staging: panel: use schedule_timeout_interruptible()
Author: Nicholas Mc Guire <hofrat@osadl.org>
API consolidation with coccinelle found:
./drivers/staging/panel/panel.c:782:2-18:
        consolidation with schedule_timeout_*() recommended
This is a 1:1 conversion with respect to schedule_timeout() to the
schedule_timeout_interruptible() helper only - so only an API
consolidation to improve readability. The timeout was being passed
as (ms * HZ + 999) / 1000 but that simply looks wrong - rather than
"manual" converting to jiffies, msecs_to_jiffies which handles all
corner-cases correctly, was used.
Patch was compile tested with x86_64_defconfig + CONFIG_STAGING=y,
CONFIG_PARPORT=m, CONFIG_PANEL=m
Signed-off-by: Nicholas Mc Guire
Acked-by: Willy Tarreau
 drivers/staging/panel/panel.c | 8 +++-----
 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/panel/panel.c b/drivers/staging/panel/panel.c
index 0046ee0..d670494 100644
--- a/drivers/staging/panel/panel.c
+++ b/drivers/staging/panel/panel.c
@@ -775,12 +775,10 @@ static void pin_to_bits(int pin, unsigned char *d_val, unsigned char *c_val)
 /* sleeps that many milliseconds with a reschedule */
 static void long_sleep(int ms)
-	if (in_interrupt()) {
+	if (in_interrupt())
 		mdelay(ms);
-	} else {
-		__set_current_state(TASK_INTERRUPTIBLE);
-		schedule_timeout((ms * HZ + 999) / 1000);
+	else
+		schedule_timeout_interruptible(msecs_to_jiffies(ms));
 /* send a serial byte to the LCD panel. The caller is responsible for locking
BtrLinux
Privacy Overview
