staging: lustre: ptlrpc: Use kzalloc and kfree
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace OBD_ALLOC, OBD_ALLOC_WAIT, OBD_ALLOC_PTR, and OBD_ALLOC_PTR_WAIT by
kalloc/kcalloc, and OBD_FREE and OBD_FREE_PTR by kfree.
A simplified version of the semantic patch that makes these changes is as
follows: (http://coccinelle.lip6.fr/)
@@ expression ptr,size; @@
- OBD_ALLOC(ptr,size)
+ ptr = kzalloc(size, GFP_NOFS)
@@ expression ptr, size; @@
- OBD_FREE(ptr, size);
+ kfree(ptr);
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/ptlrpc/client.c      | 18 +++++-----
 drivers/staging/lustre/lustre/ptlrpc/connection.c  |  6 ++--
 .../staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c    | 24 ++++++-------
 drivers/staging/lustre/lustre/ptlrpc/nrs.c         | 18 +++++-----
 drivers/staging/lustre/lustre/ptlrpc/nrs_fifo.c    |  2 +-
 drivers/staging/lustre/lustre/ptlrpc/pinger.c      |  6 ++--
 drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c     | 14 ++++----
 drivers/staging/lustre/lustre/ptlrpc/sec.c         |  2 +-
 drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c    | 17 +++++----
 drivers/staging/lustre/lustre/ptlrpc/sec_config.c  | 16 ++++-----
 drivers/staging/lustre/lustre/ptlrpc/sec_plain.c   | 10 +++---
 drivers/staging/lustre/lustre/ptlrpc/service.c     | 42 ++++++++++------------
 12 files changed, 84 insertions(+), 91 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/client.c b/drivers/staging/lustre/lustre/ptlrpc/client.c
index 0357f1d..45b7af7 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/client.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/client.c
@@ -103,7 +103,8 @@ struct ptlrpc_bulk_desc *ptlrpc_new_bulk(unsigned npages, unsigned max_brw,
 	struct ptlrpc_bulk_desc *desc;
 	int i;
-	OBD_ALLOC(desc, offsetof(struct ptlrpc_bulk_desc, bd_iov[npages]));
+	desc = kzalloc(offsetof(struct ptlrpc_bulk_desc, bd_iov[npages]),
+		       GFP_NOFS);
 	if (!desc)
 		return NULL;
@@ -205,8 +206,7 @@ void __ptlrpc_free_bulk(struct ptlrpc_bulk_desc *desc, int unpin)
 			page_cache_release(desc->bd_iov[i].kiov_page);
-	OBD_FREE(desc, offsetof(struct ptlrpc_bulk_desc,
-				bd_iov[desc->bd_max_iov]));
+	kfree(desc);
 EXPORT_SYMBOL(__ptlrpc_free_bulk);
@@ -439,7 +439,7 @@ void ptlrpc_free_rq_pool(struct ptlrpc_request_pool *pool)
 		ptlrpc_request_cache_free(req);
 	spin_unlock(&pool->prp_lock);
-	OBD_FREE(pool, sizeof(*pool));
+	kfree(pool);
 EXPORT_SYMBOL(ptlrpc_free_rq_pool);
@@ -498,7 +498,7 @@ ptlrpc_init_rq_pool(int num_rq, int msgsize,
 	struct ptlrpc_request_pool *pool;
-	OBD_ALLOC(pool, sizeof(struct ptlrpc_request_pool));
+	pool = kzalloc(sizeof(struct ptlrpc_request_pool), GFP_NOFS);
 	if (!pool)
 		return NULL;
@@ -514,7 +514,7 @@ ptlrpc_init_rq_pool(int num_rq, int msgsize,
 	if (list_empty(&pool->prp_req_list)) {
 		/* have not allocated a single request for the pool */
-		OBD_FREE(pool, sizeof(struct ptlrpc_request_pool));
+		kfree(pool);
 		pool = NULL;
 	return pool;
@@ -856,7 +856,7 @@ struct ptlrpc_request_set *ptlrpc_prep_set(void)
 	struct ptlrpc_request_set *set;
-	OBD_ALLOC(set, sizeof(*set));
+	set = kzalloc(sizeof(*set), GFP_NOFS);
 	if (!set)
 		return NULL;
 	atomic_set(&set->set_refcount, 1);
@@ -970,7 +970,7 @@ int ptlrpc_set_add_cb(struct ptlrpc_request_set *set,
 	struct ptlrpc_set_cbdata *cbdata;
-	OBD_ALLOC_PTR(cbdata);
+	cbdata = kzalloc(sizeof(*cbdata), GFP_NOFS);
 	if (cbdata == NULL)
 		return -ENOMEM;
@@ -2214,7 +2214,7 @@ int ptlrpc_set_wait(struct ptlrpc_request_set *set)
 			err = cbdata->psc_interpret(set, cbdata->psc_data, rc);
 			if (err && !rc)
 				rc = err;
-			OBD_FREE_PTR(cbdata);
+			kfree(cbdata);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/connection.c b/drivers/staging/lustre/lustre/ptlrpc/connection.c
index 7e27397..ffe36e2 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/connection.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/connection.c
@@ -54,7 +54,7 @@ ptlrpc_connection_get(lnet_process_id_t peer, lnet_nid_t self,
 	if (conn)
 		goto out;
-	OBD_ALLOC_PTR(conn);
+	conn = kzalloc(sizeof(*conn), GFP_NOFS);
 	if (!conn)
 		return NULL;
@@ -76,7 +76,7 @@ ptlrpc_connection_get(lnet_process_id_t peer, lnet_nid_t self,
 	/* coverity[overrun-buffer-val] */
 	conn2 = cfs_hash_findadd_unique(conn_hash, &peer, &conn->c_hash);
 	if (conn != conn2) {
-		OBD_FREE_PTR(conn);
+		kfree(conn);
 		conn = conn2;
 out:
@@ -227,7 +227,7 @@ conn_exit(struct cfs_hash *hs, struct hlist_node *hnode)
 	LASSERTF(atomic_read(&conn->c_refcount) == 0,
 		 "Busy connection with %d refs\n",
 		 atomic_read(&conn->c_refcount));
+	kfree(conn);
 static cfs_hash_ops_t conn_hash_ops = {
diff --git a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
index 9533ab9..1391784 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
@@ -507,7 +507,7 @@ static int ptlrpc_lprocfs_nrs_seq_show(struct seq_file *m, void *n)
 	num_pols = svc->srv_parts[0]->scp_nrs_reg.nrs_num_pols;
 	spin_unlock(&nrs->nrs_lock);
-	OBD_ALLOC(infos, num_pols * sizeof(*infos));
+	infos = kcalloc(num_pols, sizeof(*infos), GFP_NOFS);
 	if (infos == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -619,7 +619,7 @@ again:
 out:
 	if (infos)
-		OBD_FREE(infos, num_pols * sizeof(*infos));
+		kfree(infos);
 	mutex_unlock(&nrs_core.nrs_mutex);
@@ -655,7 +655,7 @@ static ssize_t ptlrpc_lprocfs_nrs_seq_write(struct file *file,
 		goto out;
-	OBD_ALLOC(cmd, LPROCFS_NRS_WR_MAX_CMD);
+	cmd = kzalloc(LPROCFS_NRS_WR_MAX_CMD, GFP_NOFS);
 	if (cmd == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -717,7 +717,7 @@ default_queue:
 out:
 	if (cmd_copy)
-		OBD_FREE(cmd_copy, LPROCFS_NRS_WR_MAX_CMD);
+		kfree(cmd_copy);
 	return rc < 0 ? rc : count;
@@ -825,7 +825,7 @@ ptlrpc_lprocfs_svc_req_history_start(struct seq_file *s, loff_t *pos)
 		return NULL;
-	OBD_ALLOC(srhi, sizeof(*srhi));
+	srhi = kzalloc(sizeof(*srhi), GFP_NOFS);
 	if (srhi == NULL)
 		return NULL;
@@ -851,7 +851,7 @@ ptlrpc_lprocfs_svc_req_history_start(struct seq_file *s, loff_t *pos)
-	OBD_FREE(srhi, sizeof(*srhi));
+	kfree(srhi);
 	return NULL;
@@ -861,7 +861,7 @@ ptlrpc_lprocfs_svc_req_history_stop(struct seq_file *s, void *iter)
 	struct ptlrpc_srh_iterator *srhi = iter;
 	if (srhi != NULL)
+		kfree(srhi);
 static void *
@@ -895,7 +895,7 @@ ptlrpc_lprocfs_svc_req_history_next(struct seq_file *s,
+	kfree(srhi);
 	return NULL;
@@ -1191,7 +1191,7 @@ int lprocfs_wr_evict_client(struct file *file, const char __user *buffer,
 	char	      *kbuf;
 	char	      *tmpbuf;
-	OBD_ALLOC(kbuf, BUFLEN);
+	kbuf = kzalloc(BUFLEN, GFP_NOFS);
 	if (kbuf == NULL)
 		return -ENOMEM;
@@ -1225,7 +1225,7 @@ int lprocfs_wr_evict_client(struct file *file, const char __user *buffer,
 	class_decref(obd, __func__, current);
 out:
-	OBD_FREE(kbuf, BUFLEN);
+	kfree(kbuf);
 	return count;
 EXPORT_SYMBOL(lprocfs_wr_evict_client);
@@ -1275,7 +1275,7 @@ int lprocfs_wr_import(struct file *file, const char __user *buffer,
 	if (count > PAGE_CACHE_SIZE - 1 || count <= prefix_len)
 		return -EINVAL;
-	OBD_ALLOC(kbuf, count + 1);
+	kbuf = kzalloc(count + 1, GFP_NOFS);
 	if (kbuf == NULL)
 		return -ENOMEM;
@@ -1319,7 +1319,7 @@ int lprocfs_wr_import(struct file *file, const char __user *buffer,
 		ptlrpc_recover_import(imp, uuid, 1);
 out:
-	OBD_FREE(kbuf, count + 1);
+	kfree(kbuf);
 	return count;
 EXPORT_SYMBOL(lprocfs_wr_import);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/nrs.c b/drivers/staging/lustre/lustre/ptlrpc/nrs.c
index 81ad747..68c754f 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/nrs.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/nrs.c
@@ -715,7 +715,7 @@ static int nrs_policy_unregister(struct ptlrpc_nrs *nrs, char *name)
 	nrs_policy_fini(policy);
 	LASSERT(policy->pol_private == NULL);
-	OBD_FREE_PTR(policy);
+	kfree(policy);
 	return 0;
@@ -761,7 +761,7 @@ static int nrs_policy_register(struct ptlrpc_nrs *nrs,
 	rc = nrs_policy_init(policy);
 	if (rc != 0) {
+		kfree(policy);
 		return rc;
@@ -776,7 +776,7 @@ static int nrs_policy_register(struct ptlrpc_nrs *nrs,
+		kfree(policy);
 		return -EEXIST;
@@ -1013,7 +1013,7 @@ again:
 	if (hp)
-		OBD_FREE_PTR(nrs);
+		kfree(nrs);
@@ -1153,7 +1153,7 @@ int ptlrpc_nrs_policy_register(struct ptlrpc_nrs_pol_conf *conf)
 		goto fail;
-	OBD_ALLOC_PTR(desc);
+	desc = kzalloc(sizeof(*desc), GFP_NOFS);
 	if (desc == NULL) {
 		rc = -ENOMEM;
 		goto fail;
@@ -1210,7 +1210,7 @@ again:
 				LASSERT(rc2 == 0);
 				mutex_unlock(&ptlrpc_all_services_mutex);
-				OBD_FREE_PTR(desc);
+				kfree(desc);
 				goto fail;
@@ -1233,7 +1233,7 @@ again:
 				LASSERT(rc2 == 0);
+				kfree(desc);
 				goto fail;
@@ -1301,7 +1301,7 @@ int ptlrpc_nrs_policy_unregister(struct ptlrpc_nrs_pol_conf *conf)
 	       conf->nc_name);
 	list_del(&desc->pd_list);
+	kfree(desc);
 fail:
@@ -1747,7 +1747,7 @@ void ptlrpc_nrs_fini(void)
 	list_for_each_entry_safe(desc, tmp, &nrs_core.nrs_policies,
 				     pd_list) {
 		list_del_init(&desc->pd_list);
+		kfree(desc);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/nrs_fifo.c b/drivers/staging/lustre/lustre/ptlrpc/nrs_fifo.c
index eb40c01..2eefa25 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/nrs_fifo.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/nrs_fifo.c
@@ -105,7 +105,7 @@ static void nrs_fifo_stop(struct ptlrpc_nrs_policy *policy)
 	LASSERT(head != NULL);
 	LASSERT(list_empty(&head->fh_list));
-	OBD_FREE_PTR(head);
+	kfree(head);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/pinger.c b/drivers/staging/lustre/lustre/ptlrpc/pinger.c
index 9dbda93..5abb91c 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/pinger.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/pinger.c
@@ -427,7 +427,7 @@ struct timeout_item *ptlrpc_new_timeout(int time, enum timeout_event event,
 	struct timeout_item *ti;
-	OBD_ALLOC_PTR(ti);
+	ti = kzalloc(sizeof(*ti), GFP_NOFS);
 	if (!ti)
 		return NULL;
@@ -514,7 +514,7 @@ int ptlrpc_del_timeout_client(struct list_head *obd_list,
 	LASSERTF(ti != NULL, "ti is NULL !\n");
 	if (list_empty(&ti->ti_obd_list)) {
 		list_del(&ti->ti_chain);
-		OBD_FREE_PTR(ti);
+		kfree(ti);
 	mutex_unlock(&pinger_mutex);
 	return 0;
@@ -529,7 +529,7 @@ int ptlrpc_pinger_remove_timeouts(void)
 	list_for_each_entry_safe(item, tmp, &timeout_list, ti_chain) {
 		LASSERT(list_empty(&item->ti_obd_list));
 		list_del(&item->ti_chain);
-		OBD_FREE_PTR(item);
+		kfree(item);
 	return 0;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
index 0c178ec..5ba3e6e 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
@@ -528,8 +528,9 @@ static int ptlrpcd_bind(int index, int max)
 	if (rc == 0 && pc->pc_npartners > 0) {
-		OBD_ALLOC(pc->pc_partners,
-			  sizeof(struct ptlrpcd_ctl *) * pc->pc_npartners);
+		pc->pc_partners = kcalloc(pc->pc_npartners,
+					  sizeof(struct ptlrpcd_ctl *),
+					  GFP_NOFS);
 		if (pc->pc_partners == NULL) {
 			pc->pc_npartners = 0;
 			rc = -ENOMEM;
@@ -699,8 +700,7 @@ out:
 	if (pc->pc_npartners > 0) {
 		LASSERT(pc->pc_partners != NULL);
-		OBD_FREE(pc->pc_partners,
+		kfree(pc->pc_partners);
 		pc->pc_partners = NULL;
@@ -717,7 +717,7 @@ static void ptlrpcd_fini(void)
 			ptlrpcd_free(&ptlrpcds->pd_threads[i]);
 		ptlrpcd_stop(&ptlrpcds->pd_thread_rcv, 0);
 		ptlrpcd_free(&ptlrpcds->pd_thread_rcv);
-		OBD_FREE(ptlrpcds, ptlrpcds->pd_size);
+		kfree(ptlrpcds);
 		ptlrpcds = NULL;
@@ -738,7 +738,7 @@ static int ptlrpcd_init(void)
 		nthreads &= ~1; /* make sure it is even */
 	size = offsetof(struct ptlrpcd, pd_threads[nthreads]);
-	OBD_ALLOC(ptlrpcds, size);
+	ptlrpcds = kzalloc(size, GFP_NOFS);
 	if (ptlrpcds == NULL) {
 		rc = -ENOMEM;
 		goto out;
@@ -781,7 +781,7 @@ out:
 			ptlrpcd_free(&ptlrpcds->pd_threads[j]);
-		OBD_FREE(ptlrpcds, size);
+		kfree(ptlrpcds);
 		ptlrpcds = NULL;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec.c b/drivers/staging/lustre/lustre/ptlrpc/sec.c
index 21e9dc9..bcfd0b0 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec.c
@@ -866,7 +866,7 @@ void sptlrpc_request_out_callback(struct ptlrpc_request *req)
 	if (req->rq_pool || !req->rq_reqbuf)
 		return;
-	OBD_FREE(req->rq_reqbuf, req->rq_reqbuf_len);
+	kfree(req->rq_reqbuf);
 	req->rq_reqbuf = NULL;
 	req->rq_reqbuf_len = 0;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c b/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
index c05a855..97edc91 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_bulk.c
@@ -210,7 +210,7 @@ static void enc_pools_release_free_pages(long npages)
 	/* free unused pools */
 	while (p_idx_max1 < p_idx_max2) {
 		LASSERT(page_pools.epp_pools[p_idx_max2]);
-		OBD_FREE(page_pools.epp_pools[p_idx_max2], PAGE_CACHE_SIZE);
+		kfree(page_pools.epp_pools[p_idx_max2]);
 		page_pools.epp_pools[p_idx_max2] = NULL;
 		p_idx_max2--;
@@ -294,7 +294,7 @@ static unsigned long enc_pools_cleanup(struct page ***pools, int npools)
 					cleaned++;
-			OBD_FREE(pools[i], PAGE_CACHE_SIZE);
+			kfree(pools[i]);
 			pools[i] = NULL;
@@ -409,12 +409,12 @@ static int enc_pools_add_pages(int npages)
 	page_pools.epp_st_grows++;
 	npools = npages_to_npools(npages);
-	OBD_ALLOC(pools, npools * sizeof(*pools));
+	pools = kcalloc(npools, sizeof(*pools), GFP_NOFS);
 	if (pools == NULL)
 		goto out;
 	for (i = 0; i < npools; i++) {
-		OBD_ALLOC(pools[i], PAGE_CACHE_SIZE);
+		pools[i] = kzalloc(PAGE_CACHE_SIZE, GFP_NOFS);
 		if (pools[i] == NULL)
 			goto out_pools;
@@ -435,7 +435,7 @@ static int enc_pools_add_pages(int npages)
 out_pools:
 	enc_pools_cleanup(pools, npools);
-	OBD_FREE(pools, npools * sizeof(*pools));
+	kfree(pools);
 out:
 	if (rc) {
 		page_pools.epp_st_grow_fails++;
@@ -508,8 +508,8 @@ int sptlrpc_enc_pool_get_pages(struct ptlrpc_bulk_desc *desc)
 	if (desc->bd_enc_iov != NULL)
 		return 0;
-	OBD_ALLOC(desc->bd_enc_iov,
-		  desc->bd_iov_count * sizeof(*desc->bd_enc_iov));
+	desc->bd_enc_iov = kcalloc(desc->bd_iov_count,
+				   sizeof(*desc->bd_enc_iov), GFP_NOFS);
 	if (desc->bd_enc_iov == NULL)
 		return -ENOMEM;
@@ -646,8 +646,7 @@ void sptlrpc_enc_pool_put_pages(struct ptlrpc_bulk_desc *desc)
 	spin_unlock(&page_pools.epp_lock);
-	OBD_FREE(desc->bd_enc_iov,
+	kfree(desc->bd_enc_iov);
 	desc->bd_enc_iov = NULL;
 EXPORT_SYMBOL(sptlrpc_enc_pool_put_pages);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_config.c b/drivers/staging/lustre/lustre/ptlrpc/sec_config.c
index 56ba9e4..16dbf3f 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_config.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_config.c
@@ -242,8 +242,7 @@ void sptlrpc_rule_set_free(struct sptlrpc_rule_set *rset)
 		(rset->srs_nrule == 0 && rset->srs_rules == NULL));
 	if (rset->srs_nslot) {
-		OBD_FREE(rset->srs_rules,
-			 rset->srs_nslot * sizeof(*rset->srs_rules));
+		kfree(rset->srs_rules);
 		sptlrpc_rule_set_init(rset);
@@ -265,7 +264,7 @@ int sptlrpc_rule_set_expand(struct sptlrpc_rule_set *rset)
 	nslot = rset->srs_nslot + 8;
 	/* better use realloc() if available */
-	OBD_ALLOC(rules, nslot * sizeof(*rset->srs_rules));
+	rules = kcalloc(nslot, sizeof(*rset->srs_rules), GFP_NOFS);
 	if (rules == NULL)
 		return -ENOMEM;
@@ -274,8 +273,7 @@ int sptlrpc_rule_set_expand(struct sptlrpc_rule_set *rset)
 		memcpy(rules, rset->srs_rules,
 		       rset->srs_nrule * sizeof(*rset->srs_rules));
 	rset->srs_rules = rules;
@@ -509,7 +507,7 @@ static void sptlrpc_conf_free_rsets(struct sptlrpc_conf *conf)
 				     &conf->sc_tgts, sct_list) {
 		sptlrpc_rule_set_free(&conf_tgt->sct_rset);
 		list_del(&conf_tgt->sct_list);
-		OBD_FREE_PTR(conf_tgt);
+		kfree(conf_tgt);
 	LASSERT(list_empty(&conf->sc_tgts));
@@ -523,7 +521,7 @@ static void sptlrpc_conf_free(struct sptlrpc_conf *conf)
 	sptlrpc_conf_free_rsets(conf);
 	list_del(&conf->sc_list);
-	OBD_FREE_PTR(conf);
+	kfree(conf);
 static
@@ -541,7 +539,7 @@ struct sptlrpc_conf_tgt *sptlrpc_conf_get_tgt(struct sptlrpc_conf *conf,
 	if (!create)
 		return NULL;
-	OBD_ALLOC_PTR(conf_tgt);
+	conf_tgt = kzalloc(sizeof(*conf_tgt), GFP_NOFS);
 	if (conf_tgt) {
 		strlcpy(conf_tgt->sct_name, name, sizeof(conf_tgt->sct_name));
 		sptlrpc_rule_set_init(&conf_tgt->sct_rset);
@@ -565,7 +563,7 @@ struct sptlrpc_conf *sptlrpc_conf_get(const char *fsname,
 	if (!create)
 		return NULL;
-	OBD_ALLOC_PTR(conf);
+	conf = kzalloc(sizeof(*conf), GFP_NOFS);
 	if (conf == NULL)
 		return NULL;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c b/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c
index a79cd53..604e511 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/sec_plain.c
@@ -376,7 +376,7 @@ struct ptlrpc_cli_ctx *plain_sec_install_ctx(struct plain_sec *plsec)
 	struct ptlrpc_cli_ctx  *ctx, *ctx_new;
-	OBD_ALLOC_PTR(ctx_new);
+	ctx_new = kzalloc(sizeof(*ctx_new), GFP_NOFS);
 	write_lock(&plsec->pls_lock);
@@ -385,7 +385,7 @@ struct ptlrpc_cli_ctx *plain_sec_install_ctx(struct plain_sec *plsec)
 		atomic_inc(&ctx->cc_refcount);
 		if (ctx_new)
-			OBD_FREE_PTR(ctx_new);
+			kfree(ctx_new);
 	} else if (ctx_new) {
 		ctx = ctx_new;
@@ -424,7 +424,7 @@ void plain_destroy_sec(struct ptlrpc_sec *sec)
 	class_import_put(sec->ps_import);
-	OBD_FREE_PTR(plsec);
+	kfree(plsec);
 static
@@ -444,7 +444,7 @@ struct ptlrpc_sec *plain_create_sec(struct obd_import *imp,
 	LASSERT(SPTLRPC_FLVR_POLICY(sf->sf_rpc) == SPTLRPC_POLICY_PLAIN);
-	OBD_ALLOC_PTR(plsec);
+	plsec = kzalloc(sizeof(*plsec), GFP_NOFS);
 	if (plsec == NULL)
 		return NULL;
@@ -508,7 +508,7 @@ void plain_release_ctx(struct ptlrpc_sec *sec,
 	LASSERT(atomic_read(&ctx->cc_refcount) == 0);
 	LASSERT(ctx->cc_sec == sec);
-	OBD_FREE_PTR(ctx);
+	kfree(ctx);
 	atomic_dec(&sec->ps_nctx);
 	sptlrpc_sec_put(sec);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/service.c b/drivers/staging/lustre/lustre/ptlrpc/service.c
index 8e61421..d0758ab 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/service.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/service.c
@@ -87,7 +87,7 @@ ptlrpc_alloc_rqbd(struct ptlrpc_service_part *svcpt)
 	OBD_CPT_ALLOC_LARGE(rqbd->rqbd_buffer, svc->srv_cptable,
 			    svcpt->scp_cpt, svc->srv_buf_size);
 	if (rqbd->rqbd_buffer == NULL) {
-		OBD_FREE_PTR(rqbd);
+		kfree(rqbd);
 		return NULL;
@@ -113,7 +113,7 @@ ptlrpc_free_rqbd(struct ptlrpc_request_buffer_desc *rqbd)
 	spin_unlock(&svcpt->scp_lock);
 	OBD_FREE_LARGE(rqbd->rqbd_buffer, svcpt->scp_service->srv_buf_size);
+	kfree(rqbd);
 int
@@ -661,13 +661,12 @@ ptlrpc_service_part_init(struct ptlrpc_service *svc,
  failed:
 	if (array->paa_reqs_count != NULL) {
-		OBD_FREE(array->paa_reqs_count, sizeof(__u32) * size);
+		kfree(array->paa_reqs_count);
 		array->paa_reqs_count = NULL;
 	if (array->paa_reqs_array != NULL) {
-		OBD_FREE(array->paa_reqs_array,
-			 sizeof(struct list_head) * array->paa_size);
+		kfree(array->paa_reqs_array);
 		array->paa_reqs_array = NULL;
@@ -724,17 +723,18 @@ ptlrpc_register_service(struct ptlrpc_service_conf *conf,
 				CERROR("%s: failed to parse CPT array %s: %d\n",
 				       conf->psc_name, cconf->cc_pattern, rc);
 				if (cpts != NULL)
-					OBD_FREE(cpts, sizeof(*cpts) * ncpts);
+					kfree(cpts);
 				return ERR_PTR(rc < 0 ? rc : -EINVAL);
 			ncpts = rc;
-	OBD_ALLOC(service, offsetof(struct ptlrpc_service, srv_parts[ncpts]));
+	service = kzalloc(offsetof(struct ptlrpc_service, srv_parts[ncpts]),
+			  GFP_NOFS);
 	if (service == NULL) {
 		if (cpts != NULL)
+			kfree(cpts);
 		return ERR_PTR(-ENOMEM);
@@ -2291,7 +2291,7 @@ static int ptlrpc_main(void *arg)
 			goto out;
-	OBD_ALLOC_PTR(env);
+	env = kzalloc(sizeof(*env), GFP_NOFS);
 	if (env == NULL) {
 		rc = -ENOMEM;
 		goto out_srv_fini;
@@ -2414,7 +2414,7 @@ out_srv_fini:
 	if (env != NULL) {
 		lu_context_fini(&env->le_ctx);
-		OBD_FREE_PTR(env);
+		kfree(env);
 out:
 	CDEBUG(D_RPCTRACE, "service thread [ %p : %u ] %d exiting: rc %d\n",
@@ -2596,7 +2596,7 @@ static void ptlrpc_svcpt_stop_threads(struct ptlrpc_service_part *svcpt)
 		thread = list_entry(zombie.next,
 					struct ptlrpc_thread, t_link);
 		list_del(&thread->t_link);
-		OBD_FREE_PTR(thread);
+		kfree(thread);
@@ -2678,7 +2678,7 @@ int ptlrpc_start_thread(struct ptlrpc_service_part *svcpt, int wait)
 	spin_lock(&svcpt->scp_lock);
 	if (!ptlrpc_threads_increasable(svcpt)) {
+		kfree(thread);
 		return -EMFILE;
@@ -2687,7 +2687,7 @@ int ptlrpc_start_thread(struct ptlrpc_service_part *svcpt, int wait)
 		 * might require unique and contiguous t_id */
 		LASSERT(svcpt->scp_nthrs_starting == 1);
+		kfree(thread);
 		if (wait) {
 			CDEBUG(D_INFO, "Waiting for creating thread %s #%d\n",
 			       svc->srv_thread_name, svcpt->scp_thr_nextid);
@@ -2733,7 +2733,7 @@ int ptlrpc_start_thread(struct ptlrpc_service_part *svcpt, int wait)
 		} else {
+			kfree(thread);
 		return rc;
@@ -2817,8 +2817,7 @@ void ptlrpc_hr_fini(void)
 	cfs_percpt_for_each(hrp, i, ptlrpc_hr.hr_partitions) {
 		if (hrp->hrp_thrs != NULL) {
-			OBD_FREE(hrp->hrp_thrs,
-				 hrp->hrp_nthrs * sizeof(hrp->hrp_thrs[0]));
+			kfree(hrp->hrp_thrs);
@@ -2999,26 +2998,23 @@ ptlrpc_service_free(struct ptlrpc_service *svc)
 		array = &svcpt->scp_at_array;
-				 sizeof(__u32) * array->paa_size);
 	ptlrpc_service_for_each_part(svcpt, i, svc)
-		OBD_FREE_PTR(svcpt);
+		kfree(svcpt);
 	if (svc->srv_cpts != NULL)
 		cfs_expr_list_values_free(svc->srv_cpts, svc->srv_ncpts);
-	OBD_FREE(svc, offsetof(struct ptlrpc_service,
-			       srv_parts[svc->srv_ncpts]));
+	kfree(svc);
 int ptlrpc_unregister_service(struct ptlrpc_service *service)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
