staging: mt29f_spinand: remove pointer to pointer cast in function argument
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes unnecessary pointer to pointer cast on function arguments.
It is worth noting that buf is already a u8 pointer.
Issue detected and resolved using the following coccinelle script:
expression e;
type t;
identifier f;
f(...,
-(t *)
e
Signed-off-by: Aya Mahfouz
 drivers/staging/mt29f_spinand/mt29f_spinand.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/mt29f_spinand/mt29f_spinand.c b/drivers/staging/mt29f_spinand/mt29f_spinand.c
index 3b191fc..7285c64 100644
--- a/drivers/staging/mt29f_spinand/mt29f_spinand.c
+++ b/drivers/staging/mt29f_spinand/mt29f_spinand.c
@@ -770,7 +770,7 @@ static void spinand_cmdfunc(struct mtd_info *mtd, unsigned int command,
 		break;
 	case NAND_CMD_READID:
 		state->buf_ptr = 0;
-		spinand_read_id(info->spi, (u8 *)state->buf);
+		spinand_read_id(info->spi, state->buf);
 		break;
 	case NAND_CMD_PARAM:
 		state->buf_ptr = 0;
BtrLinux
Privacy Overview
