staging: media: omap1: Replace clk_get with devm_clk_get
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
devm_clk_get allocated resources get released when a driver detaches.
Replace clk_get with devm_clk_get and remove corresponding data
releasing function clk_put from probe and remove functions of a
platform device. Also remove an unnecessary label.
This change was made with the help of the following Coccinelle
semantic patch:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
.probe = probefn,
.remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
e =
- clk_get
+ devm_clk_get
?- clk_put(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
?- clk_put(...);
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/media/omap1/omap1_camera.c | 15 ++++-----------
1 file changed, 4 insertions(+), 11 deletions(-)
diff --git a/drivers/staging/media/omap1/omap1_camera.c b/drivers/staging/media/omap1/omap1_camera.c
index bd721e3..bd00180 100644
--- a/drivers/staging/media/omap1/omap1_camera.c
+++ b/drivers/staging/media/omap1/omap1_camera.c
@@ -1576,17 +1576,14 @@ static int omap1_cam_probe(struct platform_device *pdev)
goto exit;
- clk = clk_get(&pdev->dev, "armper_ck");
- if (IS_ERR(clk)) {
- err = PTR_ERR(clk);
- goto exit;
+ clk = devm_clk_get(&pdev->dev, "armper_ck");
+ if (IS_ERR(clk))
+ return PTR_ERR(clk);
pcdev = kzalloc(sizeof(*pcdev) + resource_size(res), GFP_KERNEL);
if (!pcdev) {
dev_err(&pdev->dev, "Could not allocate pcdev\n");
- err = -ENOMEM;
- goto exit_put_clk;
+ return -ENOMEM;
pcdev->res = res;
@@ -1685,8 +1682,6 @@ exit_release:
release_mem_region(res->start, resource_size(res));
exit_kfree:
kfree(pcdev);
-exit_put_clk:
- clk_put(clk);
exit:
return err;
@@ -1709,8 +1704,6 @@ static int omap1_cam_remove(struct platform_device *pdev)
res = pcdev->res;
- clk_put(pcdev->clk);
kfree(pcdev);
dev_info(&pdev->dev, "OMAP1 Camera Interface driver unloaded\n"); |
goto exit;
- goto exit;
+ if (IS_ERR(clk))
if (!pcdev) {
- err = -ENOMEM;
+ return -ENOMEM;
pcdev->res = res;
exit_kfree:
kfree(pcdev);
-exit_put_clk:
- clk_put(clk);
exit:
return err;
res = pcdev->res;
kfree(pcdev);
