staging: rdma: hfi1: Use setup_timer
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
The function setup_timer combines the initialization of a timer with the
initialization of the timer's function and data fields.
The multiline code for timer initialization is now replaced with function
setup_timer.
This was done with Coccinelle.
@@ expression e1, e2, e3; type T; @@
- init_timer(&e1);
- e1.function = e2;
- e1.data = (T)e3;
+ setup_timer(&e1, e2, (T)e3);
- e1.data = (T)e3;
- e1.function = e2;
- e1.function = e2;
+ setup_timer(&e1, e2, 0);
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rdma/hfi1/verbs.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/verbs.c b/drivers/staging/rdma/hfi1/verbs.c
index 09b8d41..1761686 100644
--- a/drivers/staging/rdma/hfi1/verbs.c
+++ b/drivers/staging/rdma/hfi1/verbs.c
@@ -1926,9 +1926,7 @@ int hfi1_register_ib_device(struct hfi1_devdata *dd)
 	spin_lock_init(&dev->n_qps_lock);
 	spin_lock_init(&dev->n_srqs_lock);
 	spin_lock_init(&dev->n_mcast_grps_lock);
-	init_timer(&dev->mem_timer);
-	dev->mem_timer.function = mem_timer;
-	dev->mem_timer.data = (unsigned long) dev;
+	setup_timer(&dev->mem_timer, mem_timer, (unsigned long)dev);
 	 * The top hfi1_lkey_table_size bits are used to index the
BtrLinux
Privacy Overview
