staging: lustre: put constant on the right of binary operator
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Move constants to the right of binary operators.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
constant c;
expression e;
binary operator b = {==,!=,&,|};
- c
+ e
b
- e
+ c
- c < e
+ e > c
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/ptlrpc/client.c       |  2 +-
 drivers/staging/lustre/lustre/ptlrpc/import.c       | 10 +++++-----
 drivers/staging/lustre/lustre/ptlrpc/pack_generic.c |  2 +-
 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/client.c b/drivers/staging/lustre/lustre/ptlrpc/client.c
index c83a34a..865c8a2 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/client.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/client.c
@@ -2954,7 +2954,7 @@ void ptlrpc_init_xid(void)
 	/* Always need to be aligned to a power-of-two for multi-bulk BRW */
-	CLASSERT((PTLRPC_BULK_OPS_COUNT & (PTLRPC_BULK_OPS_COUNT - 1)) == 0);
+	CLASSERT(((PTLRPC_BULK_OPS_COUNT - 1) & PTLRPC_BULK_OPS_COUNT) == 0);
 	ptlrpc_last_xid &= PTLRPC_BULK_OPS_MASK;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/import.c b/drivers/staging/lustre/lustre/ptlrpc/import.c
index 1fd8510..f5b3245 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/import.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/import.c
@@ -899,7 +899,7 @@ static int ptlrpc_connect_interpret(const struct lu_env *env,
 	/* Determine what recovery state to move the import to. */
-	if (MSG_CONNECT_RECONNECT & msg_flags) {
+	if (msg_flags & MSG_CONNECT_RECONNECT) {
 		memset(&old_hdl, 0, sizeof(old_hdl));
 		if (!memcmp(&old_hdl, lustre_msg_get_handle(request->rq_repmsg),
 			    sizeof(old_hdl))) {
@@ -924,7 +924,7 @@ static int ptlrpc_connect_interpret(const struct lu_env *env,
 			 * eviction. If it is in recovery - we are safe to
 			 * participate since we can reestablish all of our state
 			 * with server again */
-			if ((MSG_CONNECT_RECOVERING & msg_flags)) {
+			if ((msg_flags & MSG_CONNECT_RECOVERING)) {
 				CDEBUG(level, "%s@%s changed server handle from %#llx to %#llx but is still in recovery\n",
 				       obd2cli_tgt(imp->imp_obd),
 				       imp->imp_connection->c_remote_uuid.uuid,
@@ -945,7 +945,7 @@ static int ptlrpc_connect_interpret(const struct lu_env *env,
 			imp->imp_remote_handle =
 				     *lustre_msg_get_handle(request->rq_repmsg);
-			if (!(MSG_CONNECT_RECOVERING & msg_flags)) {
+			if (!(msg_flags & MSG_CONNECT_RECOVERING)) {
 				IMPORT_SET_STATE(imp, LUSTRE_IMP_EVICTED);
 				rc = 0;
 				goto finish;
@@ -961,7 +961,7 @@ static int ptlrpc_connect_interpret(const struct lu_env *env,
 			CDEBUG(D_HA, "%s: reconnected but import is invalid; marking evicted\n",
 			       imp->imp_obd->obd_name);
-		} else if (MSG_CONNECT_RECOVERING & msg_flags) {
+		} else if (msg_flags & MSG_CONNECT_RECOVERING) {
 			CDEBUG(D_HA, "%s: reconnected to %s during replay\n",
 			       imp->imp_obd->obd_name,
 			       obd2cli_tgt(imp->imp_obd));
@@ -974,7 +974,7 @@ static int ptlrpc_connect_interpret(const struct lu_env *env,
 		} else {
 			IMPORT_SET_STATE(imp, LUSTRE_IMP_RECOVER);
-	} else if ((MSG_CONNECT_RECOVERING & msg_flags) && !imp->imp_invalid) {
+	} else if ((msg_flags & MSG_CONNECT_RECOVERING) && !imp->imp_invalid) {
 		LASSERT(imp->imp_replayable);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c b/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c
index 84937ad..e9f8aa0 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/pack_generic.c
@@ -883,7 +883,7 @@ void lustre_msg_clear_flags(struct lustre_msg *msg, int flags)
 	case LUSTRE_MSG_MAGIC_V2: {
 		struct ptlrpc_body *pb = lustre_msg_ptlrpc_body(msg);
 		LASSERTF(pb, "invalid msg %p: no ptlrpc body!\n", msg);
-		pb->pb_flags &= ~(MSG_GEN_FLAG_MASK & flags);
+		pb->pb_flags &= ~(flags & MSG_GEN_FLAG_MASK);
 		return;
 	default:
BtrLinux
Privacy Overview
