staging: media: Use kcalloc instead of kzalloc
Author: Navya Sri Nizamkari <navyasri.tech@gmail.com>
This patch uses kcalloc instead of kzalloc function.
A coccinelle script was used to make this change.
Signed-off-by: Navya Sri Nizamkari
 drivers/staging/media/bcm2048/radio-bcm2048.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/media/bcm2048/radio-bcm2048.c b/drivers/staging/media/bcm2048/radio-bcm2048.c
index 116251b..fd8de76 100644
--- a/drivers/staging/media/bcm2048/radio-bcm2048.c
+++ b/drivers/staging/media/bcm2048/radio-bcm2048.c
@@ -1792,7 +1792,7 @@ static int bcm2048_get_rds_data(struct bcm2048_device *bdev, char *data)
 		goto unlock;
-	data_buffer = kzalloc(BCM2048_MAX_RDS_RADIO_TEXT*5, GFP_KERNEL);
+	data_buffer = kcalloc(BCM2048_MAX_RDS_RADIO_TEXT, 5, GFP_KERNEL);
 	if (!data_buffer) {
 		err = -ENOMEM;
 		goto unlock;
BtrLinux
Privacy Overview
