staging: rtl8187se: fix assignment of bool to 0/1
Author: Teodora Baluta <teobaluta@gmail.com>
This patch fixes the following coccinelle warnings:
drivers/staging/rtl8187se/r8180_core.c:2433:1-20: WARNING: Assignment of bool to 0/1
drivers/staging/rtl8187se/r8180_core.c:2275:3-34: WARNING: Assignment  of bool to 0/1
Signed-off-by: Teodora Baluta
Reviewed-by: Rusty Russell
 drivers/staging/rtl8187se/r8180_core.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8187se/r8180_core.c b/drivers/staging/rtl8187se/r8180_core.c
index 55dfd5e..eb98222 100644
--- a/drivers/staging/rtl8187se/r8180_core.c
+++ b/drivers/staging/rtl8187se/r8180_core.c
@@ -2272,7 +2272,7 @@ static void rtl8180_set_channel_map(u8 channel_plan, struct ieee80211_device *ie
 	case COUNTRY_CODE_GLOBAL_DOMAIN:
-			GET_DOT11D_INFO(ieee)->bEnabled = 0;
+			GET_DOT11D_INFO(ieee)->bEnabled = false;
 			Dot11d_Reset(ieee);
 			ieee->bGlobalDomain = true;
 			break;
@@ -2430,7 +2430,7 @@ short rtl8180_init(struct net_device *dev)
 	init_timer(&priv->SwAntennaDiversityTimer);
 	priv->SwAntennaDiversityTimer.data = (unsigned long)dev;
 	priv->SwAntennaDiversityTimer.function = (void *)SwAntennaDiversityTimerCallback;
-	priv->bDigMechanism = 1;
+	priv->bDigMechanism = true;
 	priv->InitialGain = 6;
 	priv->bXtalCalibration = false;
 	priv->XtalCal_Xin = 0;
BtrLinux
Privacy Overview
