Staging: media: lirc: Merge two lines and remove unused variable
Author: Mahati Chamarthy <mahati.chamarthy@gmail.com>
This patch merges an assignment with an immediately following return of
the assigned variable. It also removes a variable that becomes unused due to this transformation.
The following Coccinelle semantic patch was used to make this transformation:
@r@
identifier ret;
identifier f;
-ret =
+return
f(...);
-return ret;
identifier r.ret;
expression e1;
type t;
-t ret = e1;
-t ret;
... when != ret
when strict
Signed-off-by: Mahati Chamarthy
Acked-by: Julia Lawall
drivers/staging/media/lirc/lirc_bt829.c | 4 +---
1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/drivers/staging/media/lirc/lirc_bt829.c b/drivers/staging/media/lirc/lirc_bt829.c
index 3b52f86..4c806ba 100644
--- a/drivers/staging/media/lirc/lirc_bt829.c
+++ b/drivers/staging/media/lirc/lirc_bt829.c
@@ -387,11 +387,9 @@ static unsigned char do_get_bits(void)
static unsigned int read_index(unsigned char index)
unsigned char __iomem *addr;
- unsigned int value;
/* addr = pci_addr_lin + DATA_PCI_OFF + ((index & 0xFF) << 2); */
addr = pci_addr_lin + ((index & 0xFF) << 2);
- value = readl(addr);
- return value;
+ return readl(addr);
static void write_index(unsigned char index, unsigned int reg_val) |
- return value;
