Staging: lustre: Remove typedef ldlm_ns_hash_def_t
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
The linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
ldlm_ns_hash_def_t. Also, the name of the struct is changed to drop
the _t, to make the name look less typedef-like.
This is done using Coccinelle. Semantic patch used to detect this
case is as follows:
@tn1@
type td;
typedef struct { ... } td;
@script:python tf@
td << tn1.td;
tdres;
coccinelle.tdres = td;
type tn1.td;
identifier tf.tdres;
-typedef
struct
+ tdres
-td
type tn1.td;
-td
+ struct tdres
Signed-off-by: Vaishali Thakkar
Acked-by: Arnd Bergmann
drivers/staging/lustre/lustre/ldlm/ldlm_resource.c | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c b/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c
index a785b7a..8b20a83 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_resource.c
@@ -501,7 +501,7 @@ cfs_hash_ops_t ldlm_ns_fid_hash_ops = {
.hs_put = ldlm_res_hop_put
-typedef struct {
+struct ldlm_ns_hash_def {
ldlm_ns_type_t nsd_type;
/** hash bucket bits */
unsigned nsd_bkt_bits;
@@ -509,9 +509,9 @@ typedef struct {
unsigned nsd_all_bits;
/** hash operations */
cfs_hash_ops_t *nsd_hops;
-} ldlm_ns_hash_def_t;
-ldlm_ns_hash_def_t ldlm_ns_hash_defs[] = {
+struct ldlm_ns_hash_def ldlm_ns_hash_defs[] = {
.nsd_type = LDLM_NS_TYPE_MDC,
.nsd_bkt_bits = 11,
@@ -563,7 +563,7 @@ struct ldlm_namespace *ldlm_namespace_new(struct obd_device *obd, char *name,
struct ldlm_namespace *ns = NULL;
struct ldlm_ns_bucket *nsb;
- ldlm_ns_hash_def_t *nsd;
+ struct ldlm_ns_hash_def *nsd;
struct cfs_hash_bd bd;
int idx;
int rc; |
-typedef struct {
.nsd_bkt_bits = 11,
int idx;
int rc;
