staging: lustre: ptlrpc: service: remove unneeded null test before free
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Kfree can cope with a null argument, so drop null tests.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@@ expression ptr; @@
- if (ptr != NULL)
  kfree(ptr);
- if (ptr != NULL) {
  kfree(ptr);
  ptr = NULL;
In the first case, specific labels are introduced to free only what is needed.
Signed-off-by: Julia Lawall
 drivers/staging/lustre/lustre/ptlrpc/service.c | 39 +++++++++-----------------
 1 file changed, 14 insertions(+), 25 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/service.c b/drivers/staging/lustre/lustre/ptlrpc/service.c
index d0758ab..d85db06 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/service.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/service.c
@@ -641,7 +641,7 @@ ptlrpc_service_part_init(struct ptlrpc_service *svc,
 	OBD_CPT_ALLOC(array->paa_reqs_count,
 		      svc->srv_cptable, cpt, sizeof(__u32) * size);
 	if (array->paa_reqs_count == NULL)
-		goto failed;
+		goto free_reqs_array;
 	cfs_timer_init(&svcpt->scp_at_timer, ptlrpc_at_timer, svcpt);
 	/* At SOW, service time should be quick; 10s seems generous. If client
@@ -655,20 +655,16 @@ ptlrpc_service_part_init(struct ptlrpc_service *svc,
 	/* We shouldn't be under memory pressure at startup, so
 	 * fail if we can't allocate all our buffers at this time. */
 	if (rc != 0)
-		goto failed;
+		goto free_reqs_count;
 	return 0;
- failed:
-	if (array->paa_reqs_count != NULL) {
-		kfree(array->paa_reqs_count);
-		array->paa_reqs_count = NULL;
-	if (array->paa_reqs_array != NULL) {
-		kfree(array->paa_reqs_array);
-		array->paa_reqs_array = NULL;
+free_reqs_count:
+	kfree(array->paa_reqs_count);
+	array->paa_reqs_count = NULL;
+free_reqs_array:
+	kfree(array->paa_reqs_array);
+	array->paa_reqs_array = NULL;
 	return -ENOMEM;
@@ -722,8 +718,7 @@ ptlrpc_register_service(struct ptlrpc_service_conf *conf,
 			if (rc <= 0) {
 				CERROR("%s: failed to parse CPT array %s: %d\n",
 				       conf->psc_name, cconf->cc_pattern, rc);
-				if (cpts != NULL)
-					kfree(cpts);
+				kfree(cpts);
 				return ERR_PTR(rc < 0 ? rc : -EINVAL);
 			ncpts = rc;
@@ -733,8 +728,7 @@ ptlrpc_register_service(struct ptlrpc_service_conf *conf,
 	service = kzalloc(offsetof(struct ptlrpc_service, srv_parts[ncpts]),
 			  GFP_NOFS);
 	if (service == NULL) {
-		if (cpts != NULL)
-			kfree(cpts);
+		kfree(cpts);
 		return ERR_PTR(-ENOMEM);
@@ -2997,15 +2991,10 @@ ptlrpc_service_free(struct ptlrpc_service *svc)
 		cfs_timer_disarm(&svcpt->scp_at_timer);
 		array = &svcpt->scp_at_array;
 	ptlrpc_service_for_each_part(svcpt, i, svc)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
