staging: lustre: use ERR_CAST() function
Author: Laurent Navet <laurent.navet@gmail.com>
use ERR_CAST() function instead of ERR_PTR() and PTR_ERR()
found using coccinelle and err_cast.cocci
Signed-off-by: Laurent Navet
 drivers/staging/lustre/lustre/llite/llite_nfs.c        | 2 +-
 drivers/staging/lustre/lustre/llite/rw.c               | 2 +-
 drivers/staging/lustre/lustre/obdclass/local_storage.c | 4 ++--
 3 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/llite/llite_nfs.c b/drivers/staging/lustre/lustre/llite/llite_nfs.c
index b830004..32362ec 100644
--- a/drivers/staging/lustre/lustre/llite/llite_nfs.c
+++ b/drivers/staging/lustre/lustre/llite/llite_nfs.c
@@ -147,7 +147,7 @@ ll_iget_for_nfs(struct super_block *sb, struct lu_fid *fid, struct lu_fid *paren
 	inode = search_inode_for_lustre(sb, fid);
 	if (IS_ERR(inode))
-		RETURN(ERR_PTR(PTR_ERR(inode)));
+		RETURN(ERR_CAST(inode));
 	if (is_bad_inode(inode)) {
 		/* we didn't find the right inode.. */
diff --git a/drivers/staging/lustre/lustre/llite/rw.c b/drivers/staging/lustre/lustre/llite/rw.c
index f48766e..43b5f0d2 100644
--- a/drivers/staging/lustre/lustre/llite/rw.c
+++ b/drivers/staging/lustre/lustre/llite/rw.c
@@ -110,7 +110,7 @@ static struct ll_cl_context *ll_cl_init(struct file *file,
 	env = cl_env_get(&refcheck);
 	if (IS_ERR(env))
-		return ERR_PTR(PTR_ERR(env));
+		return ERR_CAST(env);
 	lcc = &vvp_env_info(env)->vti_io_ctx;
 	memset(lcc, 0, sizeof(*lcc));
diff --git a/drivers/staging/lustre/lustre/obdclass/local_storage.c b/drivers/staging/lustre/lustre/obdclass/local_storage.c
index 3be35a8..e1db7ab 100644
--- a/drivers/staging/lustre/lustre/obdclass/local_storage.c
+++ b/drivers/staging/lustre/lustre/obdclass/local_storage.c
@@ -443,7 +443,7 @@ struct dt_object *local_file_find_or_create_with_fid(const struct lu_env *env,
 		ls = ls_device_get(dt);
 		if (IS_ERR(ls)) {
-			dto = ERR_PTR(PTR_ERR(ls));
+			dto = ERR_CAST(ls);
 		} else {
 			/* create the object */
 			dti->dti_attr.la_valid	= LA_MODE;
@@ -537,7 +537,7 @@ local_index_find_or_create_with_fid(const struct lu_env *env,
 		if (IS_ERR(ls)) {
 		} else {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
