staging: rtl8188eu: core: Remove casts of pointer to same type
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Casting a pointer to a pointer of the same type is unnecessary, so remove
these unnecessary casts.
This was done with Coccinelle:
type T;
T *ptr;
- (T *)ptr
+ ptr
Signed-off-by: Bhaktipriya Shridhar
drivers/staging/rtl8188eu/core/rtw_recv.c | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_recv.c b/drivers/staging/rtl8188eu/core/rtw_recv.c
index 40b7a30..d3c9ded 100644
--- a/drivers/staging/rtl8188eu/core/rtw_recv.c
+++ b/drivers/staging/rtl8188eu/core/rtw_recv.c
@@ -141,7 +141,7 @@ struct recv_frame *_rtw_alloc_recvframe(struct __queue *pfree_recv_queue)
- return (struct recv_frame *)hdr;
+ return hdr;
struct recv_frame *rtw_alloc_recvframe(struct __queue *pfree_recv_queue)
@@ -240,7 +240,7 @@ void rtw_free_recvframe_queue(struct __queue *pframequeue, struct __queue *pfre
plist = plist->next;
- rtw_free_recvframe((struct recv_frame *)hdr, pfree_recv_queue);
+ rtw_free_recvframe(hdr, pfree_recv_queue);
spin_unlock(&pframequeue->lock);
@@ -1417,7 +1417,7 @@ static struct recv_frame *recvframe_defrag(struct adapter *adapter,
phead = get_list_head(defrag_q);
plist = phead->next;
pfhdr = container_of(plist, struct recv_frame, list);
- prframe = (struct recv_frame *)pfhdr;
+ prframe = pfhdr;
list_del_init(&(prframe->list));
if (curfragnum != pfhdr->attrib.frag_num) {
@@ -1437,7 +1437,7 @@ static struct recv_frame *recvframe_defrag(struct adapter *adapter,
while (phead != plist) {
pnfhdr = container_of(plist, struct recv_frame, list);
- pnextrframe = (struct recv_frame *)pnfhdr;
+ pnextrframe = pnfhdr;
/* check the fragment sequence (2nd ~n fragment frame) */
@@ -1780,7 +1780,7 @@ static int recv_indicatepkts_in_order(struct adapter *padapter, struct recv_reor
/* Check if there is any packet need indicate. */
while (!list_empty(phead)) {
prhdr = container_of(plist, struct recv_frame, list);
- prframe = (struct recv_frame *)prhdr;
+ prframe = prhdr;
pattrib = &prframe->attrib;
if (!SN_LESS(preorder_ctrl->indicate_seq, pattrib->seq_num)) { |
+ return hdr;
+ prframe = pfhdr;
+ prframe = prhdr;
