Staging: rdma: Use memdup_user
Author: Ksenija Stanojevic <ksenija.stanojevic@gmail.com>
Use memdup_user when user data is immediately copied into the
allocated region.
Issue found using coccinelle.
Signed-off-by: Ksenija Stanojevic
 drivers/staging/rdma/ipath/ipath_fs.c | 13 +++----------
 1 file changed, 3 insertions(+), 10 deletions(-)
diff --git a/drivers/staging/rdma/ipath/ipath_fs.c b/drivers/staging/rdma/ipath/ipath_fs.c
index 25422a3..796af68 100644
--- a/drivers/staging/rdma/ipath/ipath_fs.c
+++ b/drivers/staging/rdma/ipath/ipath_fs.c
@@ -195,16 +195,9 @@ static ssize_t flash_write(struct file *file, const char __user *buf,
 		goto bail;
-	tmp = kmalloc(count, GFP_KERNEL);
-	if (!tmp) {
-		ret = -ENOMEM;
-		goto bail;
-	if (copy_from_user(tmp, buf, count)) {
-		ret = -EFAULT;
-		goto bail_tmp;
+	tmp = memdup_user(buf, count);
+	if (IS_ERR(tmp))
+		return PTR_ERR(tmp);
 	dd = file_inode(file)->i_private;
 	if (ipath_eeprom_write(dd, pos, tmp, count)) {
BtrLinux
Privacy Overview
