Staging: lustre: ptlrpc: lproc_ptlrpc: remove unneeded null test before free
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Kfree can cope with a null argument, so drop null tests.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
@@ expression ptr; @@
- if (ptr != NULL)
  kfree(ptr);
In the first case, the only cleanup needed is the unlock, so jump to that
directly.
Likewise, in the first two failure cases of ptlrpc_lprocfs_nrs_seq_write,
no cleanup is needed, so just drop the goto and return directly.
Signed-off-by: Julia Lawall
 .../staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c    | 26 ++++++++--------------
 1 file changed, 9 insertions(+), 17 deletions(-)
diff --git a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
index 1391784..aeceef5 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/lproc_ptlrpc.c
@@ -510,7 +510,7 @@ static int ptlrpc_lprocfs_nrs_seq_show(struct seq_file *m, void *n)
 	infos = kcalloc(num_pols, sizeof(*infos), GFP_NOFS);
 	if (infos == NULL) {
 		rc = -ENOMEM;
-		goto out;
+		goto unlock;
 again:
@@ -617,10 +617,8 @@ again:
 		goto again;
-out:
-	if (infos)
-		kfree(infos);
+	kfree(infos);
+unlock:
 	mutex_unlock(&nrs_core.nrs_mutex);
 	return rc;
@@ -650,16 +648,12 @@ static ssize_t ptlrpc_lprocfs_nrs_seq_write(struct file *file,
 	char			       *token;
 	int				rc = 0;
-	if (count >= LPROCFS_NRS_WR_MAX_CMD) {
-		rc = -EINVAL;
-		goto out;
+	if (count >= LPROCFS_NRS_WR_MAX_CMD)
+		return -EINVAL;
 	cmd = kzalloc(LPROCFS_NRS_WR_MAX_CMD, GFP_NOFS);
-	if (cmd == NULL) {
-		rc = -ENOMEM;
-		goto out;
+	if (cmd == NULL)
+		return -ENOMEM;
 	 * strsep() modifies its argument, so keep a copy
@@ -716,8 +710,7 @@ default_queue:
 out:
-	if (cmd_copy)
-		kfree(cmd_copy);
+	kfree(cmd_copy);
 	return rc < 0 ? rc : count;
@@ -860,8 +853,7 @@ ptlrpc_lprocfs_svc_req_history_stop(struct seq_file *s, void *iter)
 	struct ptlrpc_srh_iterator *srhi = iter;
-	if (srhi != NULL)
-		kfree(srhi);
+	kfree(srhi);
 static void *
BtrLinux
Privacy Overview
