staging: rdma: hfi1: driver: Replace IS_ALIGNED with PAGE_ALIGNED
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
mm.h contains a helper function PAGE_ALIGNED which tests whether
an address is aligned to PAGE_SIZE instead of using
IS_ALIGNED(expression, PAGE_SIZE)
This change was made with the help of the following Coccinelle
semantic patch:
expression e;
symbol PAGE_SIZE;
- ALIGN(e, PAGE_SIZE)
+ PAGE_ALIGN(e)
- IS_ALIGNED(e, PAGE_SIZE)
+ PAGE_ALIGNED(e)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/rdma/hfi1/driver.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/rdma/hfi1/driver.c b/drivers/staging/rdma/hfi1/driver.c
index 3218520..ee50bbf 100644
--- a/drivers/staging/rdma/hfi1/driver.c
+++ b/drivers/staging/rdma/hfi1/driver.c
@@ -246,7 +246,7 @@ static inline void *get_egrbuf(const struct hfi1_ctxtdata *rcd, u64 rhf,
 inline int hfi1_rcvbuf_validate(u32 size, u8 type, u16 *encoded)
-	if (unlikely(!IS_ALIGNED(size, PAGE_SIZE)))
+	if (unlikely(!PAGE_ALIGNED(size)))
 		return 0;
 	if (unlikely(size < MIN_EAGER_BUFFER))
 		return 0;
BtrLinux
Privacy Overview
