staging: netlogic: Simplify use of devm_ioremap_resource
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to
devm_ioremap_resource.
The Coccinelle semantic patch that makes this change is as follows:
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
e = devm_ioremap_resource(e1, res);
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/netlogic/xlr_net.c | 7 -------
1 file changed, 7 deletions(-)
diff --git a/drivers/staging/netlogic/xlr_net.c b/drivers/staging/netlogic/xlr_net.c
index 0015847..3a6de47 100644
--- a/drivers/staging/netlogic/xlr_net.c
+++ b/drivers/staging/netlogic/xlr_net.c
@@ -1038,13 +1038,6 @@ static int xlr_net_probe(struct platform_device *pdev)
priv->port_id = (pdev->id * 4) + port;
priv->nd = (struct xlr_net_data *)pdev->dev.platform_data;
res = platform_get_resource(pdev, IORESOURCE_MEM, port);
- pr_err("No memory resource for MAC %d\n",
- priv->port_id);
- err = -ENODEV;
- goto err_gmac;
priv->base_addr = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(priv->base_addr)) {
err = PTR_ERR(priv->base_addr); |
- priv->port_id);
- err = -ENODEV;
- goto err_gmac;
