staging: rtl8188eu: core: Remove unnecessary braces
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
This patch removes braces for single statement blocks. The warning
was detected using checkpatch.pl.
Coccinelle was used to make the change.
expression e,e1;
- if (e) {
+ if (e)
  e1;
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rtl8188eu/core/rtw_recv.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_recv.c b/drivers/staging/rtl8188eu/core/rtw_recv.c
index c81639c..40b7a30 100644
--- a/drivers/staging/rtl8188eu/core/rtw_recv.c
+++ b/drivers/staging/rtl8188eu/core/rtw_recv.c
@@ -116,9 +116,8 @@ void _rtw_free_recv_priv(struct recv_priv *precvpriv)
 	rtw_free_uc_swdec_pending_queue(padapter);
-	if (precvpriv->pallocated_frame_buf) {
+	if (precvpriv->pallocated_frame_buf)
 		vfree(precvpriv->pallocated_frame_buf);
 	rtw_hal_free_recv_priv(padapter);
@@ -910,9 +909,8 @@ static int sta2ap_data_frame(struct adapter *adapter,
 		process_pwrbit_data(adapter, precv_frame);
-		if ((GetFrameSubType(ptr) & WIFI_QOS_DATA_TYPE) == WIFI_QOS_DATA_TYPE) {
+		if ((GetFrameSubType(ptr) & WIFI_QOS_DATA_TYPE) == WIFI_QOS_DATA_TYPE)
 			process_wmmps_data(adapter, precv_frame);
 		if (GetFrameSubType(ptr) & BIT(6)) {
 			/* No data, will not indicate to upper layer, temporily count it here */
@@ -1527,10 +1525,9 @@ struct recv_frame *recvframe_chk_defrag(struct adapter *padapter,
 		if (pdefrag_q != NULL) {
 			if (fragnum == 0) {
 				/* the first fragment */
-				if (!list_empty(&pdefrag_q->queue)) {
+				if (!list_empty(&pdefrag_q->queue))
 					/* free current defrag_q */
 					rtw_free_recvframe_queue(pdefrag_q, pfree_recv_queue);
 			/* Then enqueue the 0~(n-1) fragment into the defrag_q */
@@ -1646,9 +1643,8 @@ static int amsdu_to_msdu(struct adapter *padapter, struct recv_frame *prframe)
 		a_len -= nSubframe_Length;
 		if (a_len != 0) {
 			padding_len = 4 - ((nSubframe_Length + ETH_HLEN) & (4-1));
-			if (padding_len == 4) {
+			if (padding_len == 4)
 				padding_len = 0;
 			if (a_len < padding_len) {
 				goto exit;
BtrLinux
Privacy Overview
