staging: omap-thermal/omap-bandgap.c: adjust duplicate test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive tests to the same location.  There was a previous test on
ret and it has not been updated since then.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
 { ... when forall
   return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
    when != \(XT_GETPAGE(...,y)\|WMI_CMD_BUF(...)\)
 { ... when forall
   return ...; }
Signed-off-by: Julia Lawall
 drivers/staging/omap-thermal/omap-bandgap.c | 2 --
 1 file changed, 2 deletions(-)
diff --git a/drivers/staging/omap-thermal/omap-bandgap.c b/drivers/staging/omap-thermal/omap-bandgap.c
index 8346e345..89f7180 100644
--- a/drivers/staging/omap-thermal/omap-bandgap.c
+++ b/drivers/staging/omap-thermal/omap-bandgap.c
@@ -568,8 +568,6 @@ int omap_bandgap_read_update_interval(struct omap_bandgap *bg_ptr, int id,
 	tsr = bg_ptr->conf->sensors[id].registers;
 	time = omap_bandgap_readl(bg_ptr, tsr->bgap_counter);
-	if (ret)
-		return ret;
 	time = (time & tsr->counter_mask) >> __ffs(tsr->counter_mask);
 	time = time * 1000 / bg_ptr->clk_rate;
BtrLinux
Privacy Overview
