_action_BA(padapter, pparm->addr, RTW_WLAN_ACTION_ADDBA_REQ, (u16)pparm->tid);
- _set_timer(&psta->addba_retry_timer, ADDBA_TO);
+ mod_timer(&psta->addba_retry_timer,
+ jiffies + msecs_to_jiffies(ADDBA_TO));
} else {
psta->htpriv.candidate_tid_bitmap &= ~BIT(pparm->tid);
diff --git a/drivers/staging/rtl8188eu/core/rtw_recv.c b/drivers/staging/rtl8188eu/core/rtw_recv.c
index bd79e9e..0db421e 100644
--- a/drivers/staging/rtl8188eu/core/rtw_recv.c
+++ b/drivers/staging/rtl8188eu/core/rtw_recv.c
@@ -1927,7 +1927,8 @@ static int recv_indicatepkt_reorder(struct adapter *padapter,
/* recv_indicatepkts_in_order(padapter, preorder_ctrl, true); */
if (recv_indicatepkts_in_order(padapter, preorder_ctrl, false)) {
- _set_timer(&preorder_ctrl->reordering_ctrl_timer, REORDER_WAIT_TIME);
+ mod_timer(&preorder_ctrl->reordering_ctrl_timer,
+ jiffies + msecs_to_jiffies(REORDER_WAIT_TIME));
spin_unlock_bh(&ppending_recvframe_queue->lock);
} else {
@@ -1957,7 +1958,8 @@ void rtw_reordering_ctrl_timeout_handler(void *pcontext)
spin_lock_bh(&ppending_recvframe_queue->lock);
if (recv_indicatepkts_in_order(padapter, preorder_ctrl, true) == true)
diff --git a/drivers/staging/rtl8188eu/include/osdep_service.h b/drivers/staging/rtl8188eu/include/osdep_service.h
index 3a27477..4c968ac 100644
--- a/drivers/staging/rtl8188eu/include/osdep_service.h
+++ b/drivers/staging/rtl8188eu/include/osdep_service.h
@@ -85,11 +85,6 @@ static inline void _init_timer(struct timer_list *ptimer,
init_timer(ptimer);
-static inline void _set_timer(struct timer_list *ptimer, u32 delay_time)
- mod_timer(ptimer , (jiffies+msecs_to_jiffies(delay_time)));
#define RTW_TIMER_HDL_ARGS void *FunctionContext
#define RTW_TIMER_HDL_NAME(name) rtw_##name##_timer_hdl
#define RTW_DECLARE_TIMER_HDL(name) \
diff --git a/drivers/staging/rtl8188eu/include/rtw_mlme_ext.h b/drivers/staging/rtl8188eu/include/rtw_mlme_ext.h
index 4f05aee..51c9173 100644
--- a/drivers/staging/rtl8188eu/include/rtw_mlme_ext.h
+++ b/drivers/staging/rtl8188eu/include/rtw_mlme_ext.h
@@ -650,14 +650,12 @@ void link_timer_hdl(void *funtion_context);
void addba_timer_hdl(void *function_context);
#define set_survey_timer(mlmeext, ms) \
- do { \
- _set_timer(&(mlmeext)->survey_timer, (ms)); \
- } while (0)
+ mod_timer(&mlmeext->survey_timer, jiffies + \
+ msecs_to_jiffies(ms))
#define set_link_timer(mlmeext, ms) \
- do { \
- _set_timer(&(mlmeext)->link_timer, (ms)); \
- } while (0)
+ mod_timer(&mlmeext->link_timer, jiffies + \
int cckrates_included(unsigned char *rate, int ratelen);
int cckratesonly_included(unsigned char *rate, int ratelen);
diff --git a/drivers/staging/rtl8188eu/include/rtw_pwrctrl.h b/drivers/staging/rtl8188eu/include/rtw_pwrctrl.h
index 54dfbf0..aa1fd87 100644
--- a/drivers/staging/rtl8188eu/include/rtw_pwrctrl.h
+++ b/drivers/staging/rtl8188eu/include/rtw_pwrctrl.h
@@ -233,9 +233,8 @@ struct pwrctrl_priv {
#define RTW_PWR_STATE_CHK_INTERVAL 2000
#define _rtw_set_pwr_state_check_timer(pwrctrlpriv, ms) \
- do { \
- _set_timer(&(pwrctrlpriv)->pwr_state_check_timer, (ms)); \
- } while (0)
+ mod_timer(&pwrctrlpriv->pwr_state_check_timer, \
+ jiffies + msecs_to_jiffies(ms))
#define rtw_set_pwr_state_check_timer(pwrctrl) \
_rtw_set_pwr_state_check_timer((pwrctrl), \
diff --git a/drivers/staging/rtl8188eu/include/rtw_recv.h b/drivers/staging/rtl8188eu/include/rtw_recv.h
index f0c26ef..241a871 100644
--- a/drivers/staging/rtl8188eu/include/rtw_recv.h
+++ b/drivers/staging/rtl8188eu/include/rtw_recv.h
@@ -216,8 +216,8 @@ struct recv_priv {
#define rtw_set_signal_stat_timer(recvpriv) \
- _set_timer(&(recvpriv)->signal_stat_timer, \
- (recvpriv)->signal_stat_sampling_interval)
+ mod_timer(&(recvpriv)->signal_stat_timer, jiffies + \
+ msecs_to_jiffies((recvpriv)->signal_stat_sampling_interval))
struct sta_recv_priv {
spinlock_t lock;
diff --git a/drivers/staging/rtl8188eu/os_dep/os_intfs.c b/drivers/staging/rtl8188eu/os_dep/os_intfs.c
index 88a909c..5fe3ae5 100644
--- a/drivers/staging/rtl8188eu/os_dep/os_intfs.c
+++ b/drivers/staging/rtl8188eu/os_dep/os_intfs.c
@@ -998,7 +998,8 @@ int _netdev_open(struct net_device *pnetdev)
padapter->net_closed = false;
- _set_timer(&padapter->mlmepriv.dynamic_chk_timer, 2000);
+ mod_timer(&padapter->mlmepriv.dynamic_chk_timer,
padapter->pwrctrlpriv.bips_processing = false;
rtw_set_pwr_state_check_timer(&padapter->pwrctrlpriv);
@@ -1052,7 +1053,8 @@ static int ips_netdrv_open(struct adapter *padapter)
padapter->intf_start(padapter);
- _set_timer(&padapter->mlmepriv.dynamic_chk_timer, 5000);
+ jiffies + msecs_to_jiffies(5000));
return _SUCCESS; |
