staging: media: davinci_vpfe: remove unnecessary ret variable
Author: Thaissa Falbo <thaissa.falbo@gmail.com>
Simplified return of funcions by removing assignment of ret variable.
Coccinelle script used:
local idexpression ret;
expression e;
- ret = e;
- if(ret)
-       return ret;
+ if(e)
+       return e;
expression e;
- ret = e;
- return ret;
+ return e;
expression e;
- ret = e;
- if(ret){
+ if(e){
        ... when != ret
-       return ret;
+       return e;
type T; identifier i;
- T i;
... when != i
Signed-off-by: Thaissa Falbo
 drivers/staging/media/davinci_vpfe/vpfe_video.c | 54 +++++++++----------------
 1 file changed, 20 insertions(+), 34 deletions(-)
diff --git a/drivers/staging/media/davinci_vpfe/vpfe_video.c b/drivers/staging/media/davinci_vpfe/vpfe_video.c
index 7f0e423..0a65405 100644
--- a/drivers/staging/media/davinci_vpfe/vpfe_video.c
+++ b/drivers/staging/media/davinci_vpfe/vpfe_video.c
@@ -172,11 +172,9 @@ static int vpfe_prepare_pipeline(struct vpfe_video_device *video)
 static int vpfe_update_pipe_state(struct vpfe_video_device *video)
 	struct vpfe_pipeline *pipe = &video->pipe;
-	int ret;
-	ret = vpfe_prepare_pipeline(video);
-	if (ret)
-		return ret;
+	if (vpfe_prepare_pipeline(video))
+		return vpfe_prepare_pipeline(video);
 	 * Find out if there is any input video
@@ -184,10 +182,9 @@ static int vpfe_update_pipe_state(struct vpfe_video_device *video)
 	if (pipe->input_num == 0) {
 		pipe->state = VPFE_PIPELINE_STREAM_CONTINUOUS;
-		ret = vpfe_update_current_ext_subdev(video);
-		if (ret) {
+		if (vpfe_update_current_ext_subdev(video)) {
 			pr_err("Invalid external subdev\n");
-			return ret;
+			return vpfe_update_current_ext_subdev(video);
 	} else {
 		pipe->state = VPFE_PIPELINE_STREAM_SINGLESHOT;
@@ -670,7 +667,6 @@ static int vpfe_enum_fmt(struct file *file, void  *priv,
 	struct v4l2_subdev *subdev;
 	struct v4l2_format format;
 	struct media_pad *remote;
-	int ret;
 	v4l2_dbg(1, debug, &vpfe_dev->v4l2_dev, "vpfe_enum_fmt\n");
@@ -699,11 +695,10 @@ static int vpfe_enum_fmt(struct file *file, void  *priv,
 	sd_fmt.pad = remote->index;
 	sd_fmt.which = V4L2_SUBDEV_FORMAT_ACTIVE;
 	/* get output format of remote subdev */
-	ret = v4l2_subdev_call(subdev, pad, get_fmt, NULL, &sd_fmt);
-	if (ret) {
+	if (v4l2_subdev_call(subdev, pad, get_fmt, NULL, &sd_fmt)) {
 		v4l2_err(&vpfe_dev->v4l2_dev,
 			 "invalid remote subdev for video node\n");
-		return ret;
+		return v4l2_subdev_call(subdev, pad, get_fmt, NULL, &sd_fmt);
 	/* convert to pix format */
 	mbus.code = sd_fmt.format.code;
@@ -730,7 +725,6 @@ static int vpfe_s_fmt(struct file *file, void *priv,
 	struct vpfe_video_device *video = video_drvdata(file);
 	struct vpfe_device *vpfe_dev = video->vpfe_dev;
-	int ret;
 	v4l2_dbg(1, debug, &vpfe_dev->v4l2_dev, "vpfe_s_fmt\n");
 	/* If streaming is started, return error */
@@ -739,9 +733,8 @@ static int vpfe_s_fmt(struct file *file, void *priv,
 		return -EBUSY;
 	/* get adjacent subdev's output pad format */
-	ret = __vpfe_video_get_format(video, &format);
-	if (ret)
-		return ret;
+	if (__vpfe_video_get_format(video, &format))
+		return __vpfe_video_get_format(video, &format);
 	*fmt = format;
 	video->fmt = *fmt;
 	return 0;
@@ -764,13 +757,11 @@ static int vpfe_try_fmt(struct file *file, void *priv,
-	int ret;
 	v4l2_dbg(1, debug, &vpfe_dev->v4l2_dev, "vpfe_try_fmt\n");
-	if (ret)
-		return ret;
 	*fmt = format;
 	return 0;
@@ -847,9 +838,8 @@ static int vpfe_s_input(struct file *file, void *priv, unsigned int index)
 	v4l2_dbg(1, debug, &vpfe_dev->v4l2_dev, "vpfe_s_input\n");
-	ret = mutex_lock_interruptible(&video->lock);
-	if (ret)
-		return ret;
+	if (mutex_lock_interruptible(&video->lock))
+		return mutex_lock_interruptible(&video->lock);
 	 * If streaming is started return device busy
 	 * error
@@ -950,9 +940,8 @@ static int vpfe_s_std(struct file *file, void *priv, v4l2_std_id std_id)
 	v4l2_dbg(1, debug, &vpfe_dev->v4l2_dev, "vpfe_s_std\n");
 	/* Call decoder driver function to set the standard */
-	if (ret)
-		return ret;
 	sdinfo = video->current_ext_subdev;
 	/* If streaming is started, return device busy error */
 	if (video->started) {
@@ -1338,9 +1327,8 @@ static int vpfe_reqbufs(struct file *file, void *priv,
 		return -EINVAL;
-	if (ret)
-		return ret;
 	if (video->io_usrs != 0) {
 		v4l2_err(&vpfe_dev->v4l2_dev, "Only one IO user allowed\n");
@@ -1366,11 +1354,10 @@ static int vpfe_reqbufs(struct file *file, void *priv,
 	q->buf_struct_size = sizeof(struct vpfe_cap_buffer);
 	q->timestamp_flags = V4L2_BUF_FLAG_TIMESTAMP_MONOTONIC;
-	ret = vb2_queue_init(q);
-	if (ret) {
+	if (vb2_queue_init(q)) {
 		v4l2_err(&vpfe_dev->v4l2_dev, "vb2_queue_init() failed\n");
 		vb2_dma_contig_cleanup_ctx(vpfe_dev->pdev);
-		return ret;
+		return vb2_queue_init(q);
 	fh->io_allowed = 1;
@@ -1546,9 +1533,8 @@ static int vpfe_streamoff(struct file *file, void *priv,
 		return -EINVAL;
-	if (ret)
-		return ret;
 	vpfe_stop_capture(video);
 	ret = vb2_streamoff(&video->buffer_queue, buf_type);
BtrLinux
Privacy Overview
