staging: most: Delete an unnecessary check before the function call “module_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The module_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
 drivers/staging/most/mostcore/core.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/most/mostcore/core.c b/drivers/staging/most/mostcore/core.c
index 19852ca..ed1ed25 100644
--- a/drivers/staging/most/mostcore/core.c
+++ b/drivers/staging/most/mostcore/core.c
@@ -1587,8 +1587,7 @@ out:
 	return 0;
 error:
-	if (iface->mod)
-		module_put(iface->mod);
+	module_put(iface->mod);
 	modref--;
 	mutex_unlock(&c->start_mutex);
 	return ret;
BtrLinux
Privacy Overview
