staging: rdma: hfi1: Remove unnecessary pci_set_drvdata()
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Unnecessary pci_set_drvdata() has been removed since the driver
core clears the driver data to NULL after device release or on
probe failure. There is no need to manually clear the device
driver data to NULL.
The Coccinelle semantic patch used to make this change is as follows:
struct pci_dev *pci;
- pci_set_drvdata(pci, NULL);
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/rdma/hfi1/pcie.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/pcie.c b/drivers/staging/rdma/hfi1/pcie.c
index b2f553d8..47ca631 100644
--- a/drivers/staging/rdma/hfi1/pcie.c
+++ b/drivers/staging/rdma/hfi1/pcie.c
@@ -247,8 +247,6 @@ void hfi1_pcie_ddcleanup(struct hfi1_devdata *dd)
 		iounmap(dd->rcvarray_wc);
 	if (dd->piobase)
 		iounmap(dd->piobase);
-	pci_set_drvdata(dd->pcidev, NULL);
BtrLinux
Privacy Overview
