Staging: nvec: use !x instead of x == NULL
Author: Somya Anand <somyaanand214@gmail.com>
Functions like devm_kzalloc, kmalloc_array, devm_ioremap,
usb_alloc_urb, alloc_netdev return NULL as a return value on failure.
Generally, When NULL represents failure, !x is commonly used.
This patch cleans up the tests on the results of these functions, thereby
using !x instead of x == NULL or NULL == x. This is done via following
coccinelle script:
@prob_7@
identifier x;
statement S;
x = devm_kzalloc(...);
x = usb_alloc_urb(...);
x = kmalloc_array(...);
x = devm_ioremap(...);
x = alloc_netdev(...);
- if(NULL == x)
+ if(!x)
S
Further we have used isomorphism characteristics of coccinelle to
indicate x == NULL and NULL == x are equivalent. This is done via
following iso script.
Expression
@ is_null @ expression X; @@
X == NULL <=> NULL == X
Signed-off-by: Somya Anand
drivers/staging/nvec/nvec.c | 2 +-
drivers/staging/nvec/nvec_paz00.c | 2 +-
drivers/staging/nvec/nvec_power.c | 2 +-
drivers/staging/nvec/nvec_ps2.c | 2 +-
4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/nvec/nvec.c b/drivers/staging/nvec/nvec.c
index 5868ebb..1bdc8d0 100644
--- a/drivers/staging/nvec/nvec.c
+++ b/drivers/staging/nvec/nvec.c
@@ -803,7 +803,7 @@ static int tegra_nvec_probe(struct platform_device *pdev)
nvec = devm_kzalloc(&pdev->dev, sizeof(struct nvec_chip), GFP_KERNEL);
- if (nvec == NULL)
+ if (!nvec)
return -ENOMEM;
platform_set_drvdata(pdev, nvec);
diff --git a/drivers/staging/nvec/nvec_paz00.c b/drivers/staging/nvec/nvec_paz00.c
index f0cea0e..68146bf 100644
--- a/drivers/staging/nvec/nvec_paz00.c
+++ b/drivers/staging/nvec/nvec_paz00.c
@@ -51,7 +51,7 @@ static int nvec_paz00_probe(struct platform_device *pdev)
int ret = 0;
led = devm_kzalloc(&pdev->dev, sizeof(*led), GFP_KERNEL);
- if (led == NULL)
+ if (!led)
return -ENOMEM;
led->cdev.max_brightness = NVEC_LED_MAX;
diff --git a/drivers/staging/nvec/nvec_power.c b/drivers/staging/nvec/nvec_power.c
index 6a1459d..3621b66 100644
--- a/drivers/staging/nvec/nvec_power.c
+++ b/drivers/staging/nvec/nvec_power.c
@@ -378,7 +378,7 @@ static int nvec_power_probe(struct platform_device *pdev)
struct nvec_chip *nvec = dev_get_drvdata(pdev->dev.parent);
power = devm_kzalloc(&pdev->dev, sizeof(struct nvec_power), GFP_NOWAIT);
- if (power == NULL)
+ if (!power)
return -ENOMEM;
dev_set_drvdata(&pdev->dev, power);
diff --git a/drivers/staging/nvec/nvec_ps2.c b/drivers/staging/nvec/nvec_ps2.c
index 4fd63c2..6ebbc82 100644
--- a/drivers/staging/nvec/nvec_ps2.c
+++ b/drivers/staging/nvec/nvec_ps2.c
@@ -109,7 +109,7 @@ static int nvec_mouse_probe(struct platform_device *pdev)
char mouse_reset[] = { NVEC_PS2, SEND_COMMAND, PSMOUSE_RST, 3 };
ser_dev = devm_kzalloc(&pdev->dev, sizeof(struct serio), GFP_KERNEL);
- if (ser_dev == NULL)
+ if (!ser_dev)
return -ENOMEM;
ser_dev->id.type = SERIO_PS_PSTHRU; |
- if (nvec == NULL)
+ if (!nvec)
return -ENOMEM;
int ret = 0;
- if (led == NULL)
+ if (!led)
return -ENOMEM;
+ if (!power)
return -ENOMEM;
+ if (!ser_dev)
return -ENOMEM;
