staging: netlogic: Replace pr_* with netdev_*
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Replace generic pr_info and pr_err with netdev_info and netdev_err
respectively for net devices.
Found using Coccinelle. The semantic patch used to find this is as
follows:
expression e;
identifier f,i;
position p;
f(...,struct net_device *i,...) {
-  pr_debug@p (e)
+  netdev_dbg(i, e)
- pr_err@p (e)
+ netdev_err(i, e)
- pr_info@p (e)
+ netdev_info(i, e)
expression e;
identifier f,i;
position p;
f(...) {
struct net_device *n;
-  pr_debug@p (e)
+  netdev_dbg(n, e)
- pr_err@p (e)
+ netdev_err(n, e)
- pr_info@p (e)
+ netdev_info(n, e)
@a@
identifier s,x;
struct s {
struct net_device *x;
@b depends on a@
expression e;
identifier f,i,a.s,a.x;
position p;
f ( ..., struct s *i, ...) {
-  pr_debug@p (e)
+  netdev_dbg(i->x, e)
- pr_err@p (e)
+ netdev_err(i->x, e)
- pr_info@p (e)
+ netdev_info(i->x, e)
@c depends on a@
expression e;
position p;
f (...) {
struct s *i = ...;
-  pr_debug@p (e)
- pr_err@p (e)
- pr_info@p (e)
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/netlogic/xlr_net.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/netlogic/xlr_net.c b/drivers/staging/netlogic/xlr_net.c
index 59deeee..b0877a8 100644
--- a/drivers/staging/netlogic/xlr_net.c
+++ b/drivers/staging/netlogic/xlr_net.c
@@ -99,7 +99,7 @@ static int send_to_rfr_fifo(struct xlr_net_priv *priv, void *addr)
 			return 0;
 	} while (++num_try < 10000);
-	pr_err("Send to RFR failed in RX path\n");
+	netdev_err(priv->ndev, "Send to RFR failed in RX path\n");
 	return ret;
@@ -209,12 +209,12 @@ static int xlr_net_fill_rx_ring(struct net_device *ndev)
 	for (i = 0; i < MAX_FRIN_SPILL / 4; i++) {
 		skb_data = xlr_alloc_skb();
 		if (!skb_data) {
-			pr_err("SKB allocation failed\n");
+			netdev_err(ndev, "SKB allocation failed\n");
 			return -ENOMEM;
 		send_to_rfr_fifo(priv, skb_data);
-	pr_info("Rx ring setup done\n");
+	netdev_info(ndev, "Rx ring setup done\n");
 	return 0;
BtrLinux
Privacy Overview
