staging: rdma: hfi1: Replace ALIGN with PAGE_ALIGN
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
mm.h contains a helper function PAGE_ALIGN which aligns the pointer
to the page boundary instead of using ALIGN(expression, PAGE_SIZE)
This change was made with the help of the following Coccinelle
semantic patch:
expression e;
symbol PAGE_SIZE;
- ALIGN(e, PAGE_SIZE)
+ PAGE_ALIGN(e)
- IS_ALIGNED(e, PAGE_SIZE)
+ PAGE_ALIGNED(e)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/rdma/hfi1/init.c      | 8 ++++----
 drivers/staging/rdma/hfi1/user_sdma.c | 3 +--
 2 files changed, 5 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/init.c b/drivers/staging/rdma/hfi1/init.c
index 3107103..02df291 100644
--- a/drivers/staging/rdma/hfi1/init.c
+++ b/drivers/staging/rdma/hfi1/init.c
@@ -735,8 +735,8 @@ int hfi1_init(struct hfi1_devdata *dd, int reinit)
 		ret = lastfail;
 	/* Allocate enough memory for user event notification. */
-	len = ALIGN(dd->chip_rcv_contexts * HFI1_MAX_SHARED_CTXTS *
-		    sizeof(*dd->events), PAGE_SIZE);
+	len = PAGE_ALIGN(dd->chip_rcv_contexts * HFI1_MAX_SHARED_CTXTS *
+			 sizeof(*dd->events));
 	dd->events = vmalloc_user(len);
 	if (!dd->events)
 		dd_dev_err(dd, "Failed to allocate user events page\n");
@@ -1505,8 +1505,8 @@ int hfi1_create_rcvhdrq(struct hfi1_devdata *dd, struct hfi1_ctxtdata *rcd)
 		 * rcvhdrqentsize is in DWs, so we have to convert to bytes
 		 * (* sizeof(u32)).
-		amt = ALIGN(rcd->rcvhdrq_cnt * rcd->rcvhdrqentsize *
-			    sizeof(u32), PAGE_SIZE);
+		amt = PAGE_ALIGN(rcd->rcvhdrq_cnt * rcd->rcvhdrqentsize *
+				 sizeof(u32));
 		gfp_flags = (rcd->ctxt >= dd->first_user_ctxt) ?
 			GFP_USER : GFP_KERNEL;
diff --git a/drivers/staging/rdma/hfi1/user_sdma.c b/drivers/staging/rdma/hfi1/user_sdma.c
index d152126a..9d4f5d6 100644
--- a/drivers/staging/rdma/hfi1/user_sdma.c
+++ b/drivers/staging/rdma/hfi1/user_sdma.c
@@ -413,8 +413,7 @@ int hfi1_user_sdma_alloc_queues(struct hfi1_ctxtdata *uctxt, struct file *fp)
 	if (!cq)
 		goto cq_nomem;
-	memsize = ALIGN(sizeof(*cq->comps) * hfi1_sdma_comp_ring_size,
-			PAGE_SIZE);
+	memsize = PAGE_ALIGN(sizeof(*cq->comps) * hfi1_sdma_comp_ring_size);
 	cq->comps = vmalloc_user(memsize);
 	if (!cq->comps)
 		goto cq_comps_nomem;
BtrLinux
Privacy Overview
