Staging: meilhaus: Correct use of ! and &
ME_IO_SINGLE_TYPE_WRITE_NONBLOCKING and ME_IO_STREAM_CONFIG_WRAPAROUND both
hanve 0 as the rightmost bit, and thus eg
!flags & ME_IO_SINGLE_TYPE_WRITE_NONBLOCKING is always 0.
I assume that !(flags & ME_IO_SINGLE_TYPE_WRITE_NONBLOCKING) and
!(flags & ME_IO_STREAM_CONFIG_WRAPAROUND) were intended.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E; constant C; @@
  !E & !C
- !E & C
+ !(E & C)
Signed-off-by: Julia Lawall
 drivers/staging/meilhaus/me1600_ao.c | 4 +++-
 drivers/staging/meilhaus/me4600_ao.c | 2 +-
 drivers/staging/meilhaus/me6000_ao.c | 2 +-
 3 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/meilhaus/me1600_ao.c b/drivers/staging/meilhaus/me1600_ao.c
index d127c6b..52b3b03 100644
--- a/drivers/staging/meilhaus/me1600_ao.c
+++ b/drivers/staging/meilhaus/me1600_ao.c
@@ -756,7 +756,9 @@ static int me1600_ao_io_single_write(me_subdevice_t * subdevice,
 	queue_delayed_work(instance->me1600_workqueue,
 			   &instance->ao_control_task, 1);
-	if ((!flags & ME_IO_SINGLE_TYPE_WRITE_NONBLOCKING) && ((instance->ao_regs_shadows)->trigger & instance->ao_idx)) {	//Blocking mode. Wait for software trigger.
+	if ((!(flags & ME_IO_SINGLE_TYPE_WRITE_NONBLOCKING)) &&
+	    ((instance->ao_regs_shadows)->trigger & instance->ao_idx)) {
+		/* Blocking mode. Wait for software trigger. */
 		if (time_out) {
 			delay = (time_out * HZ) / 1000;
 			if (delay == 0)
diff --git a/drivers/staging/meilhaus/me4600_ao.c b/drivers/staging/meilhaus/me4600_ao.c
index e2bec82..2571caf 100644
--- a/drivers/staging/meilhaus/me4600_ao.c
+++ b/drivers/staging/meilhaus/me4600_ao.c
@@ -1025,7 +1025,7 @@ static int me4600_ao_io_stream_config(me_subdevice_t * subdevice,
 	if (flags & ME_IO_STREAM_CONFIG_HARDWARE_ONLY) {
-		if (!flags & ME_IO_STREAM_CONFIG_WRAPAROUND) {
+		if (!(flags & ME_IO_STREAM_CONFIG_WRAPAROUND)) {
 			PERROR
 			    ("Hardware ME_IO_STREAM_CONFIG_HARDWARE_ONLY has to be with ME_IO_STREAM_CONFIG_WRAPAROUND.\n");
 			return ME_ERRNO_INVALID_FLAGS;
diff --git a/drivers/staging/meilhaus/me6000_ao.c b/drivers/staging/meilhaus/me6000_ao.c
index 94f0123..e1c94cb 100644
--- a/drivers/staging/meilhaus/me6000_ao.c
+++ b/drivers/staging/meilhaus/me6000_ao.c
@@ -1063,7 +1063,7 @@ static int me6000_ao_io_stream_config(me_subdevice_t * subdevice,
 			PERROR
 			return ME_ERRNO_INVALID_FLAGS; |
 		if (time_out) {
 			if (delay == 0)
 			PERROR
 			PERROR
