staging: rdma: hfi1: Remove casts of pointer to same type
Author: Bhaktipriya Shridhar <bhaktipriya96@gmail.com>
Casting a pointer to a pointer of the same type is unnecessary, so
remove these unnecessary casts.
This was done with Coccinelle:
type T;
T *ptr;
- (T *)ptr
+ ptr
Signed-off-by: Bhaktipriya Shridhar
 drivers/staging/rdma/hfi1/mad.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/mad.c b/drivers/staging/rdma/hfi1/mad.c
index bee1c0e..ddce918 100644
--- a/drivers/staging/rdma/hfi1/mad.c
+++ b/drivers/staging/rdma/hfi1/mad.c
@@ -2579,7 +2579,7 @@ static int pma_get_opa_datacounters(struct opa_pma_mad *pmp,
 		return reply((struct ib_mad_hdr *)pmp);
-	rsp = (struct _port_dctrs *)&(req->port[0]);
+	rsp = &(req->port[0]);
 	memset(rsp, 0, sizeof(*rsp));
 	rsp->port_number = port;
@@ -2731,7 +2731,7 @@ static int pma_get_opa_porterrors(struct opa_pma_mad *pmp,
-	rsp = (struct _port_ectrs *)&(req->port[0]);
 	ibp = to_iport(ibdev, port_num);
 	ppd = ppd_from_ibp(ibp);
@@ -2779,7 +2779,7 @@ static int pma_get_opa_porterrors(struct opa_pma_mad *pmp,
 	tmp = read_dev_cntr(dd, C_DC_UNC_ERR, CNTR_INVALID_VL);
 	rsp->uncorrectable_errors = tmp < 0x100 ? (tmp & 0xff) : 0xff;
-	vlinfo = (struct _vls_ectrs *)&(rsp->vls[0]);
+	vlinfo = &(rsp->vls[0]);
 	vfi = 0;
 	vl_select_mask = be32_to_cpu(req->vl_select_mask);
 	for_each_set_bit(vl, (unsigned long *)&(vl_select_mask),
@@ -2810,7 +2810,7 @@ static int pma_get_opa_errorinfo(struct opa_pma_mad *pmp,
 	u64 reg;
 	req = (struct opa_port_error_info_msg *)pmp->data;
-	rsp = (struct _port_ei *)&(req->port[0]);
 	num_ports = OPA_AM_NPORT(be32_to_cpu(pmp->mad_hdr.attr_mod));
 	num_pslm = hweight64(be64_to_cpu(req->port_select_mask[3]));
@@ -3051,7 +3051,7 @@ static int pma_set_opa_errorinfo(struct opa_pma_mad *pmp,
 	u32 error_info_select;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
