staging: rdma: hfi1: file_ops: Replace ALIGN with PAGE_ALIGN
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
mm.h contains a helper function PAGE_ALIGN which aligns the pointer
to the page boundary instead of using ALIGN(expression, PAGE_SIZE)
This change was made with the help of the following Coccinelle
semantic patch:
expression e;
symbol PAGE_SIZE;
- ALIGN(e, PAGE_SIZE)
+ PAGE_ALIGN(e)
- IS_ALIGNED(e, PAGE_SIZE)
+ PAGE_ALIGNED(e)
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/rdma/hfi1/file_ops.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/rdma/hfi1/file_ops.c b/drivers/staging/rdma/hfi1/file_ops.c
index d57d549..8b911e8 100644
--- a/drivers/staging/rdma/hfi1/file_ops.c
+++ b/drivers/staging/rdma/hfi1/file_ops.c
@@ -487,8 +487,7 @@ static int hfi1_file_mmap(struct file *fp, struct vm_area_struct *vma)
* Map only the amount allocated to the context, not the
* entire available context's PIO space.
- memlen = ALIGN(uctxt->sc->credits * PIO_BLOCK_SIZE,
- PAGE_SIZE);
+ memlen = PAGE_ALIGN(uctxt->sc->credits * PIO_BLOCK_SIZE);
flags &= ~VM_MAYREAD;
flags |= VM_DONTCOPY | VM_DONTEXPAND;
vma->vm_page_prot = pgprot_writecombine(vma->vm_page_prot);
@@ -638,7 +637,7 @@ static int hfi1_file_mmap(struct file *fp, struct vm_area_struct *vma)
goto done;
memaddr = (u64)cq->comps;
- memlen = ALIGN(sizeof(*cq->comps) * cq->nentries, PAGE_SIZE);
+ memlen = PAGE_ALIGN(sizeof(*cq->comps) * cq->nentries);
flags |= VM_IO | VM_DONTEXPAND;
vmf = 1;
break; |
- PAGE_SIZE);
goto done;
vmf = 1;
break;
