Staging: lustre: Remove parentheses around right side an assignment
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
Parentheses are not needed around the right hand side of an assignment.
This patch remove parenthese of such occurenses. Issue was detected and
solved using the following coccinelle script:
@rule1@
identifier x, y, z;
expression E1, E2;
x = (y == z);
x = (E1 == E2);
 x =
Signed-off-by: Haneen Mohammed
 drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c         | 2 +-
 drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c         | 4 ++--
 drivers/staging/lustre/lnet/klnds/socklnd/socklnd_cb.c      | 4 ++--
 drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c             | 2 +-
 drivers/staging/lustre/lustre/ldlm/ldlm_request.c           | 2 +-
 drivers/staging/lustre/lustre/libcfs/debug.c                | 2 +-
 drivers/staging/lustre/lustre/llite/file.c                  | 2 +-
 drivers/staging/lustre/lustre/llite/lloop.c                 | 2 +-
 drivers/staging/lustre/lustre/llite/rw.c                    | 2 +-
 drivers/staging/lustre/lustre/lov/lov_obd.c                 | 4 ++--
 drivers/staging/lustre/lustre/obdclass/genops.c             | 2 +-
 drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c | 2 +-
 drivers/staging/lustre/lustre/osc/osc_io.c                  | 2 +-
 13 files changed, 16 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c
index 109f44c..2f2f71c 100644
--- a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c
+++ b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd.c
@@ -2972,7 +2972,7 @@ kiblnd_start_schedulers(struct kib_sched_info *sched)
 	} else {
 		LASSERT(sched->ibs_nthreads <= sched->ibs_nthreads_max);
 		/* increase one thread if there is new interface */
-		nthrs = (sched->ibs_nthreads < sched->ibs_nthreads_max);
+		nthrs = sched->ibs_nthreads < sched->ibs_nthreads_max;
 	for (i = 0; i < nthrs; i++) {
diff --git a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c
index f815bb8..7586b7e 100644
--- a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c
+++ b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd.c
@@ -722,7 +722,7 @@ ksocknal_match_peerip(ksock_interface_t *iface, __u32 *ips, int nips)
 		if (ips[i] == 0)
 			continue;
-		this_xor = (ips[i] ^ iface->ksni_ipaddr);
+		this_xor = ips[i] ^ iface->ksni_ipaddr;
 		this_netmatch = ((this_xor & iface->ksni_netmask) == 0) ? 1 : 0;
 		if (!(best < 0 ||
@@ -809,7 +809,7 @@ ksocknal_select_ips(ksock_peer_t *peer, __u32 *peerips, int n_peerips)
 					continue;
 				k = ksocknal_match_peerip(iface, peerips, n_peerips);
-				xor = (ip ^ peerips[k]);
+				xor = ip ^ peerips[k];
 				this_netmatch = ((xor & iface->ksni_netmask) == 0) ? 1 : 0;
 				if (!(best_iface == NULL ||
diff --git a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_cb.c b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_cb.c
index 92760fe..fa7ad88 100644
--- a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_cb.c
+++ b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_cb.c
@@ -1374,9 +1374,9 @@ ksocknal_sched_cansleep(ksock_sched_t *sched)
 	spin_lock_bh(&sched->kss_lock);
-	rc = (!ksocknal_data.ksnd_shuttingdown &&
+	rc = !ksocknal_data.ksnd_shuttingdown &&
 	      list_empty(&sched->kss_rx_conns) &&
-	      list_empty(&sched->kss_tx_conns));
+	      list_empty(&sched->kss_tx_conns);
 	spin_unlock_bh(&sched->kss_lock);
 	return rc;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
index e0a8157..08a91f5 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
@@ -152,7 +152,7 @@ void ldlm_handle_bl_callback(struct ldlm_namespace *ns,
 	if (lock->l_flags & LDLM_FL_CANCEL_ON_BLOCK)
 		lock->l_flags |= LDLM_FL_CANCEL;
-	do_ast = (!lock->l_readers && !lock->l_writers);
+	do_ast = !lock->l_readers && !lock->l_writers;
 	unlock_res_and_lock(lock);
 	if (do_ast) {
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_request.c b/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
index 53226b8..4f71318 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
@@ -307,7 +307,7 @@ int ldlm_blocking_ast_nocheck(struct ldlm_lock *lock)
 	int do_ast;
 	lock->l_flags |= LDLM_FL_CBPENDING;
 	if (do_ast) {
diff --git a/drivers/staging/lustre/lustre/libcfs/debug.c b/drivers/staging/lustre/lustre/libcfs/debug.c
index 5435236..021c92f 100644
--- a/drivers/staging/lustre/lustre/libcfs/debug.c
+++ b/drivers/staging/lustre/lustre/libcfs/debug.c
@@ -409,7 +409,7 @@ int libcfs_debug_init(unsigned long bufsize)
 	if (max > cfs_trace_max_debug_mb() || max < num_possible_cpus()) {
 		max = TCD_MAX_PAGES;
 	} else {
-		max = (max / num_possible_cpus());
+		max = max / num_possible_cpus();
 		max <<= (20 - PAGE_CACHE_SHIFT);
 	rc = cfs_tracefile_init(max);
diff --git a/drivers/staging/lustre/lustre/llite/file.c b/drivers/staging/lustre/lustre/llite/file.c
index 0fd113d..6dab3ba 100644
--- a/drivers/staging/lustre/lustre/llite/file.c
+++ b/drivers/staging/lustre/lustre/llite/file.c
@@ -161,7 +161,7 @@ static int ll_close_inode_openhandle(struct obd_export *md_exp,
 		op_data->op_lease_handle = och->och_lease_handle;
 		op_data->op_attr.ia_valid |= ATTR_SIZE | ATTR_BLOCKS;
-	epoch_close = (op_data->op_flags & MF_EPOCH_CLOSE);
+	epoch_close = op_data->op_flags & MF_EPOCH_CLOSE;
 	rc = md_close(md_exp, op_data, och->och_mod, &req);
 	if (rc == -EAGAIN) {
 		/* This close must have the epoch closed. */
diff --git a/drivers/staging/lustre/lustre/llite/lloop.c b/drivers/staging/lustre/lustre/llite/lloop.c
index cec9254..413a840 100644
--- a/drivers/staging/lustre/lustre/llite/lloop.c
+++ b/drivers/staging/lustre/lustre/llite/lloop.c
@@ -348,7 +348,7 @@ static void loop_make_request(struct request_queue *q, struct bio *old_bio)
 	       old_bio->bi_iter.bi_size);
 	spin_lock_irq(&lo->lo_lock);
-	inactive = (lo->lo_state != LLOOP_BOUND);
+	inactive = lo->lo_state != LLOOP_BOUND;
 	spin_unlock_irq(&lo->lo_lock);
 	if (inactive)
 		goto err;
diff --git a/drivers/staging/lustre/lustre/llite/rw.c b/drivers/staging/lustre/lustre/llite/rw.c
index 8884a43..991d20c 100644
--- a/drivers/staging/lustre/lustre/llite/rw.c
+++ b/drivers/staging/lustre/lustre/llite/rw.c
@@ -750,7 +750,7 @@ int ll_readahead(const struct lu_env *env, struct cl_io *io,
 		/* Note: we only trim the RPC, instead of extending the RPC
 		 * to the boundary, so to avoid reading too much pages during
 		 * random reading. */
-		rpc_boundary = ((end + 1) & (~(PTLRPC_MAX_BRW_PAGES - 1)));
+		rpc_boundary = (end + 1) & (~(PTLRPC_MAX_BRW_PAGES - 1));
 		if (rpc_boundary > 0)
 			rpc_boundary--;
diff --git a/drivers/staging/lustre/lustre/lov/lov_obd.c b/drivers/staging/lustre/lustre/lov/lov_obd.c
index 219852a..b2ed52f 100644
--- a/drivers/staging/lustre/lustre/lov/lov_obd.c
+++ b/drivers/staging/lustre/lustre/lov/lov_obd.c
@@ -1667,8 +1667,8 @@ static int fiemap_calc_last_stripe(struct lov_stripe_md *lsm, u64 fm_start,
 	int i, j;
 	if (fm_end - fm_start > lsm->lsm_stripe_size * lsm->lsm_stripe_count) {
-		last_stripe = (start_stripe < 1 ? lsm->lsm_stripe_count - 1 :
-							      start_stripe - 1);
+		last_stripe = start_stripe < 1 ? lsm->lsm_stripe_count - 1 :
+							      start_stripe - 1;
 		*stripe_count = lsm->lsm_stripe_count;
 	} else {
 		for (j = 0, i = start_stripe; j < lsm->lsm_stripe_count;
diff --git a/drivers/staging/lustre/lustre/obdclass/genops.c b/drivers/staging/lustre/lustre/obdclass/genops.c
index 6d440b4..01858b0 100644
--- a/drivers/staging/lustre/lustre/obdclass/genops.c
+++ b/drivers/staging/lustre/lustre/obdclass/genops.c
@@ -1221,7 +1221,7 @@ int class_connected_export(struct obd_export *exp)
 	if (exp) {
 		int connected;
 		spin_lock(&exp->exp_lock);
-		connected = (exp->exp_conn_cnt > 0);
+		connected = exp->exp_conn_cnt > 0;
 		spin_unlock(&exp->exp_lock);
 		return connected;
diff --git a/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c b/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c
index c86598d..4b62d25 100644
--- a/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c
+++ b/drivers/staging/lustre/lustre/obdclass/linux/linux-sysctl.c
@@ -206,7 +206,7 @@ static int proc_max_dirty_pages_in_mb(struct ctl_table *table, int write,
 			CERROR("Refusing to set max dirty pages to %u, which is more than 90%% of available RAM; setting to %lu\n",
 			       obd_max_dirty_pages,
 			       ((totalram_pages / 10) * 9));
-			obd_max_dirty_pages = ((totalram_pages / 10) * 9);
+			obd_max_dirty_pages = (totalram_pages / 10) * 9;
 		} else if (obd_max_dirty_pages < 4 << (20 - PAGE_CACHE_SHIFT)) {
 			obd_max_dirty_pages = 4 << (20 - PAGE_CACHE_SHIFT);
diff --git a/drivers/staging/lustre/lustre/osc/osc_io.c b/drivers/staging/lustre/lustre/osc/osc_io.c
index fad4c13..3c7300b 100644
--- a/drivers/staging/lustre/lustre/osc/osc_io.c
+++ b/drivers/staging/lustre/lustre/osc/osc_io.c
@@ -417,7 +417,7 @@ static int osc_io_setattr_start(const struct lu_env *env,
 			if (ia_valid & ATTR_SIZE) {
 				attr->cat_size = attr->cat_kms = size;
-				cl_valid = (CAT_SIZE | CAT_KMS);
+				cl_valid = CAT_SIZE | CAT_KMS;
 			if (ia_valid & ATTR_MTIME_SET) {
 				attr->cat_mtime = lvb->lvb_mtime;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
