staging: lustre: ptlrpc: Use !x to check for kzalloc failure
Author: Julia Lawall <Julia.Lawall@lip6.fr>
!x is more normal for kzalloc failure in the kernel.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x;
statement S1, S2;
x = kzalloc(...);
if (
- x == NULL
+ !x
 ) S1 else S2
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/ptlrpc/client.c       | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c | 8 ++++----
 drivers/staging/lustre/lustre/ptlrpc/nrs.c          | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c      | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c     | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/sec_config.c   | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/sec_plain.c    | 2 +-
 drivers/staging/lustre/lustre/ptlrpc/service.c      | 4 ++--
 8 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/client.c b/drivers/staging/lustre/lustre/ptlrpc/client.c
index a12cd66..c83a34a 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/client.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/client.c
@@ -971,7 +971,7 @@ int ptlrpc_set_add_cb(struct ptlrpc_request_set *set,
 	struct ptlrpc_set_cbdata *cbdata;
 	cbdata = kzalloc(sizeof(*cbdata), GFP_NOFS);
-	if (cbdata == NULL)
+	if (!cbdata)
 		return -ENOMEM;
 	cbdata->psc_interpret = fn;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
index aaaabbf..53f9af1 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
@@ -652,7 +652,7 @@ static ssize_t ptlrpc_lprocfs_nrs_seq_write(struct file *file,
 		return -EINVAL;
 	cmd = kzalloc(LPROCFS_NRS_WR_MAX_CMD, GFP_NOFS);
-	if (cmd == NULL)
+	if (!cmd)
 		return -ENOMEM;
 	 * strsep() modifies its argument, so keep a copy
@@ -819,7 +819,7 @@ ptlrpc_lprocfs_svc_req_history_start(struct seq_file *s, loff_t *pos)
 	srhi = kzalloc(sizeof(*srhi), GFP_NOFS);
-	if (srhi == NULL)
+	if (!srhi)
 		return NULL;
 	srhi->srhi_seq = 0;
@@ -1219,7 +1219,7 @@ int lprocfs_wr_evict_client(struct file *file, const char __user *buffer,
 	char *tmpbuf;
 	kbuf = kzalloc(BUFLEN, GFP_NOFS);
-	if (kbuf == NULL)
+	if (!kbuf)
 		return -ENOMEM;
@@ -1303,7 +1303,7 @@ int lprocfs_wr_import(struct file *file, const char __user *buffer,
 		return -EINVAL;
 	kbuf = kzalloc(count + 1, GFP_NOFS);
-	if (kbuf == NULL)
+	if (!kbuf)
 		return -ENOMEM;
 	if (copy_from_user(kbuf, buffer, count)) {
diff --git a/drivers/staging/lustre/lustre/ptlrpc/nrs.c b/drivers/staging/lustre/lustre/ptlrpc/nrs.c
index 9516aca..d37cdd5 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/nrs.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/nrs.c
@@ -1156,7 +1156,7 @@ int ptlrpc_nrs_policy_register(struct ptlrpc_nrs_pol_conf *conf)
 	desc = kzalloc(sizeof(*desc), GFP_NOFS);
-	if (desc == NULL) {
+	if (!desc) {
 		rc = -ENOMEM;
 		goto fail;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
index e591cff..17cc81d 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
@@ -739,7 +739,7 @@ static int ptlrpcd_init(void)
 	size = offsetof(struct ptlrpcd, pd_threads[nthreads]);
 	ptlrpcds = kzalloc(size, GFP_NOFS);
-	if (ptlrpcds == NULL) {
+	if (!ptlrpcds) {
 		rc = -ENOMEM;
 		goto out;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c b/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
index 69d73c4..2ee3e8b 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
@@ -415,7 +415,7 @@ static int enc_pools_add_pages(int npages)
 	for (i = 0; i < npools; i++) {
 		pools[i] = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
-		if (pools[i] == NULL)
+		if (!pools[i])
 			goto out_pools;
 		for (j = 0; j < PAGES_PER_POOL && alloced < npages; j++) {
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_config.c b/drivers/staging/lustre/lustre/ptlrpc/sec_config.c
index 31da43e..e7f2f33 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_config.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_config.c
@@ -564,7 +564,7 @@ struct sptlrpc_conf *sptlrpc_conf_get(const char *fsname,
 		return NULL;
 	conf = kzalloc(sizeof(*conf), GFP_NOFS);
-	if (conf == NULL)
+	if (!conf)
 		return NULL;
 	strcpy(conf->sc_fsname, fsname);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c b/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c
index 53ce0d1..a243db6 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c
@@ -444,7 +444,7 @@ struct ptlrpc_sec *plain_create_sec(struct obd_import *imp,
 	LASSERT(SPTLRPC_FLVR_POLICY(sf->sf_rpc) == SPTLRPC_POLICY_PLAIN);
 	plsec = kzalloc(sizeof(*plsec), GFP_NOFS);
-	if (plsec == NULL)
+	if (!plsec)
 		return NULL;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/service.c b/drivers/staging/lustre/lustre/ptlrpc/service.c
index 9117f1c..56a8631 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/service.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/service.c
@@ -732,7 +732,7 @@ ptlrpc_register_service(struct ptlrpc_service_conf *conf,
 	service = kzalloc(offsetof(struct ptlrpc_service, srv_parts[ncpts]),
 			  GFP_NOFS);
-	if (service == NULL) {
+	if (!service) {
 		kfree(cpts);
 		return ERR_PTR(-ENOMEM);
@@ -2298,7 +2298,7 @@ static int ptlrpc_main(void *arg)
 	env = kzalloc(sizeof(*env), GFP_NOFS);
-	if (env == NULL) {
+	if (!env) {
 		rc = -ENOMEM;
 		goto out_srv_fini;
BtrLinux
Privacy Overview
