staging: most: compress return logic into one line
Author: Eva Rachel Retuya <eraretuya@gmail.com>
Eliminate local variable 'ret' and modify return statement to contain
the value being returned directly instead of assigning it first to 'ret'
and returning this variable.
Coccinelle semantic patch used:
@@ expression e, ret; @@
-ret =
+return
	e;
-return ret;
Signed-off-by: Eva Rachel Retuya
 drivers/staging/most/hdm-dim2/dim2_sysfs.c | 4 +---
 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/most/hdm-dim2/dim2_sysfs.c b/drivers/staging/most/hdm-dim2/dim2_sysfs.c
index c5b10c7..2b28e4a 100644
--- a/drivers/staging/most/hdm-dim2/dim2_sysfs.c
+++ b/drivers/staging/most/hdm-dim2/dim2_sysfs.c
@@ -63,7 +63,6 @@ static ssize_t bus_kobj_attr_show(struct kobject *kobj, struct attribute *attr,
 static ssize_t bus_kobj_attr_store(struct kobject *kobj, struct attribute *attr,
 				   const char *buf, size_t count)
-	ssize_t ret;
 	struct medialb_bus *bus =
 		container_of(kobj, struct medialb_bus, kobj_group);
 	struct bus_attr *xattr = container_of(attr, struct bus_attr, attr);
@@ -71,8 +70,7 @@ static ssize_t bus_kobj_attr_store(struct kobject *kobj, struct attribute *attr,
 	if (!xattr->store)
 		return -EIO;
-	ret = xattr->store(bus, buf, count);
-	return ret;
+	return xattr->store(bus, buf, count);
 static struct sysfs_ops const bus_kobj_sysfs_ops = {
BtrLinux
Privacy Overview
