Staging: rspiusb: use USB API functions rather than constants
This set of patches introduces calls to the following set of functions:
usb_endpoint_dir_in(epd)
usb_endpoint_dir_out(epd)
usb_endpoint_is_bulk_in(epd)
usb_endpoint_is_bulk_out(epd)
usb_endpoint_is_int_in(epd)
usb_endpoint_is_int_out(epd)
usb_endpoint_num(epd)
usb_endpoint_type(epd)
usb_endpoint_xfer_bulk(epd)
usb_endpoint_xfer_control(epd)
usb_endpoint_xfer_int(epd)
usb_endpoint_xfer_isoc(epd)
In some cases, introducing one of these functions is not possible, and it
just replaces an explicit integer value by one of the following constants:
USB_ENDPOINT_XFER_BULK
USB_ENDPOINT_XFER_CONTROL
USB_ENDPOINT_XFER_INT
USB_ENDPOINT_XFER_ISOC
An extract of the semantic patch that makes these changes is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r1@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) ==
- \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ usb_endpoint_xfer_control(epd)
@r5@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) ==
-  \(USB_DIR_IN\|0x80\))
+ usb_endpoint_dir_in(epd)
@inc@
#include
@depends on !inc && (r1||r5)@
+ #include
  #include
Signed-off-by: Julia Lawall
 drivers/staging/rspiusb/rspiusb.c | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rspiusb/rspiusb.c b/drivers/staging/rspiusb/rspiusb.c
index ca281d6..ecaffb5 100644
--- a/drivers/staging/rspiusb/rspiusb.c
+++ b/drivers/staging/rspiusb/rspiusb.c
@@ -781,9 +781,8 @@ static int piusb_probe(struct usb_interface *interface,
 			dbg("Endpoint[%d]->MaxPacketSize = %d\n", i,
 			    endpoint->wMaxPacketSize);
-		if ((endpoint->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) ==
-		    USB_ENDPOINT_XFER_BULK) {
-			if (endpoint->bEndpointAddress & USB_DIR_IN)
+		if (usb_endpoint_xfer_bulk(endpoint)) {
+			if (usb_endpoint_dir_in(endpoint))
 				pdx->hEP[i] =
 				    usb_rcvbulkpipe(pdx->udev,
 						    endpoint->bEndpointAddress);
BtrLinux
Privacy Overview
