staging: rtl8187se: use is_broadcast_ether_addr() instead of memcmp()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Using is_broadcast_ether_addr() instead of directly use
memcmp() to determine if the ethernet address is broadcast
address.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
 drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c b/drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c
index 8173240..7c669a2 100644
--- a/drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c
+++ b/drivers/staging/rtl8187se/ieee80211/ieee80211_softmac.c
@@ -21,6 +21,7 @@
 #include <linux/slab.h>
 #include <linux/interrupt.h>
 #include <asm/uaccess.h>
+#include <linux/etherdevice.h>
 #include "dot11d.h"
 u8 rsn_authen_cipher_suite[16][4] = {
@@ -2808,9 +2809,7 @@ static int ieee80211_wpa_set_encryption(struct ieee80211_device *ieee,
 			       param->u.crypt.key_len);
 		return -EINVAL;
-	if (param->sta_addr[0] == 0xff && param->sta_addr[1] == 0xff &&
-	    param->sta_addr[2] == 0xff && param->sta_addr[3] == 0xff &&
-	    param->sta_addr[4] == 0xff && param->sta_addr[5] == 0xff) {
+	if (is_broadcast_ether_addr(param->sta_addr)) {
 		if (param->u.crypt.idx >= WEP_KEYS)
 			return -EINVAL;
 		crypt = &ieee->crypt[param->u.crypt.idx];
BtrLinux
Privacy Overview
