Staging: otus: use USB API functions rather than constants
This set of patches introduces calls to the following set of functions:
usb_endpoint_dir_in(epd)
usb_endpoint_dir_out(epd)
usb_endpoint_is_bulk_in(epd)
usb_endpoint_is_bulk_out(epd)
usb_endpoint_is_int_in(epd)
usb_endpoint_is_int_out(epd)
usb_endpoint_num(epd)
usb_endpoint_type(epd)
usb_endpoint_xfer_bulk(epd)
usb_endpoint_xfer_control(epd)
usb_endpoint_xfer_int(epd)
usb_endpoint_xfer_isoc(epd)
In some cases, introducing one of these functions is not possible, and it
just replaces an explicit integer value by one of the following constants:
USB_ENDPOINT_XFER_BULK
USB_ENDPOINT_XFER_CONTROL
USB_ENDPOINT_XFER_INT
USB_ENDPOINT_XFER_ISOC
An extract of the semantic patch that makes these changes is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r1@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) ==
- \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ usb_endpoint_xfer_control(epd)
@r5@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) ==
-  \(USB_DIR_IN\|0x80\))
+ usb_endpoint_dir_in(epd)
@inc@
#include
@depends on !inc && (r1||r5)@
+ #include
  #include
Signed-off-by: Julia Lawall
 drivers/staging/otus/usbdrv.c | 12 ++++--------
 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/staging/otus/usbdrv.c b/drivers/staging/otus/usbdrv.c
index dfe0707..565a839 100644
--- a/drivers/staging/otus/usbdrv.c
+++ b/drivers/staging/otus/usbdrv.c
@@ -936,30 +936,26 @@ int zfLnxAllocAllUrbs(struct usbdrv_private *macp)
     for (i = 0; i < iface_desc->desc.bNumEndpoints; ++i)
         endpoint = &iface_desc->endpoint[i].desc;
-        if ((endpoint->bEndpointAddress & 0x80) &&
-            ((endpoint->bmAttributes & 3) == 0x02))
+	 if (usb_endpoint_is_bulk_in(endpoint))
             /* we found a bulk in endpoint */
             printk(KERN_ERR "bulk in: wMaxPacketSize = %x\n", le16_to_cpu(endpoint->wMaxPacketSize));
-        if (((endpoint->bEndpointAddress & 0x80) == 0x00) &&
+	 if (usb_endpoint_is_bulk_out(endpoint))
             /* we found a bulk out endpoint */
             printk(KERN_ERR "bulk out: wMaxPacketSize = %x\n", le16_to_cpu(endpoint->wMaxPacketSize));
-            ((endpoint->bmAttributes & 3) == 0x03))
+	 if (usb_endpoint_is_int_in(endpoint))
             /* we found a interrupt in endpoint */
             printk(KERN_ERR "interrupt in: wMaxPacketSize = %x\n", le16_to_cpu(endpoint->wMaxPacketSize));
             printk(KERN_ERR "interrupt in: int_interval = %d\n", endpoint->bInterval);
+	 if (usb_endpoint_is_int_out(endpoint))
             /* we found a interrupt out endpoint */
             printk(KERN_ERR "interrupt out: wMaxPacketSize = %x\n", le16_to_cpu(endpoint->wMaxPacketSize));
BtrLinux
Privacy Overview
